how much tire pressure
Discussion in 'Wheels & Tires' started by ilovemytaco, Nov 1, 2008.
  1. Nov 1, 2008 at 9:40 AM
    ilovemytaco
    ilovemytaco [OP] Well-Known Member
    i have a 08 tacoma 4dr 2wd with the stock rims and tires and i was wondering how much should my tire pressure be...i checked them and they all have about 28psi but when i look at the tire it says 50 psi max. so i was wondering how much is a good pressure to give a smoth ride and good gas mileage or is 28 enough?
    thanx
  2. Nov 1, 2008 at 10:11 AM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    I would say 32 or 34 PSI. 50 PSI is the absolute max tire pressure that the tire can sustain safely, so I wouldn't go that high. I'd say 32 or 34 would be a good balance for comfort and MPG. What does the little sticker say on the driver's side door jamb?
  3. Nov 1, 2008 at 10:56 AM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    The sticker says
    29 PSI front
    32 PSI back (I think)
    It's really all about personal preference.
  4. Nov 1, 2008 at 11:45 AM
    mws4ua
    mws4ua I'll try being nicer if you try being smarter.
    Birmingham
    2018 GMC Sierra SLT Z71 4x4... Yeah yeah, I know.
    You are correct.
    Open your driver's door and look at the sticker on the frame of the truck. 29/32 front/back is what it recommends. I run mine at 30-32 all the way around.
  5. Nov 1, 2008 at 1:45 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    In general...Lower pressure is softer ride with lower gas mileage. High you get...harder ride with better mpg response.
    Using the stock recommendations is a good place to start.
  6. Nov 1, 2008 at 3:59 PM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    Not really. Under-inflated tires can impact mileage because you're increasing the contact patch (more friction) but going over the recommended pressure doesn't do much to increase mileage because beyond the recommended pressure; you're not really reducing the contact patch size, just making the tire harder.
    Even at 10psi lower than recommended, you might only see a 0.5 mpg drop.
  7. Nov 1, 2008 at 4:05 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    This is true. The best way I have found to determine the propper psi for your tires, as everyones are different, is to make a chalk line across your tread, from the out side of the tire, inward. Then drive it 100 feet or so, and see how much of the line is left. Idealy, you want to have the chalk completely removed except the last 1/8". :)
  8. Nov 1, 2008 at 4:08 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    For the stock tires you get a recommended pressure-I haven't seen many swapped tires that come with a recco'd psi. They have a max..but that's the only number I remember seeing on the spec sheets.
    I'm all for the "You gotta try it out for yourself and find out what you like for a ride" method. After you like how the tires feel for your normal application-Make sure the pressure is still within specs for the tire.
    For this one- my last comment is most important- Use the stock recommendations for a starting point and then adjust from there.
  9. Nov 1, 2008 at 4:10 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Good method for finding the right pressure. You're so gall durn smart.
  10. Nov 1, 2008 at 4:13 PM
    Evil Monkey
    Robert
    Escondido, CA
    Original post:
    Good point though.
  11. Nov 1, 2008 at 4:15 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Yeah...I know...I read it.
    If you read my post you'd see that the last line says
    That's a starting place. The in general stuff can help the OP tailor his truck to his liking. so can chris's method. so can alot of other things....That's why the forum is here...to discuss.
  12. Nov 1, 2008 at 4:18 PM
    cmytacoma
    cmytacoma Well-Known Member
    Humboldt county NORCAL
    05 black DC LB sport
    Eclipse AVN 6620, Diamond audio 4.5" component in kicks, center channel with same mid and 2 tweets, infinity kappa perfect component 6.1 in front doors, kappa 6.1 coax in rear, sx900.4, fosgate power 1000, 06 L7 in ported box. BHLM, custom made sliders,
    I would have to agree with Brunes Here! He didn't say fill to 50 and you'll get 30 mpgs, he said running them softer the less mileage and harder=more which is a prety basic rule of thumb. I'm NOT saying that what you stated was incorrect but i think you're getting too technical on a pretty basic question.
  13. Nov 1, 2008 at 4:24 PM
    Ken Dawg
    Ken Dawg Well-Known Member
    EAST COAST
    08 Prerunner TRD Sport LB
    Tranny rebuilt 12/2016 at 142,500 Pioneer deh-p400ub head unit Alpine spr-69c fronts Alpine 17c rears. Rockford Fosgate 4 channel amp JL sub behind seat Upper console solder fix Recall: Rear leaf's 12/2016 To Do List: JVC KW-V820BT with Backup cam Zelwig Helper Spring Clazzio Dark Gray seat covers /heat Viper alarm w/ Starter Then drive to 250,000 miles!
    its a truck...not a mercedes
    i run them at max...do that with harley etc. also
    now a 3/4 ton 4x4 i will back off 5-8 lbs from max.
    this all said its really personal preference.
  14. Nov 1, 2008 at 4:31 PM
    Evil Monkey
    Robert
    Escondido, CA
    It's not correct though, so it's not a basic rule of thumb. Underinflating will impact mileage, inflating beyond the recommended pressure won't increase mileage. It may affect ride quality, but you won't boost mpg. And for the record, I said he did have a good point.
  15. Nov 1, 2008 at 4:32 PM
    Evil Monkey
    Robert
    Escondido, CA
    Motorcyles are different because they have a rounded tire. Inflating a motorcycle tire beyond the recommended pressure reduces the contact patch, and traction.
  16. Nov 1, 2008 at 4:34 PM
    Ken Dawg
    EAST COAST
    who is past the recommended tire pressure??:rolleyes:
  17. Nov 1, 2008 at 4:39 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    I came check this post to see if chris had filled yall in yet i see that he has thus I am out.
  18. Nov 1, 2008 at 4:40 PM
    Evil Monkey
    Robert
    Escondido, CA
    Didn't say you were. I said overinflating a mc tire does reduce the contact patch, as opposed to car/truck tires.
  19. Nov 3, 2008 at 12:17 PM
    Demoncleaner
    Demoncleaner Well-Known Member
    Upstate NY
    05 Dcab 6spd 4x4 TRD Sport w/Tow
    TRD exhaust Homemade bed mat & bed extender, front Drings, Short clutch throw, Summer: Stock 17's Winter: Blizzaks on 16' black steelies
    Just a note for those running much more pressure than the manual/door jam says. Besides the lesser contact patch, a few years ago I found running too high of pressure caused the middle of the tire to wear much quicker than the outsides. Keeping around the recommended psi, tire wears even, good traction, mpg is where it should be. Heavy loads I'll add a few more.
  20. Nov 3, 2008 at 12:23 PM
    futile
    futile Active Member
    Birmingham
    06 Dbl Cab 4x4 Sport
    Excellent idea. I've never heard of it before...
