How much oil do you lose when checking your oil over time?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by IPNPULZ, Feb 7, 2022.
  1. Feb 7, 2022 at 5:27 PM
    IPNPULZ
    IPNPULZ [OP] Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    Oil dries out. But you may have already known that if you’ve over owned a vehicle! We’re sure that you’ve, no doubt, found yourself checking that dipstick and wondering how much oil did I just lose....
  2. Feb 7, 2022 at 5:30 PM
    eurowner
    eurowner Duke Sky
    Scoty
    If the truck burns and leaks enough oil, you never need an oil change.
  3. Feb 7, 2022 at 5:30 PM
    Montana_Actual
    Montana_Actual ;)
  4. Feb 7, 2022 at 5:31 PM
    IPNPULZ
    going to be fun!
    There were also no signs of smoke or strange smells either. That is because nothing is wrong with the car. So what was causing all the oil to “disappear” and where was this mysterious oil disappearing to?
    Junkhead and Montana_Actual like this.
  5. Feb 7, 2022 at 5:32 PM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Oh this gonna be good :popcorn:
  6. Feb 7, 2022 at 5:33 PM
    Montana_Actual
    Montana_Actual ;)
    The Metaverse! (Thanks @vivid02)
    kgilly and vivid02 like this.
  7. Feb 7, 2022 at 5:34 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Move over :popcorn::popcorn:
    Squirt, kgilly, Junkhead and 3 others like this.
  8. Feb 7, 2022 at 5:35 PM
    IPNPULZ
    going to be fun!
    For most cars, it is highly recommended for you to change the oil every 7,500 miles or so. If your car is newer you might be able to go longer before changing or checking your oil.
  9. Feb 7, 2022 at 5:38 PM
    IPNPULZ
    going to be fun!
    could it be that you parked on uneven ground and shut off the engine causing you to wonder?
    Delta09 likes this.
  10. Feb 7, 2022 at 5:38 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    I have an old Eagle with a Chrysler 420A 4 banger that self changes itself in 2500 miles. It'll drink all 4.5 quarts :spy:
    Squirt, tinker_troy, Inferno! and 3 others like this.
  11. Feb 7, 2022 at 5:38 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Every combustion engine burns oil.
    Tacman19 and Willy-N like this.
  12. Feb 7, 2022 at 5:39 PM
    IPNPULZ
    going to be fun!
    Since when?
    Junkhead likes this.
  13. Feb 7, 2022 at 5:41 PM
    IPNPULZ
    going to be fun!
    How much oil should be on the dipstick? Examine the end of the dipstick and notice where the oil ends.
    StayinStock likes this.
  14. Feb 7, 2022 at 5:43 PM
    Montana_Actual
    Montana_Actual ;)
  15. Feb 7, 2022 at 5:44 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    I had a vehicle that burned/used a quart of oil every 20 gal tank:eek:
  16. Feb 7, 2022 at 5:46 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    20 gallon fuel tank? Fuckin' fancy rich guy here... :rofl:
    GreenTaco22, Junkhead, Brex69 and 4 others like this.
  17. Feb 7, 2022 at 5:47 PM
    Droid
    Droid Well-Known Member
    22 Pro 6MT #FFFFFF
  18. Feb 7, 2022 at 5:48 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    When I was young I worked in a filling station, a kid would come in with a Chev Vega and buy 2 quarts of straight 30 grade oil. He put 1 quart in there at the station and would put the other in at his girlfriends house for the return trip to town.
    The girlfriend lived 15 miles away! Oil dripped out of the tailpipe...
    Squirt, PzTank, Junkhead and 4 others like this.
  19. Feb 7, 2022 at 5:50 PM
    wilcam47
    Will
    Bourbon state
    77 cutlass..:goingcrazy::facepalm:
    Squirt, PzTank, Junkhead and 2 others like this.
  20. Feb 7, 2022 at 5:52 PM
    INSAYN
    INSAYN Well-Known Member
    PNWet, Oregon
    '17 TRD OR DCSB 6MT 4x4...'97 Taco XtraCab 5MT 4x4
    DIY Fabricobbler.
    I have learned over the years that if I use the much higher quality brands of oil, it has a better understanding of it's job and does not aimlessly wander off.
    Can't say that for the cheap stuff though, it acts like a really stupid dog that constantly chases random squirrels. I can't believe companies can even sell that to the public. Go figure?
    Squirt, cryptolime, SR-71A and 4 others like this.
