how much oil do you put in?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JJ5685, Apr 4, 2012.
  1. Apr 4, 2012 at 5:31 AM
    JJ5685
    JJ5685 [OP] Well-Known Member
    NC
    08 TRD Off Road v6 sr5 4X4
    pioneer stereo, 10" rockford fosgate punchgate sub, custom box, bull bar, custom trd decals
    I put in almost 5.5 quarts of oil and I couldn't read it good but it looked almost to full mark. This morning I checked it and it was about 3/8" above full. I drained some out but still can't read stupid dip stick cause it smears up the stick. I think it looked about half way between the low and full but their is usually a stop in oil about half way. Does oil rise over night I thought it dropped?
  2. Apr 4, 2012 at 5:35 AM
    FrankNasti
    FrankNasti Well-Known Member
    Frank
    Anywhere the Army tells my wife to go.
    Subaru Forester
    The toddler and baby seat mod.
    I put about 5.2 qts in mine and it read right at full.
  3. Apr 4, 2012 at 5:36 AM
    Tythias
    Tythias Active Member
    If you leave the dip stick out for a minute then take the reading there is no smearing.
    I put in 5 liter = 5.283qt with a new filter and its just a hair under full.
  4. Apr 4, 2012 at 5:40 AM
    hillbillynwv
    hillbillynwv Well-Known Member
    Fairmont, WV
    2017 Tacoma 6MT TRD Pro
    Falken Wildpeak MT 285's
    Did you drain the oil when it was hot or cold? I always drain mine when it's still hot so more oil drains out. I put back in 5.5 quarts and it shows perfect on the stick.
  5. Apr 4, 2012 at 5:41 AM
    JJ5685
    NC
    Well I don't know how much I emptied but I hope it wasn't too much cause I drove to work. Ill try leaving the stick out fir a while cause sanding it didn't help. I think I should have around 5 quarts
  6. Apr 4, 2012 at 5:43 AM
    JJ5685
    NC
    I warmed it up for min and it was warm coming out. Not cold
  7. Apr 4, 2012 at 5:52 AM
    FrankNasti
    Frank
    Subaru Forester
    Owner's manual says;
    2TR-FE
    5.8 liters with filter, 5.1 without.
    1GR-FE 2 wheel drive excluding Prerunner
    4.5 liters with filter, 4.2 without.
    4 wheel drive and Prerunner
    5.2 liters with filter, 4.9 without.
  8. Apr 4, 2012 at 5:57 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    You mean... there's actually good information for the Owner of a vehicle in the Owner's Manual?!?! :eek:
    BLASPHEMY! Get 'em :quickdraw:
  9. Apr 4, 2012 at 6:00 AM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    Take the dipstick out before you even start draining and don't put it back in until you've put in 5 quarts. Then stick it to see how much more you need. Even using this method, the dipstick sucks and I tend to put in 5.5 regardless.
  10. Apr 4, 2012 at 6:01 AM
    bb609
    bb609 O.F.
    NH
    '09 TRD Sport Access Cab
    FOX 2 1/2" CO's STOCK UCA's - They used to be Icons! Icons suck!!! TSB Rear w/Bilstein 5100's - Air Lift System - Leer 550 Bedcover - Ventshades - Yota Bed Mat - Sheepskins!!! - Weathertechs
    I dump 5 1/2 quarts and then check it. Some times it takes the other half quart, sometimes not.
  11. Apr 4, 2012 at 6:02 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    I just put in 5.5 and I don't even bother to check the stick. Being a little bit over isn't going to hurt anything.
  12. Apr 4, 2012 at 6:03 AM
    gooch14
    gooch14 Well-Known Member
    Kyle
    Michigan
    2011 Blk DC Taco SR5 4x LB
    Bestop, Child Seats, petrified french fry, dog hair, empty Mtn Dew cans cracked windshield, scratches.
    2 gallons, some is good more is better right?
  13. Apr 4, 2012 at 6:03 AM
    Maticuno
    2011 Suburban 2500
    I still have the original Owner's Manual for the '77 in my sig pic. If you can believe it, they were putting the oil capacity in the manual even back then. Of course, you have to learn how to read hieroglyphics first.
  14. Apr 4, 2012 at 6:06 AM
    macgyver
    Brad
    Canton, GA
    I like to put vegetable oil in mine. It's cheaper. Oil is oil right?
  15. Apr 4, 2012 at 6:09 AM
    FrankNasti
    Frank
    Subaru Forester
    Guilty as charged, I actually read the whole manual. Just give me a cigarette before I face the firing squad.
  16. Apr 4, 2012 at 6:19 AM
    Pugga
    Massachusetts
    Damn... I haven't gone that far with it. I have half the book dog earred with the few quick reference pages (wheel torque specs, how to reset the maint. req'd light, capacities, etc). :eek:
  17. Apr 4, 2012 at 6:23 AM
    FrankNasti
    Frank
    Subaru Forester
    I got bored right after I bought the truck. We had just moved and all of our stuff was still in transit.
  18. Apr 4, 2012 at 7:08 AM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    Does the 4 cylinder hold the same amount or less?
  19. Apr 4, 2012 at 7:45 AM
    Pugga
    Massachusetts
  20. Apr 4, 2012 at 8:13 AM
    gooch14
    Kyle
    Michigan
    Does the manual have a 'quick reference' in it? with Oil needed with change, torque specs, dif volume, all that info?
    It'd be nice if it did, my dirt bike's manual does. Right on the inside cover it tells me all teh specs, wheel and tire recomended sizes, oil for changes, cable lengths, everything. Super nice.
