How much oil in 4.0L
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mattsyota529, Sep 16, 2021.
  1. Sep 16, 2021 at 9:32 AM
    Mattsyota529
    Mattsyota529 [OP] Active Member
    2009 Tacoma Prerunner
    So my 2009 v6 prerunner says it takes 4.8 quarts of oil but it always looks low on the dipstick after I pour in a full 5 quart bottle. So this last oil change I added in 5.5 quarts of oil and it's over on the dipstick but it runs better with the extra oil.. How much oil do yall add in? Tia
  2. Sep 16, 2021 at 9:34 AM
    Gen2Tacoma
    Gen2Tacoma A Question Asked is an Answer Learned!
    North East Atlanta
    Just a word of caution.....You are aware you can easily blow the seals by overfilling right?
  3. Sep 16, 2021 at 9:44 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    According to Mitchell service info should be 5.5 quarts with changing the filter 5.2 quarts without changing the filter. My 14 4wd takes 5.5 quarts, as far as I know all Tacoma 4.0 v6's do.
    wi_taco and 2015WhiteOR like this.
  4. Sep 16, 2021 at 9:47 AM
    Mattsyota529
    Yes I'm aware and I'm trying to prevent that. That's why I've created this thread
    gregzz likes this.
  5. Sep 16, 2021 at 9:48 AM
    Gen2Tacoma
    North East Atlanta
    10-4
  6. Sep 16, 2021 at 10:13 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    4.8 quarts for 2WD and 5.5 quarts for 4WD for 4.0 engines. I would drain until its correct on the dipstick. IMHO.
    69 Jim likes this.
  7. Sep 16, 2021 at 10:27 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    You almost never get all of the old oil out. If you let it sit and drain for an hour or so you'll get more. But for most people who only let it drain for a few minutes there will be some left in the engine. I always add 5 quarts and check it again after a short drive and add a little more if it needs it. The oil doesn't have to come all the way to the top of the mark on the dipstick. As long as it is somewhere in the middle it is fine.
  8. Sep 16, 2021 at 10:29 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    4.8 quarts is for the 5 lug v6 (xrunner). All 6 lug trucks take 5.5 quarts. Personally I just put a 5 qt jug in and call it good.
    BizzyB726, pahaf, BlkDakDave and 6 others like this.
  9. Sep 16, 2021 at 10:46 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Yep....my PreRunner with the tow pack is 5.5 quarts. 5.25 puts me on the money every time
    Tacoma Mike likes this.
  10. Sep 16, 2021 at 11:42 AM
    LancerRevo
    LancerRevo Well-Known Member
    Phillip
    2007 Tacoma Pre Runner V6 4.0
    On my 07 pre runner 4.0 I do 5.5qt and it gets right to the top dot on the dipstick. I wish they made it easier with just 5qt so I don't have to spend an extra $8-10 on 1qt when its $24 for 5qt. But, at least I can use the other half on the next change haha
  11. Sep 16, 2021 at 11:48 AM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    Having a .5 quart leftover is not a total waste of time or energy. You'll learn you can use it for other purposes around the house. I keep my half quart leftover in the bedroom.
  12. Sep 16, 2021 at 11:53 AM
    LancerRevo
    Phillip
    Nah its not haha, its not a big deal and helps just in case it does lower. But *knock on wood*, the level always stays right near the top dot. 190k on her.
  13. Sep 16, 2021 at 12:04 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    5.5 on my 4WD 2015
    Anywhere between the dots on the dipstick is fine. There's reason it's called the "safe zone"
    Also curious how you can tell it "runs better" with 5.5 versus 4.8
    PzTank and Jimmyh like this.
  14. Sep 16, 2021 at 1:33 PM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    Blow seals by overfilling by .7 qts.. ugh no
  15. Sep 16, 2021 at 3:17 PM
    Beerline123
    Beerline123 Well-Known Member
    07 Tacoma access 4x4
    I just put 5 qts in seems to work out 172000 and.a.pretty quiet engine
    QChawks and Monkeybutt2000 like this.
  16. Sep 16, 2021 at 3:47 PM
    Gen2Tacoma
    North East Atlanta
    I didn't day by .7 quarts. I simply said by over filling. And I have seen it happen on older chevy's for sure if the seals are already older and weak. But each to their own. :anonymous: he has a 2009 with undisclosed mileage.
  17. Sep 16, 2021 at 3:53 PM
    Brian_d
    Brian_d Well-Known Member
    Socal
    Is this for real? Or is it some kind of marine mammal joke?
  18. Sep 16, 2021 at 4:06 PM
    Gen2Tacoma
    North East Atlanta
    Put 2 quarts over in truck and check back with me in 5000 miles. I never said how much I simply said over filling! Y'all some peeps! It depends on how much over the age of the truck the condition of the seals maintenance done etc! Geese I was just trying to save the guy some issues because he said he kept puttin in oil. Y'all act like the facebook trolls!
  19. Sep 16, 2021 at 4:11 PM
    Brian_d
    Socal
    Take it easy - Not trolling - I've never heard of this issue before. Geese I was just trying to hide my ignorance with light/funny.
  20. Sep 16, 2021 at 4:11 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    I just dump in the 5 quart jug and call it good....except when I accidentally drain my tranny. Then I roll with ten quarts.
    JUST KIDDING, don't put in ten quarts!
    tinker_troy likes this.
