how much oil do you put in?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JJ5685, Apr 4, 2012.
  1. Apr 4, 2012 at 8:17 AM
    OH-MAN
    OH-MAN Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    I look it up once and write it on the case of oil filters for each vehicle that way my feeble memory is not strained on every change. :D
  2. Apr 4, 2012 at 8:23 AM
    FrankNasti
    FrankNasti Well-Known Member
    Frank
    Anywhere the Army tells my wife to go.
    Subaru Forester
    The toddler and baby seat mod.
    A lot of the specs are in section 8 page 371 in an '05 manual.
  3. Apr 4, 2012 at 8:31 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    5.25 qt will take you right up to the fill mark on the dip stick. When you want to read the stick leave it out for 20 minutes or so to let the oil drain down the tube.
  4. Apr 4, 2012 at 1:53 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I've got a few pages dog earred, the explanation of all the dash board dummy lights, the oil type and volume, wheel torque spec and how to reset the Maint Req'd light.
  5. Apr 4, 2012 at 2:27 PM
    Larry
    Larry CARL
    CARL
    5.5 qts w/ new filter
  6. Apr 4, 2012 at 2:31 PM
    Toyotacrawler
    Toyotacrawler She's got the jimmy legs
    Cusseta/Opelika AL
    2010 Tacoma DC TRD Sport
    5100's set to 1.75" Wheelers 3 leaf progressive AAL & 5100's for the rear Konig Countersteer Offroads K&N Drop in WeatherTech's Bed Mat Blacked out Badges Rear leaf TSB
    One of these
    and add about 1/8th of a quart. Comes out on right on the line for me.
  7. Apr 4, 2012 at 2:55 PM
    boomer6
    boomer6 Well-Known Member
    TN
    Tacoma TRD Offroad
    disabled DRLs disabled seat belt chime disabled the key in the ignition with door open buzzer Installed Illuminated 4wd switch circuit board Marker lights Flashing with turn signals Toggle switch ABS Disable Fog Lights on AnyTime Mod Changed to Yellow bulbs in the Fog Lights Converted interior lights to leds Installed oem roof rack Installed Firestone Ride Rite Air Bags and Daystar Cradles for the air bags Added oil catch can Relentless Tailgate Protector installed
    5.5 Qts. with filter
  8. Apr 4, 2012 at 4:32 PM
    CorrosiveTendency
    CorrosiveTendency When up to your nose in shit, keep your mouth shut
    Nathan S.
    Schuylkill Co, Pa
    05' DblCab SB Speedway Blue
    OME 885's, Locker Mod. Bilstein 5100's on 4 corners
    MANUAL. It's usually in a thing called the "glove compartment" also sometimes referred to as the "glove box". That storage thingie in front of the passenger seat on the dashboard. It has a flipper latch, you put 1 or 2 fingers under it and gently lift until the compartment opens, revealing an area to put stuff like napkins, a trailer plug adapter, insurance cards, registration, OWNERS MANUAL, warranty information pamphlet, etc.
    STEP 1: unlock truck and enter
    STEP 2: open glove compartment as described above
    STEP 3: remove OWNERS MANUAL
    STEP 4: READ OWNERS MANUAL
    STEP 5: slap palm to forehead while saying "duh"
    Sorry, couldn't restrain myself.
  9. Apr 4, 2012 at 4:50 PM
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    5.5 qts. Buy 6 quarts 1 change and save the .5, 5 the next and use the other .5 from the last change. Then I buy 6 quarts 1 change and save the .5, 5 the next and use the other .5 from the last change. Then I buy 6 quarts 1 change and save the .5, 5 the next and use the other .5 from the last change. Then I buy 6 quarts 1 change and save the .5, 5 the next and use the other .5 from the last change. Then I buy 6 quarts 1 change and save the .5, 5 the next and use the other .5 from the last change. Then I buy 6 quarts 1 change and save the .5, 5 the next and use the other .5 from the last change. Then I buy 6 quarts 1 change and save the .5, 5 the next and use the other .5 from the last change. Then I buy 6 quarts 1 change and save the .5, 5 the next and use the other .5 from the last change. Then I buy 6 quarts 1 change and save the .5, 5 the next and use the other .5 from the last change. Then I buy 6 quarts 1 change and save the .5, 5 the next and use the other .5 from the last change. Then I buy 6 quarts 1 change and save the .5, 5 the next and use the other .5 from the last change.
  10. Apr 4, 2012 at 4:54 PM
    big sky
    big sky Well-Known Member
    Montana
    2012 TRD Sport DCSB 4x4
    wait a minute, I think you are saying you buy 6 quarts and then buy 5 quarts the next change
  11. Apr 4, 2012 at 4:59 PM
    Larry
    Larry CARL
    CARL
    I buy a couple 5 quart jugs of Mobil-1 and a single quart. It does two changes with less math involved. :D
  12. Apr 4, 2012 at 4:59 PM
    dYL0n
    Dyl0n
    New Orleans, LA
    It's a highly advanced technical procedure. Kinda like, I turn ATRAC on then I turn ATRAC off. Then I turn ATRAC on then I turn ATRAC off. Then I turn ATRAC on then I turn ATRAC off. Then I turn ATRAC on then I turn ATRAC off. Then I turn ATRAC on then I turn ATRAC off. Then I turn ATRAC on then I turn ATRAC off. Etc.
    5.2 QTS reccommended, I do 5.5.
  13. Apr 4, 2012 at 5:04 PM
    Larry
    Larry CARL
    CARL
    same thing happens to me every time I visit Nawlins' :D
  14. Apr 4, 2012 at 5:05 PM
    dYL0n
    Dyl0n
    New Orleans, LA
    Stupid streets :(
  15. Apr 4, 2012 at 6:12 PM
    #35
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    I put in an even 5 quarts. Since I don't have need of keeping it on the "full" line, the slightly lower level is good for cutting windage especially given how fast the 6 speed lets it spin. With a mobil 1 filter that's less than 1/4" below full line; haven't verified what it does with a YZZD3 on there yet. That's for next time.
    I'd forgotten I had done that trick.
    Going a half pint low on the Fit was good for minimum 2 mpg on average (didn't have much of a windage tray), and this truck doesn't burn any to speak of, so I figured why not.
  16. Apr 4, 2012 at 7:20 PM
    #36
    dYL0n
    Dyl0n
    New Orleans, LA
    Iroh,
    Do you think Toyota engineers said they'll up the oil capacity to reduce MPG? I find it VERY hard to believe that you're getting 42 more miles out of your tank by reducing the amount of oil you out in. The excess oil is in the oil pan, not all 5.2 recommended qts are used at once. Show me some proof.
  17. Apr 4, 2012 at 7:33 PM
    #37
    iroh
    michigander
    tonneau
    Ugh. Read my post again. I said the FIT got 2 more mpg. It was at 91 cubic inch engine and was getting like 40 mpg to start with.
    *grumpy backhand
    Windage is when the air pushed around by the crankshaft starts whipping around the oil that IS in the pan. The farther away from the crankshaft the oil is, the less it gets pushed around, the less the air in the crankcase feels resistance, and the less parasitic loss you get on the crank. Simple physics that every car has to deal with. That's why you have windage trays on high performance engines, besides then excessive whipping causes oil frothing and later dead bearings.
    I stated why I did it, why it won't hurt it (you're allowed a quart down before you're even out of the range), and to boot I'm not buying another dinky quart bottle just to top off that 3/16" on the stick. End rant, going to bed.
  18. Apr 4, 2012 at 7:34 PM
    #38
    Larry
    Larry CARL
    CARL
    but love the food.
    and, I must resist the temptation of Magazine St. :D
  19. Apr 5, 2012 at 12:43 AM
    #39
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2021 TRD OFFROAD 4x4
    5.5 or whatever it takes to put it at full on the stick. With these deep skirt blocks they arent as picky as the old style blocks,
  20. Apr 5, 2012 at 4:16 AM
    #40
    JJ5685
    JJ5685 [OP] Well-Known Member
    NC
    08 TRD Off Road v6 sr5 4X4
    pioneer stereo, 10" rockford fosgate punchgate sub, custom box, bull bar, custom trd decals
    Just checked it again and am right on the full mark. Thanks for your input
