How much Nitrogen can you put in a Icon 2.0
Discussion in 'Suspension' started by Dellosa89, Jan 20, 2010.
  1. Jan 20, 2010 at 11:43 AM
    Dellosa89
    Dellosa89 [OP] Love peace and Taco Grease
    Brian
    Murrieta CA
    07 Prerunner TRD Off Road
    Fox 2.5 Coilovers, Camburg 1.25" UCA's, Icon RR, Icon aal,EVS foam bump stops, Borla Catback, HID Headlights and fogs, Defiant light bar, 3 hella 700 hid, Satellite Radio, Sony hu with 10'' sub, custom jetski rack, TRD seat covers, secondary air filter removed.
    Right now my truck has billys in the front at 2.5 and the rear with Icon aal with 2.0 RR, went to Ocotillo Wells last week and hit a medium size whoop section, they truck did great over them, but the rear could use a little more dampening and rebound, i was wondering if it would help if i put an extra 75 psi of nitrogen in the rear shocks? My friend has a Nitrogen tank at his place since he is constantly revalving his truck.
  2. Jan 20, 2010 at 11:47 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    The nitrogen prevents the oil from aerating and that's about it. If you need more dampening, you're looking at changing out the shim stack.
    At least, that's how Fox and King shocks work. I'd assume the Icons are similar.
    Icon does a ton of R&D on their products and the valving should be pretty much dead on. Maybe it's time for some hydraulic bumpstops in the rear?
    EDIT: How much pressure are you currently running? I keep my Fox shocks at 200psi.
  3. Jan 20, 2010 at 11:51 AM
    straycat241
    straycat241 maXXXed out mid travel
    paul
    PreRunner TRD off road 4x2
    airaid intake, jba headers, jba exhaust, DMZ enginecage, King 2.5 coilovers , 1.25camburg uca's, total chaos lca's, shock hoops with Icon 2.5 piggybacks, camburg 4.0 Spindles, Defined engineering SUA, King 2.5" Shocks w/Reservoir, King 2.5 Bumpstops,shocktacobumper,moto metal 951's, compartment locks, blackgrill,Glassworks fenders front and rear,ViS racing glass hood,PIAA 510s,hella 500's,black rebadge,fabtech spare tire holder,tailgate delete,mudflaps delete,cobra 19 ultra iii
    i remember checking my front coilovers once and it read at 60 psi would it help more to have more nitrogen in them like the max amount?
  4. Jan 20, 2010 at 11:51 AM
    Dellosa89
    Brian
    Murrieta CA
    Unfortunately the Icons 2.0 cant be revalved, for almost $400 they should be able too, Good call on the bump stops. Ill look into them, my friend might have some laying around.
  5. Jan 20, 2010 at 11:53 AM
    Dellosa89
    Brian
    Murrieta CA
    not sure ill check them, do you know the max off hand, cause i know most coilovers are around 300psi.
  6. Jan 20, 2010 at 11:54 AM
    dysfunctnlretard
    dysfunctnlretard Hi
    Manny
    CA
    2021 Jeep Rubicon
    Someone chime in here and validate me. But...I think thats way too low.
  7. Jan 20, 2010 at 11:54 AM
    mjp2
    NJ
    If you lose dampening in your shocks then you're probably either low on pressure or overheating them. Cheap and easy is to bump the pressure to the max recommended. :)
    I need friends like that! :p
  8. Jan 20, 2010 at 11:55 AM
    Dellosa89
    Brian
    Murrieta CA
    yea i believe Icon fills ther 2.5 c/o to 200psi
  9. Jan 20, 2010 at 11:56 AM
    Dellosa89
    Brian
    Murrieta CA
    Haha yea, but they wont be free just hopefully a good price.
  10. Jan 20, 2010 at 12:03 PM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    yeah, i think so too
    250 psi
  11. Jan 20, 2010 at 12:08 PM
    Its_Taco_Time
    Its_Taco_Time Well-Known Member
    Yorba Linda
    07 Tunda DC TRD Offroad
    CST spindles, Magnaflow, TRD intake
    This is right. I am having a problem with my dampening, so Icon told me to send it in to change the shim stack
    The Icon fronts run @ 250 psi, not sure about the rear resi though.
