How much pulling force without damage?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacoma pilot, Jul 12, 2021.
  1. Jul 12, 2021 at 12:09 PM
    tacoma pilot
    tacoma pilot [OP] Member
    I'm going to try to pull out a tree stump with a chain.
    Plan to hook one end of the chain to the tree stump, and the other end to the tow hook under the front bumper. Then reverse in 4wd.
    How much pulling force can I put on it without risk to damaging anything -- like the frame that the tow hook is attached to, for example?
    Please note that I'm not asking about towing limit. Because I'm assuming that's a different issue? I have a 2013 tacoma with 4cyl and 4wd, it does not have a trailer hitch.
    Thanks!
  2. Jul 12, 2021 at 12:12 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Use a wheel:
    https://www.youtube.com/watch?v=00MQHfLTKq8
    Pull forward, not in reverse. Backside of the axle gears aren't as strong.
    And if you can't get it after a couple of pulls, find a different way to do it.
    How do you plan to measure pulling force? I Don't think anyone will have a number for that.
  3. Jul 12, 2021 at 12:28 PM
    15TACOSPORT4X4
    15TACOSPORT4X4 Well-Known Member
    Stan
    2015 Black Tacoma TRD Sport 4x4
    3" lift on 33 inch Nitto's with 18" Fuel wheels. N-Fab step bars. Husky floor liners.
    You just reminded me of a few years ago I had a dead limb in a tree in my front yard. I said no problem I will just pull it down with my truck. I climbed the tree and tied a big rope to the limb and tied the other end to my trailer hitch. Four low and slowly started pulling but the limb won. My back tires were a foot off the ground and pulling with my front. Gave up and went and got my chainsaw. I have pulled up many a stump though. Some from the front and some from the rear and never damaged anything. Just be smart about it and it helps to dig around it first and cut as many roots as you can.
  4. Jul 12, 2021 at 12:34 PM
    VXEric
    VXEric Well-Known Member
    Eric
    Worcester, PA
    07 ACS V6 6 Spd TRD Sport
    265/70/17 ATs on 17x8"wheels and 0 offset Morimoto XB LED Fogs Reinforced tailgate 2011 Honeycomb grille URD Short Shifter and cue- ball style knob
    X2 on using a wheel (I use my spare tire w/ a 3" strap).
    I'd also suggest if you're using a chain around the stump, also use some clothes line or other 1/4" - 3/8" cordage anchored to the tire or some fixed object as a safety strap. That way if the chain or stump or anything else gives out, it doesn't go flying.
    06Tacooo and Marc70 like this.
  5. Jul 12, 2021 at 12:36 PM
    tacoma pilot
    Yeah .... the thought about reverse being weaker than forward had occurred to me. Thanks. But then I blocked it out of mind because that seems like a show stopper? I can't find anything to hook to on the back? Is there any good place?
    I'm planning to buy a hook or fastener with a rated tensile strength maximum which is significantly below the maximum-damage-free-force that the truck can handle. If I exceed the force, then the hook or fastener will fail, first (assuming that I increase the force gradually and don't pound on it). Think of it like an electrical fuse. My truck is old, but it's still worth enough that I don't want to be an idiot about this. :)
    As far as a good number, I'm thinking about doing the calculations of how much force would be required to pull the truck out of a ditch. To assume that the hook and frame attachment should be able to handle that, seems reasonable. But the math would be annoying to have to figure cause it's been decades since I've done any math. And, I'm lazy. If I was 21 years old back at the university, I'd have it figured out in less than 5 minutes. But not now! Gads, I'm old! Was hopeful someone already knows.
  6. Jul 12, 2021 at 12:36 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Please video it and share here
  7. Jul 12, 2021 at 12:37 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    DONT ! you don't have a 1 ton truck,you have a little truck with a sheet metal thin frame.
    OldManTacoFeels and ToyoTaco25 like this.
  8. Jul 12, 2021 at 12:40 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    i was told to pull ALWAYS going forward. something about the pinion gear being stronger in that direction.
    Marc70 and Scott B. like this.
  9. Jul 12, 2021 at 12:40 PM
    15TACOSPORT4X4
    Stan
    Way overthinking this. What ever happened to HEY YALL WATCH THIS...
    Naveronski, igno1tus and ToyoTaco25 like this.
  10. Jul 12, 2021 at 12:41 PM
    ToyoTaco25
    ToyoTaco25 Well-Known Member
    North Carolina
    09 Super-White DCSB 6-Speed
    ProComp 4" D-Bag, I mean Drop Bracket Lift, AMP Research Powersteps, 285/70-R17’s, Magnaflow, AFE CAI, Dipped Badges
    This is the only things that comes to mind when I hear “I’m gonna pull out this tree stump with my truck”
    https://youtu.be/3ISgFgxmxMc
    A stump grinder would be way better.
  11. Jul 12, 2021 at 12:41 PM
    aficianado
    back to bone stock.
    how big is this target stump? is it cut really low to the ground?
  12. Jul 12, 2021 at 12:42 PM
    tacoma pilot
    I'm digging now. If nothing else, it's good exercise. Do plan on cutting roots, cause it's a big stump. I'm digging pretty deep. If all fails, I'll take a chain saw to it as low as I can cut it down in the hole. Then backfill. But I'd like to get it out so don't have to deal with settling or issues with planting something new. Good times!
    edit: also with chain saws I'm a big freaking baby. I only use them when I absolutely must.
  13. Jul 12, 2021 at 12:43 PM
    tacoma pilot
    I don't want to say how big it is because you'll call me an idiot and tell me to forget it. It's cut a good 3 to 4 feet above ground, purposefully so an excavator can wrench it out. But that didn't happen for reasons.
  14. Jul 12, 2021 at 12:45 PM
    15TACOSPORT4X4
    Stan
    Your gonna need more beer...
  15. Jul 12, 2021 at 12:45 PM
    Chunk
    Chunk I smell Ice Cream!
    2016 DCSB OR
    Baby Ruth
    LET HIM DO IT! :popcorn::popcorn::popcorn:
  16. Jul 12, 2021 at 12:47 PM
    tacoma pilot
    I love it!!! More beer! More exercise!! More digging! More beer! More exercise ... seriously, this plan is looking better.
  17. Jul 12, 2021 at 12:50 PM
    15TACOSPORT4X4
    Stan
    Hell if I was your neighbor I would help ya for a few cold ones...
    winkel likes this.
  18. Jul 12, 2021 at 12:50 PM
    tacoma pilot
    LOLOL! That's hilarious! The guy basically got a ground stump -- a flat stump flush with the ground! Did you notice how it broke? This is one reason I like using a chain. Using really strong rubber bands is asking for trouble!!
    ToyoTaco25[QUOTED] likes this.
  19. Jul 12, 2021 at 12:51 PM
    aficianado
    back to bone stock.
    cutting roots is the best arguement for buying a carbide tooth chain. i notice very little mud will dull the regular chain instantly.
    and seriously. pull going forward.
  20. Jul 12, 2021 at 12:52 PM
    aficianado
    back to bone stock.
    no..
    pulled out a relatively big stump with a chevy 4x4 S10 hahaha.. it was much harder than i thought (to do)
    Roberto123 and davidstacoma like this.
