How Much Performance Loss From Larger Wheels/Tires?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by joecbr, Feb 27, 2021.
  1. Feb 27, 2021 at 11:58 AM
    joecbr
    joecbr [OP] Member
    2018 TRD Off Road Long Bed
    Toyota Roof rack, Havoc Side Steps, Blackout Emblems, PlastiDip Grill
    2018 TRD Off Road Long Bed - I am considering larger tires and a small lift on my 2018 TRD. I plan to do it in steps, starting with a slightly larger tire (265/75 R16) on the factory wheels. The 265/75 has a 31.65 inch diameter compared to the stock 265/70 30.61 inch. I'm considering the 265/75 Copper Discoverer tire which is about the same weight as the stock 265/70 tires. After seeing how the tires work out I may consider a Bilstein 1-2 inch lift front and rear.
    Given that the V6 is already struggling with the stock tires regarding performance (acceleration, highway passing, cruising on a grade etc.,) I'm wondering if the lager diameter tire will be noticeably worse. Also wondering if gas mileage will be significantly reduced. I love my TACO but the engine lacks low/midrange torque and is really not suitable for a truck. I recently discovered the engine is actually Atkinson cycle in cruise mode. This explains why it is so reluctant to downshift on the highway, and then suddenly explodes dropping 2-3 gears to accelerate.
    I would greatly appreciate anyone's experience on this issue after switching to larger tires.
  2. Feb 27, 2021 at 12:01 PM
    ryanvar42
    ryanvar42 Well-Known Member
    2024 Silverado Trailboss
    None
    About 50 percent
    Skydvrr likes this.
  3. Feb 27, 2021 at 12:18 PM
    Mtn Mike
    Mtn Mike Well-Known Member
    Spokane, WA
    2017 TRD OR AC
    I switched from stock tires to the 265/75 Discoverer AT3 4S and felt a noticeable decrease in performance. I've run them for about 15,000 miles. Objectively, my Fuelly stats went down by an average of 1.5 MPG. Subjectively I notice slower acceleration and decreased braking performance. They're nice tires and I like the look and off-road performance of the bigger tires. But for me it hasn't been worth the sacrifice in performance. I was about to post my AT3 4S in the buy/sell/trade forum. Make me an offer :) I'm going back to the stock size.
    Kolohe07 and Vmax540 like this.
  4. Feb 27, 2021 at 12:22 PM
    Juisebocks
    Juisebocks Commander of the Inglorious Badger
    Drew
    2015 SR5 2.7L AT OPAF,DTF&PITA
    "Stock+"
    The actual weight difference in the tires is where the most effect comes into play. If you can keep tire and wheel weight low enough, the difference will be way less than other tires of the same size.
    hossler1788 and R4D4G4ST like this.
  5. Feb 27, 2021 at 12:24 PM
    Mtn Mike
    Spokane, WA
    2017 TRD OR AC
    This is true. But most of the time people also go to a more aggressive tread when they increase the tire size. More aggressive almost always mean heavier, even within the same tire size. Toyota must use the Goodyear Kevlar ATs as the stock tire because it's about as light as you can get in an "all terrain" tire.
  6. Feb 27, 2021 at 12:28 PM
    bodean
    bodean Well-Known Member
    Shawn
    Crowsnest Pass, AB
    02 Taco RCSB, 16 Taco AC6MT, 07 FJC, 22 Bronco
    If it’s a concern, just leave it alone.
  7. Feb 27, 2021 at 12:29 PM
    Juisebocks
    Drew
    "Stock+"
    Definitely. I have a 4cyl AT and I kid you not, I got new wheels this morning that are about 3 lbs lighter IIRC. There was a noticeable difference on the butt dyno driving around today :burnrubber:
  8. Feb 27, 2021 at 12:31 PM
    Mtn Mike
    Spokane, WA
    2017 TRD OR AC
    This thread should be merged with all the "why is my gas mileage so bad" threads.
  9. Feb 27, 2021 at 12:31 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    You can expect 25-30% loss of mpg. You can expect even more sluggish acceleration.
    Regearing will help with the acceleration but hurt efficiency even more. When you add more drag (lifting) more unsprung weight (heavier tires) and rolling resistance (wider tires with more aggressive tread) you have to pay for it somehow because... physics. The payment is loss of mpg or efficiency.
    Remember everything has to work harder when you add stuff... engine, transmission, cooling system, power steering and pretty much everything else including brake system.
  10. Feb 27, 2021 at 12:32 PM
    Juisebocks
    Drew
    "Stock+"
    See, I knew somebody with real good words would come in here and set us straight.
  11. Feb 27, 2021 at 12:35 PM
    ryanvar42
    None
    He could tune it as well to help with what you described. The tire size increase is marginal but you will feel it most likely
    Junkhead and hiPSI[QUOTED] like this.
  12. Feb 27, 2021 at 12:47 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Not sure if serious or not.
    Juisebocks and hiPSI like this.
  13. Feb 27, 2021 at 12:50 PM
    ryanvar42
    None
    Not at all
  14. Feb 27, 2021 at 12:51 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Yes he could but he still can't break the laws of physics.
    There is a law in Thermodynamics that roughly translates to "nothing is free."
    This is both a science rule and a life rule lol.
    StayinStock and Mtn Mike like this.
  15. Feb 27, 2021 at 12:52 PM
    slistings
    slistings Well-Known Member
    SoCal
    You’re adding unsprung weight with the tires and decreasing aerodynamics with the lift. Acceleration, braking, handling, gas mileage will all take a hit but it’s going to be hard to quantify by how much for your specific application. That said, I’m guessing those qualities aren’t why you bought a Tacoma so...
  16. Feb 27, 2021 at 12:52 PM
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
    Hey Joe, Welcome to TW! I'd say that your idea of going from a 30" to 31" tire, with slightly aggressive AT tread, and adding a modest 2" lift, is a happy-medium. You'll get the look and clearance gains that you're looking for, while sacrificing the least amount of fuel efficiency. :thumbsup: The only way to fix the sluggish engine is to regear :notsure:
    AODRN, 4x4cajun and Junkhead like this.
  17. Feb 27, 2021 at 12:53 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Tune definitely wakes up this 3.5L. I get that they alway de tune engines in trucks for longevity but IMO they over did it, not that I had any issues on stock tune with power.
  18. Feb 27, 2021 at 12:53 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    That is good.:) Carry on...
    hiPSI likes this.
  19. Feb 27, 2021 at 12:54 PM
    ryanvar42
    None
    Yeah I drive mine slow af so doesn't bother me at all. Im sure a tune makes it nice but I also worry about longevity as most of these tunes haven't been on for 5 years or more
    Junkhead[QUOTED] likes this.
  20. Feb 27, 2021 at 12:55 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    FWIW I get the same or better MPGs on 265/70/17 C load KO2s than my buddy with identical truck on stock Firestone SL tires. We are both on stock sport suspension and both MTs.
    RyanDCLB[QUOTED] and hiPSI like this.
