How Much Tire Can I put.......
Discussion in '1st Gen. Tacomas (1995-2004)' started by BJO, May 23, 2009.
  1. May 23, 2009 at 9:08 AM
    BJO
    BJO [OP] New Member
    99 SR5
    I want to put taller, wider tires on my 1999 4wd Tacoma. It has the factory 15" wheels - I think they are 7" wide. How big can I reasonably go without a lift kit or new rims??
  2. May 23, 2009 at 9:11 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I belive you can fit some 32" talls tires on there without too much rubbing. Maybe a 32/11.50/15....
  3. May 23, 2009 at 10:47 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    10.50" tire is the widest you can run (technically) with a 7" wide rim.
    You can run 11.50" wide tire - but you will have to set your air pressure a little bit lower to ensure the tread wears evenly.
    I ran 32 x 11.50's M/T's on my stock rims (on my 96) and had to run air pressure around 26psi. I had 2" lift - no rubbing at all.
  4. May 24, 2009 at 5:22 PM
    savoy
    savoy tacoma 4 life
    Josh
    Fort mcmurray, Alberta
    06 Tacoma double cab black
    Pro comp 6" lift, afe intake, flowmaster duel exhaust, dick cepek 35" mt's, and black XD rims
    i have 31-10.50-15
    and they rub when the wheel is hard over .....i wouldn't go any larger
  5. May 24, 2009 at 6:24 PM
    BJO
    BJO [OP] New Member
    99 SR5
    DO they rub bad? I mean do they damage the tires or the truck? You don't have a lift kit right?
  6. May 24, 2009 at 6:26 PM
    savoy
    savoy tacoma 4 life
    Josh
    its not to bad of a rub ...no lift kit ....
  7. May 24, 2009 at 6:41 PM
    BJO
    BJO [OP] New Member
    99 SR5
    Dont want to keep buggin you, but it looks like you painted your wheels black - looks good. How did you get the paint to adhere?
  8. May 24, 2009 at 6:48 PM
    savoy
    savoy tacoma 4 life
    Josh
    your not bugging ....any who ...when i painted the rims, i washed them with soapy water to remove the dirt/grease... let them dry for a bit then taped the tire walls so i didn't get over spray...then sprayed them with wheel paint...wheel paint in more adhesive then normal paint.. one thing to be careful with is over spray ....do short sprays and about 6 to 8 inches away from your rims...just to avoid running paint
    ya so just use wheel paint and you'll be good to go
  9. May 24, 2009 at 6:55 PM
    BJO
    BJO [OP] New Member
    99 SR5
    Thanks man. I think Imay try painting the inside (textured) parts of the wheels - they're always covered in brake dust anyway. Your paint has stayed on ok?
  10. May 24, 2009 at 7:00 PM
    savoy
    savoy tacoma 4 life
    Josh
    oh ya no worrys the paint has stayed really well ...considering i've been out mudding a few times since and also use a pressure washer to clean the truck/tires ...and the paint stays just fine
