How much rear lift will these springs give me?
Discussion in 'Suspension' started by newbie taco, Sep 8, 2018.
  1. Sep 8, 2018 at 6:24 PM
    newbie taco
    newbie taco [OP] Well-Known Member
  2. Sep 8, 2018 at 6:49 PM
    Freeheelbillie
    Freeheelbillie Well-Known Member
    Billie
    Saint Clair, MI
    2019 Tacoma SR, DCSB
    FRONT END King Stage 3 3” RR Coil Overs SPC UCA’s REAR END King Stage 3 BAMF Shock Relocation Rear AAL Heavy ARB Universal Diff Breather Kit TIRES & RIMS 16” Method Bronze BFG K02 (315/75/R16) ARMOR Demello Off Road Baja Hoop Front Bumper Main Line Overland Rock Sliders w/ Top Plate ¼” Aluminum RCI Fuel Tank Skid RCI Fuel Tank Straps RCI Rear Diff Skid RCI A-Arm Skids RCI – Front, Transmission, and rear Transfer Case Skid DRIVE LINE YotaWerx, BlackHawk Tune Re Geared w/ Nitro 4.56 Package Front ARB Air Locker Rear ARB Air Locker 8” Reverse Clamshell 3.73 & Down Carrier RECOVERY ComeUp Seal Gen2 9.5RS Winch, Synthetic Line ComeUp Seal Hawse Fairlead ARB On Board Twin Air Compressor LIGHTING Squadron-R Pro Amber Fogs (Wide Cornering) Baja Designs Rock Lights Squadron Sport Fogs (qty 4) Baja Designs Bed Light Kit SPODS, HD 8 Circuit Switch Panel
    For the money I'd check out OME...just my opinion.
  3. Sep 8, 2018 at 6:53 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    OME, Deaver, Dakar...
    A 3 leaf add on to your current factory springs if still in great shape will easily last you years and years past what OEM will last you. I know because I run a 3+ add on.. and I have beat the ever loving hell out of my packs. Still going incredibly strong.
  4. Sep 8, 2018 at 7:35 PM
    newbie taco
    Will it give you more lift?
  5. Sep 8, 2018 at 8:29 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Yes it will. Overall height after fill assembly will be anything from 1.75-2.25 depending how many leafs you use or if you want to use your overload spring.
  6. Sep 9, 2018 at 4:00 AM
    Freeheelbillie
    Billie
    Saint Clair, MI
    What are you running up front?
  7. Sep 9, 2018 at 4:50 AM
    MattCowsmasher
    MattCowsmasher ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Temple, Tx
    O3 Rubicon wrangler
    For the money like stated above go ome or a 3 leaf aal that goes on your factory leafs. I had icon aal prior to ome dakars an they rode great unloaded any real weight in the back it would sag i had about 1.5in lift without the overload leaf in.
    Now I have ome HD dakar pack an it ride is good also a little stiff but nothing unbearable. Loaded up no sag an it rides like a dream.
  8. Sep 10, 2018 at 5:14 PM
    newbie taco
    Stock suspension.
  9. Sep 10, 2018 at 5:19 PM
    newbie taco
    Unfortunately it looks like I will need to replace the oem leafs. Anybody use the SD 4x4 3-leafs or another brand for complete direct replacements?
  10. Sep 11, 2018 at 5:24 AM
    GP_spence
    GP_spence Well-Known Member
    AL
    2013 DCSB TRD Off-Road 4x4
    From what I've seen on here General Spring KC has some good options for 3 leaf and 4 leaf (HD) packs
  11. Sep 11, 2018 at 11:47 AM
    outxider
    outxider Never stop exploring. Rest in Paradise Big Bro.
    Sang
    East Bay, CA
    06 DCSB 4x4
    A few mods here and there and counting....
    It would be cheaper if you look for TSB leaf pack take offs on craigslist or the classifieds if you're gonna stay oem ride height.
  12. Sep 11, 2018 at 1:25 PM
    newbie taco
    I want a bit more lift.
  13. Sep 11, 2018 at 1:26 PM
    newbie taco
    thanks I will check them out. Would you happen to know if they will give more lift or retain the stock height?
  14. Sep 11, 2018 at 1:32 PM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Are you trying to lift all around (front and rear)? Goals besides lift? Hauling and towing capacity? Budget?
    The problem with Toyota leafs is that they're shit. I can't advise replacing shit with shit. Just like I can't advise adding a progressive leaf pack to shit as a band-aid. However, that solution is better than a single AAL, but the problem still remains; the Toyota leafs.
  15. Sep 11, 2018 at 1:39 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    TSB 4 pack leafs are not shit. Now if you ride on them for over 100k and then add 3 leaf AAL's to it I cannot and will not attest for longevity, but considering I rode for something around 25k on the 4 pack leafs then added 3 leaf AAL's (kept the overload), then beat the ever loving shit out of them off road and have made it to 100k and they still retain their arch and perform amazingly tells me that the leafs are not as shit as most people would be quick to accuse them of.
    Also, I apologize for the run on sentence.
    CableTec and outxider like this.
  16. Sep 11, 2018 at 2:59 PM
    Rd62
    Rd62 Well-Known Member
    2014 DCLB TRD Sport
    How much are should rear leaves have? My 2014 has 85000 on it. (I've had it for 10k). It obviously had a cap on it at some point before I bought it as there's a pigtail there for the third brake light. Truck rides fine though the leaves sit essentially flat. Thinking of adding some new 5100s and front and rear springs. Was looking at AALs from Headstrong but not sure if I should be looking for new leaf packs instead?
  17. Sep 11, 2018 at 3:04 PM
    geekhouse23
    If they're flat or negative arched, you should be looking to replace the whole pack. Otherwise you'd be adding a band-aid to the real issue
  18. Sep 24, 2018 at 5:32 PM
    CableTec
    CableTec Legend in my own mind
    J-ville and P-ville, FL
    2007 V6 PreRunner SR5 TRD
    See sig.....
    I can attest to the 4 leaf TSB not being crap. I had the TSB done for free at 28K. I now have 180K on the truck and they are still arched high and supporting any load I put in the bed of my Taco.
  19. Sep 24, 2018 at 5:39 PM
    Rd62
    2014 DCLB TRD Sport
    Are there good reference photos of good and bad? What I should look for?
  20. Sep 26, 2018 at 12:12 PM
    GP_spence
    AL
    Well look under your truck and check them out. Good leafs should have some arch to them, like a smiley face. Flat or frowning springs mean it's probably time to upgrade, especially if your bed sags when loaded. Depending on how you use your truck you might be able to add a leaf (AAL) but most folks on this forum agree that the stock leaf springs suck and should be replaced all together.
