How much pressure does this Nut have when truck is on the ground?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by trexTRD, Oct 7, 2014.
  1. Oct 7, 2014 at 9:08 PM
    #41
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    So that's how the nut face got rounded!
  2. Oct 7, 2014 at 9:11 PM
    #42
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    You could try removing it with a pipe wrench or vice grips if its rounded. I'd replace it now since it will be much harder down the road when shit starts to rust.
    And I also have an expensive 250 ft lb torque wrench and torque all critical suspension components and lug nuts.
    All info was found here on TW :thumbsup:
  3. Oct 7, 2014 at 9:59 PM
    #43
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    So the nut is rounded off, not stripped. This is easier to deal with.
    ^I would replace the nut for this reason. The corrosion protection on the Toyota OEM nut is already pretty poor. In fact, it's better if you go to Fastenal and buy a bright zinc-plated slotted nut. I did just that when I had to disconnect my outer tie rod to replace a coil spring.
    Sears, Harborfreight, etc. also sell extractor sockets which can be used to remove the rounded nut if a pipe wrench doesn't work.
  4. Oct 8, 2014 at 8:17 AM
    #44
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Just tell me you don't rebuild engines, it's one thing to be off a few lbs. on a lug nut & quite another when setting torque to main or rod bearing, or any torquing involving plasti-gauge..
  5. Oct 8, 2014 at 11:29 AM
    #45
    TrdSurgie
    TrdSurgie revised
    Oahu
    I didnt think we were talking about engines.:rolleyes:
  6. Oct 8, 2014 at 11:30 AM
    #46
    TrdSurgie
    TrdSurgie revised
    Oahu
    suck it. :cool: I told him to take care of it while it was already in the shop.
  7. Oct 8, 2014 at 3:00 PM
    #47
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
  8. Oct 8, 2014 at 4:19 PM
    #48
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    so much derpness, so little torque wrenchness.
  9. Oct 8, 2014 at 4:39 PM
    #49
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Ball joints tie rod ends etc have a Morse taper they bind up in the steering parts when tightened if the flats on the nut are damaged and it's tight it won't come apart. Don't relay on a cotter pin to hold any thing other than keeping a nut from turning.
  10. Oct 8, 2014 at 4:56 PM
    #50
    bullaculla
    Da big big island!
    :confused:
    umm, what makes you think its a morse taper? How do you know its not a Jacobs taper? Or a brown and sharpe taper?
    I really don't think ball joints have anything to do with machine tapers.
  11. Oct 8, 2014 at 7:55 PM
    #51
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I also know a lot of people that use the " two grunts and a fart method of torque " such as yourself. [​IMG]
  12. Oct 8, 2014 at 7:59 PM
    #52
    bullaculla
    Da big big island!
    :rofl: never heard of that technique before!
  13. Oct 8, 2014 at 8:09 PM
    #53
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    It becomes a shart at > 230 ft-lb
  14. Oct 8, 2014 at 8:10 PM
    #54
    mutilatedjak
    mutilatedjak n00b waffle
    WA
    11 DC SB TRD Sport 6spd
    BP-51s, Dakar leafs, ARB bumper, 4xinnovations rear HC, 3x trail camera, pure android, lightforce 170s, Dick Cepek 255 85s extreme terrain.
    Nothing really constructive to contribute besides saying you should probably fix this.
    But damn...... Get the units right. Pressure(stress) and torque are two different things.
  15. Oct 8, 2014 at 10:05 PM
    #55
    Jimmyh
    SC
    2012 Prerunner SR5
    And a full blow sh1t at 275 ft-lbs! [​IMG]
  16. Oct 9, 2014 at 4:55 AM
    #56
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    I don't any more than you do people get confused when they use US standard wrenches on metric nuts he said the flats were rounded. I do not think it should be left like that because you just don't know but just replacing the nut is a simple project.
  17. Oct 9, 2014 at 5:05 AM
    #57
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    OK it's a taper matter whose taper it is it's a tapered fit meant to stay in place when tightened. Designed not to slip with rotational force or fall out kind of like the head of a common drill press.
