How much oil does the 2.7 hold?
Discussion in '4 Cylinder' started by The Shape, Feb 12, 2009.
  1. Feb 19, 2009 at 6:34 PM
    BUK 0H5
    BUK 0H5 Still For Sale
    Queen Creek, AZ
    Silver 09 2.7L Manual AccessCab SR5 PreRunner
    Removed Mud Flaps, Suspension TSB, 5100's all around, JVC KW-AVX710 Head Unit with Metra surround.
    I just checked mine the other day after driving it around for a few days and it looks like even with 5.5 qts it seems to be right at the very top of the top dot on the stick. I think I'll go with 5 qts the next time around and see how it looks after a few days of driving.
  2. Feb 19, 2009 at 6:55 PM
    91r100gs
    91r100gs Understand the Voice Within
    Dan
    Kansas City area
    '08 Impluse Red SR5 I-4
    Factory bed mat, TacomaWorld.com sticker, EGR In-Channel Vent Visors, AFE ProDryS drop in air filter
    Those half quarts sure are a pain:(
  3. Feb 20, 2009 at 4:21 AM
    The Shape
    The Shape [OP] Well-Known Member
    Forrest City, AR
    '09 Access Cab A/T 4banger
    Well, this is the first time I have changed the oil in my Tacoma. I have had the oil changed at the dealership up until now. I looked back at my receipts and they all show 5 quarts were put in on each oil change. So I am assuming driving around on 5 quarts is fine seeing as I have done it for 26K miles.
  4. Feb 20, 2009 at 8:52 AM
    wawireguy
    wawireguy Well-Known Member
    Under filling a little is better than over filling. I have been using 5qts. Check the oil the next morning after it sits. Easier to see it on the dip stick.
  5. Feb 20, 2009 at 5:09 PM
    CometKat
    CometKat Well-Known Member
    Carson City NV
    08 Tacoma 4X4 Regular Cab SR5
    5.75 US Quarts with the oversize V6 filter.
  6. Feb 20, 2009 at 6:59 PM
    BUK 0H5
    Queen Creek, AZ
    When I worked as a lube jockey my shop charged extra over 5 qts, as do most other shops. We didn't pour the oil out of jugs, instead we had a hose with a meter on it connected to a huge vat. If it was anything less than about 6.5 qts most of us would just call it 5 on the paper work to avoid the extra charge. Some shops will have factory specs in the computer that automaticly charge for what the factory says should go in there but as you can tell the factory spec isn't always right. Be carefull if the desk jockey tells you that your vehicle will cost extra because it takes more than 5 qts according to his computer. Ask to see how much is actually pumped in before you pay any extra.
  7. Feb 20, 2009 at 7:20 PM
    The Shape
    Forrest City, AR
    Well according to the owners manual that came with my '07 the 2.7 engine oil capacity with a filter change should be (5.8 Liters, 6.1 Quarts or 5.1 Imp. Quarts) I understand Liters and Quarts, but what is an Imp Quart????? Anyway 6.1 seems to be the recommended fill with a filter change so figuring there is probably close to 1/2 quart left in the engine that doesn't drain out 5.5 quarts should put it close to or a tad over full and 5 quarts should put it just a hair over a 1/2 quart low either of which should be fine no????
  8. Feb 25, 2009 at 10:14 PM
    marvin02
    marvin02 Well-Known Member
    '07 Access Cab SR5 - Black
    Top Dawg Folding Tonneau Cover, DIY Bed Light, Aux. Input for MP3 Player, OEM Bed Mat
    I rotate my tires every time I change my oil and let it drain while I am doing the tires, cleaning the rear brakes. etc.
    I put 6 qts. in mine and after running for a bit it is right on the full mark. The first couple of times I double checked after the truck sat overnight and it was right on the full mark the next morning.
    For my 2007, the owner's manual calls for 6 US quarts.
    I use Mobil-1.
  9. Mar 1, 2009 at 8:37 PM
    darkturtleninja
    darkturtleninja 9th level dungeon master
    Illinois
    95 2.7 3rz turd
    cold air intake, body lift, suspension lift.
    i just did mine in mine in my 2.7 and it took a jug and then some.... almost 6 quarts with new oil filter
  10. Mar 10, 2009 at 10:42 AM
    Terrier
    Terrier Well-Known Member
    Idaho
    2008 SR5 Access Cab 4x4 2.7
    Changed mine (oil and filter) last Friday. Put in 5.5 quarts and it was above the full level according to the difficult to read dipstick. Drained a little (about .18) and now just right. On the other hand, on the oil change before this one, I put in about 5.4 quarts and had to add about .1 (total of 5.5) to make it to the full mark. Go figure. In any event, I hope my dipstick reading is accurate.
  11. Mar 10, 2009 at 1:17 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Just curious, but after you add the oil on an oil change, you guys are starting the engine and letting it run for a min. before checking the oil, right?
  12. Mar 10, 2009 at 2:46 PM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    I don't know about the others, but I always run the engine for a minute or two, then let it set for about a minute before checking the level.
  13. Mar 10, 2009 at 3:35 PM
    Terrier
    Idaho
    Yes for approx. 45 seconds to a minute.
  14. Mar 11, 2009 at 6:59 AM
    tacoma-king
    tacoma-king Well-Known Member
    sault ste. marie Michigan
    1997 Tacoma
    hitch
    I let mine run for a min or 2 then check the oil level
  15. Mar 11, 2009 at 10:56 AM
    #35
    scrapedface
    scrapedface Well-Known Member
    vacaville, ca
    2008 2.7 liter 4wd tacoma
    ipod charger and aux cable, scanguage 2, wet okole seat covers, 35% tint, toytec ultimate set at 2.5"
    the whole dipstick is a design flaw. so hard to read. cuz the oil goes way up the stick then has a little plateau where it should be. especially hard to read when you put in new oil. i used mobil 1 0w-20 and my mpg went up a few. i put in about 5.7quarts
  16. Mar 11, 2009 at 11:04 AM
    #36
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    FWIW, you can sand your dipstick to make it easier to see the oil.....
    Not sure that sounded so good....
  17. Mar 11, 2009 at 6:57 PM
    #37
    06dak
    06dak Well-Known Member
    Central Ohio
    05 PreRunner SR5 4cyl
    Undercover hard tonneau, Husky front liners
  18. Mar 18, 2009 at 2:48 PM
    #38
    no_werries
    no_werries Well-Known Member
    Simcoe County, Ontario, Canada
    2005 4x4 reg cab Indigo Ink 5 speed
    CAI, 2 1/2" rear lift AAL, Ready Lift strut ext. & diff drop = 2 1/2" front lift, tweaked clutch, Magnaflo Muffler & Custom exhaust 265/75/16lt Nitto Terra Grappler 8ply on stock rims. Huskyliners
    Someone said the 4 cyl's are supposed to take 5w-20, but my oil cap says 5w-30, could been something they had to switch when I got the truck brought over to canada from states, I find between 5.5-6 quarts is where im ending up, I put oil in, start engine up for a minute, wait a couple of mintues, then check oil level again, I'll check it once more in the morning, and its usually bout bang on!
  19. Mar 18, 2009 at 2:50 PM
    #39
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Oil cap may have been changed out.
  20. Mar 18, 2009 at 3:00 PM
    #40
    no_werries
    Yeah I been running mobil 1 full synthetic 5w-30 for a year and 35,000 miles with no problems. Don't know whether to bother to try 5w-20.
