How much oil...
Discussion in 'Performance and Tuning' started by beastlytaco, Nov 22, 2008.
  1. Nov 22, 2008 at 8:30 AM
    beastlytaco
    beastlytaco [OP] Well-Known Member
    Ian
    08 Access Cab SR5
    i have the 08 tacoma 2TR-FE 4 cyl. and i need to know exactly how many quarts of oil to use. the oil is 5w-20 and i have the truck oil changed, sitting in my garage, i just need to know how many quarts to add.
  2. Nov 22, 2008 at 8:34 AM
    beastlytaco
    Ian
    08 Access Cab SR5
    guys, i know this is a stupid question but i really need help on this. i cant find it in the manual, either.
  3. Nov 22, 2008 at 8:53 AM
    CometKat
    CometKat Well-Known Member
    Carson City NV
    08 Tacoma 4X4 Regular Cab SR5
    The manual says 6.1 quarts for an oil change with filter. Be advised this will show an overfill on the stick. If you want to go strictly by the stick use 5.25 quarts with a filter. The disparity is ridiculous but nobody has ever got a straight answer from Toyota. Last time I used 6 quarts with the slightly larger V6 filter.
  4. Nov 22, 2008 at 3:47 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Wow. Manual calls for 6.1 Qts., but only 5.25 to show "FULL" on the dipstick. :confused: I always go by what the manual state on all my vehicles, and on my 2000 2.7 it said 5.5 qts. for a drain and fill with filter change, which put it right at the "FULL" mark on the stick. :confused:
  5. Nov 22, 2008 at 6:52 PM
    beastlytaco
    Ian
    08 Access Cab SR5
    yeah i looked it up and for some reason i got 5.4 quarts was the ideal mark?? i changed the oil this morning and did it trial and error. i would put oil in, then run it through the crank case and then i would keep doing that, till i got the right amount of oil in the crank case
