How much strain will the bed rails on our Tacos take? Lateral strain, mainly.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by secher, Jul 5, 2024.
  1. Jul 5, 2024 at 6:32 PM
    secher
    secher [OP] Well-Known Member
    2015 OR v6 6MT
    I have an idea I'd like to try and I don't know if the bed rails will suspend 400# spread across 12" centers and both rails. It would end up with 33# pulling down and in every 12" on each railside.
    With the tailgate closed to provide stability, would the bed rails hold that much mass, and does anyone know the structural limits on those rails?
  2. Jul 5, 2024 at 6:39 PM
    BC Hunter
    BC Hunter Well-Known Member
    Kootenays, British Columbia
    2022 Black AC OR MT w/all TRD goodies
    TRD: Lift, Exhaust, Air Intake, Skid Plate & "Beadlock" wheels. Batman sticker. 255/85R16 Toyo MTs. Debadged. H9s.
    Page 178 of the 2022 Canadian Owner's Manual.
    "Do not exceed a total tensile load of 440 lb. (200 kg) per deck rail."
    deanosaurus and GilbertOz like this.
  3. Jul 5, 2024 at 6:49 PM
    secher
    2015 OR v6 6MT
    Oh, sweet! So not even a problem then; I won't be touching even half load. Thank you!
  4. Jul 5, 2024 at 6:50 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    You're better off pulling OUT on them, then down or up.
    The rails will twist. The closer you are to a rail mounting screw, the less it happens.
  5. Jul 5, 2024 at 6:51 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    Just keep in mind the bed itself is polymer. It's one thing to suspend weight statically from the rails, and another to suspend weight and to flex that weight repeatedly for some time.
    GilbertOz likes this.
  6. Jul 5, 2024 at 6:53 PM
    secher
    2015 OR v6 6MT
    Ah, the rails are not through to the metal bed itself? Sorry, I've onlh had my Tacoma for a few weeks and haven't been able to fully explore details yet.
  7. Jul 5, 2024 at 6:55 PM
    secher
    2015 OR v6 6MT
    Hmm.. good point.
    Once I have a solid test, I'll post up to 2nd Gen of teh project. I just don't want to talk about what it is because then I'll never do it.
  8. Jul 5, 2024 at 6:57 PM
    TnShooter
    Deogee
    STOCK
    You'll pull the D-Ring out of the rail, before the bed breaks.
    But you'll start to see a gap between the bed and rail before this happens.
  9. Jul 5, 2024 at 7:00 PM
    2015WhiteOR
    Gainesville TX
    The bed is not metal. Knock on it with your fist and look at it through the rear wheel wells. The entire "tub" is polymer.
  10. Jul 5, 2024 at 7:18 PM
    TacoTuesday1
    SD CA
  11. Jul 5, 2024 at 7:21 PM
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 84K miles
    FOX 2.5, Deavers, ARB, OTT, 4xInnovations
    A lot depends on your use case.
    "..the structural limits..." is a very broad umbrella. They're different in different directions, and in particular they're different depending on the dynamic loads they / the truck will be subject to regularly. Think "fatigue cycling."
    If this 400# of whatnot is going to be around town on paved roads it may be fine, even long term.
    If it's a truck that sees regular off-road use, depending on exactly what you have in mind it might not be all that good for the bed.
    No need to be mysterious in the design phase. Make some sketches, share them here, before you spend 10 or 20 hours and 100's or 1000's of dollars and end up with something that is... questionable as far as long term durability.
    2015WhiteOR likes this.
  12. Jul 7, 2024 at 7:06 AM
    secher
    2015 OR v6 6MT
    I wasn't being secretive; if I talk about it, I will end up not doing it. :).
    I think I have to skip it, though. I was going to suspend a sheet of 3/4 CDX from cables connected to brackets in the rails for use as an easily removable bedframe during good weather travel; without taking up significant space in the lower portion of the bed.
    Since the bed wall is fully plastic though, it won't work.
