How much more gas can you get in the tank after the first shutoff?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ctxtaco, Apr 12, 2010.
  1. Apr 12, 2010 at 8:20 PM
    ctxtaco
    ctxtaco [OP] Well-Known Member
    Austin, Texas
    2010 PreRunner SR5 Double Cab
    Black tube steps
    2010 stock DC with 4600 miles, first oil change just done, getting around 22.0 MPG at 65 MPH on the highway. On the last fill up, I noticed after the pump shut off, putting more in slowly, I got about an additional 2.5 gallons in the tank, but still not up to the cap. How much more gas can you get in going to the cap? Is there any harm in doing so with reference to venting, sensors, etc?
  2. Apr 12, 2010 at 8:21 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    If you got 2.5 gallons you probably had a faulty pump handle. It shuts off when the level gets to the handle... You shouldn't try to go anymore if you're at the known max.
  3. Apr 12, 2010 at 8:31 PM
    808StateTacoma
    808StateTacoma SEARCH button is my BEST FRIEND
    Honolulu, Hawaii
    Magnetic Grey 2010 TRD Sport Access Cab
    Weathertech Floor Mats Wet Okole Seat Covers Ultragauge Flowmaster Original 40 Series Rear Suspension TSB SlimbCubby 4300K HID Hi/Lo
    i usually try to even out the dollar after the click.
  4. Apr 12, 2010 at 8:31 PM
    thekidcatcher
    thekidcatcher Well-Known Member
    Waco, TX
    05 TRD offroad SR5
    Legs- --Helo rims --Duratrac 285/75/R16 --Bilstein 5100 in front with OME 886 --Dakar with extra leaf --Total Chaos UCA's --5165's Bilstein in the rear Electronics- --Warn M8000 w/ Warn wirless remote --Cobra 29LTD CB, --12in sub with alpine amp , --Dual Battery, --Warn Air compressor --URD MAF sensor, --touchscreen cd player hooked up to front and rear cameras Armor- --All-Pro offroad front/rear/rocksliders --AP skid plate, diff armor Cajones- --JBA headers, midpipe, exhaust --Safari Snorkel --4.56s Misc- highlift jack --UWS toolbox --u bolt flip kit --Tepui Kukenam Custom- --in dash inverter --on-board shower system --dvd anytime mod --custom bed rack and tiregate.
    ^ same for me man
  5. Apr 12, 2010 at 8:33 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    When the gas is on your shoes , that was too much .
    OZ
  6. Apr 12, 2010 at 8:35 PM
    EquinsuOcha
    EquinsuOcha Bourbon
    Casey
    Ft Worth, TX
    07 PreRunner
    AFE Drop-in filter, Wet Okole seat covers, Hifonics 6.5" components in front, MA Audio midbasses in rear, Kicker 8", RE Audio 2 channel for components, Elemental Designs bridged 2-channel for sub, CB, Devil Horns, Rancho QuickLift, Rancho RS9000XL rear shocks, Toytec AAL, stickers, things and stuff.
    I can get about half of a gallon in each of my shoes.
  7. Apr 12, 2010 at 8:37 PM
    81shark
    81shark Well-Known Member
    2006 Base Access CP1
    stop when the pump clicks off. no need to go further. i play with plastic, so i don't care about roudning
  8. Apr 12, 2010 at 8:43 PM
    OZ-T
    Peter North
    British Columbia
    But do you have to pay for it ?
    OZ
  9. Apr 12, 2010 at 8:46 PM
    Duck760
    Duck760 The Duck
    I usually put it full to the first click... take out the pump to remove the air (idk y) then go till next click
  10. Apr 12, 2010 at 8:48 PM
    Project.paradigm
    Project.paradigm Well-Known Member
    Oil Country,Alberta, Canada
    04 TRD 4X4 Dub cab
    Airlift rear air bags. Hood struts. sockmonkey bedside decal. TRD supercharger(not installed). Deckplate. Grey wire mod. Extended rear diff breather. 6000k HIDS. 18"Magnaflow. Truxxx 3" level kit. (Temporary) Wet Okole seat covers. BoxRocket bed rack. Bora 0.75 wheel spacers All pro sliders. BAMF BPV. B&M trans cooler.
    Your tank has a cavity at the top to allow for expansion or contracting of the fuel. You shouldn't keep adding more once the pump stops.
  11. Apr 12, 2010 at 8:49 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    San Antonio, TX
    2016 TRD Off-Road 4x4 DCSB - Super White
    If you were able to put in an extra 2.5 gallons after the pump shut off on you, there was something wrong with the pump.
    It is a good rule of thumb to let it be after the pump shuts its self off. If you continue to fill the truck up, you run the risk of over filling the tank. When this happens you run fuel back into the charcoal canister and can ruin the canister. It will throw a check engine light and can cost over 400 dollars to repair.
  12. Apr 12, 2010 at 8:49 PM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    Don't go higher than when it clicks off. I've read there are 2 things that you can damage by filling up higher (like going up the fill pipe). One is the fuel gauge. The other is your charcoal canister (your smog equipment). Filling up too high can get gas (liquid, not vapor) in those lines and those lines lead to the air intake. The fuel can then ruin your charcoal canister (a few hundred dollars to replace).
    EDIT: What SC4333 said (at the same time as me).
  13. Apr 12, 2010 at 8:50 PM
    EquinsuOcha
    EquinsuOcha Bourbon
    Casey
    Ft Worth, TX
    07 PreRunner
    Never. It's just like Subway; tell them the sandwich is for a duck and you get it for free.
    Anybody get the Mitch Hedberg reference?
  14. Apr 12, 2010 at 8:58 PM
    NAYo2002
    NAYo2002 Well-Known Member
    Great Falls, MT
    '09 Tacoma 4x4 TRD Off Road
    Michelin LTX A/T2, TRD Skid Plate, WeatherTech DigiFit Liners, OEM Bed Extender, OEM Bed mat, Advantage TorzaTop Trifold Tonneau, Pop & Lock PL5300
    One time stupid thing did not shut off and shot out gas all over me... It got on my jeans a little bit but mostly on my sweatshirt so I changed my sweatshirt but left the jeans on.
    That night my girlfriend and I decided to go to a Hibachi place... man I was sweating when he did the open flame thing. :D
  15. Apr 12, 2010 at 8:59 PM
    Duck760
    Duck760 The Duck
    haha i might have to try this...
  16. Apr 12, 2010 at 8:59 PM
    ctxtaco
    Austin, Texas
    Black tube steps
    Good advice. Thanks much...do not want to replace the charcoal canister.
  17. Apr 12, 2010 at 9:00 PM
    BakoTruck
    BakoTruck Well-Known Member
    Herbie Hancock
    Bakersfield, CA
    05 PreRunner TRD
    Mostly stock for now, I have added a cb radio, various cheap mods and I plan on adding aftermarket wheels and other items in the future.
    THIS. :cool:
