how much tis too much
Discussion in 'Audio & Video' started by bailerc, Jun 7, 2011.
  1. Jun 7, 2011 at 10:45 PM
    bailerc
    bailerc [OP] Well-Known Member
    Cody
    Fayetteville, NC
    16' MGM Limited
  2. Jun 7, 2011 at 11:38 PM
    Carson
    Carson Well-Known Member
    Carson
    Modesto, California
    05 TRD Sport 4x4 SR5 V6
    Garage Fabbed +2 LT, FOA 2.5 RR w/ Comp Adj, 35 XMTs on Level 8s, 50T Spring Under w/ 13" Shackles, Elite Front Bumper, AP Rear, Retrofitted, Wicked Flow, Custom Roof Rack, Custom Sliders, Custom Scratches, 12" JL and an Audiopipe amp.
    There is never too much bump, and that thing will slam real hard... :D Besides, you can adjust the base level with the bass knob. As far as that amp, i am not sure of that brand, but yes that should push the sub just fine. Make sure to get an amp wiring kit!
  3. Jun 7, 2011 at 11:58 PM
    bailerc
    Cody
    Fayetteville, NC
    16' MGM Limited
    i actually already have the wiring to the back of my truck .. so it will be as simple as putting it in .. im currently running a infinity basslink T ... it will be a nice upgrade and free up space in the back
  4. Jun 8, 2011 at 12:35 AM
    Carson
    Carson
    Modesto, California
    That will be a nice upgrade, do you know what gauge the wire is that you have ran? I'm sure lots of other people will advise on the amp in the morning.
  5. Jun 8, 2011 at 1:51 AM
    bailerc
    Cody
    Fayetteville, NC
    16' MGM Limited
    i don't remember what gauge i ran , and i can't really look because it's quite a ways away, any idea of a minimum i should have ?
  6. Jun 8, 2011 at 4:51 AM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    That amp will NEVER make that amount of power. You'll have to trust me on this. Also, that Type X is a very inefficient sub that NEEDS a lot of power to reach it's potential. Why not get something more efficient?
  7. Jun 8, 2011 at 6:06 AM
    bailerc
    Cody
    Fayetteville, NC
    16' MGM Limited
    My internet sucks...
  8. Jun 8, 2011 at 6:06 AM
    bailerc
    Cody
    Fayetteville, NC
    16' MGM Limited
    after quite a bit of reading i think i'm going to go with the alpine MRP M-1000, would that be of a wiser choice ?
  9. Jun 8, 2011 at 1:27 PM
    Carson
    Carson
    Modesto, California
    As far as the wiring goes, 4 gauge would be the safest, for both hot and ground, along with an 80-100 amp fuse at the battery. Im pretty sure this is correct but wait for some experts to say...
  10. Jun 13, 2011 at 9:34 PM
    the arkitect
    the arkitect I will gladly pay you on Tuesday...
    Houston
    08 PreRunner SR5
    If you're running over 1000 watts RMS on your amp, I wouldn't run a 4 gauge cable more than 8'. Your good if you go from the battery through the firewall an mount the amp under the drivers seat, but if the amp is taller than 2.5" it won't fit under there. Plan and measure out EVERYTHING before you spend your hard earned money. If ItalynStalion says look at another option for a sub, listen to him. Dude knows what he's talking about.
  11. Jun 13, 2011 at 9:37 PM
    Crownedcustoms
    Crownedcustoms Well-Known Member
    Gilbert
    07 dc 4x4 fox coilovers 20's & toyo mudders
    Fox coil-overs, Fox shocks, 20" Helo wheels, blowthough, Jl and focal system, Grillcraft grill, Toyo Mud terrains
    X2
  12. Jun 13, 2011 at 9:38 PM
    Crownedcustoms
    Gilbert
    Much better choice! :)
