How much to change a pre-runner to 4-wheel drive?
Discussion in '1st Gen. Tacomas (1995-2004)' started by yfz450admirer, Sep 24, 2010.
  1. Sep 24, 2010 at 8:41 PM
    yfz450admirer
    yfz450admirer [OP] Well-Known Member
    98 TRD 4x4
    How much would this transformation cost?
  2. Sep 24, 2010 at 9:39 PM
    crazyasu45
    crazyasu45 Well-Known Member
    Canada
    2013 MGM DCLB 4X4 TRD SPORT
    3" SUSPENSION LIFT
    Too much...way cheaper just to go out and buy a 4WD...
  3. Sep 24, 2010 at 9:40 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    A guy on TTORA did it for $1000.00....Plan on about $1500.00
  4. Sep 24, 2010 at 9:42 PM
    Lentsnh
    Lentsnh Well-Known Member
    2007 Hummer H3 Tactical Edition
    None yet- Future: HIDs, Tinted tails, LED interior lights,
    IFS or SA?
  5. Sep 24, 2010 at 9:48 PM
    pittim
    pittim mittip backwards
    Mk7 TDI
    Permanent CEL
    There was a guy selling a complete IFS front end for like $400 a little while ago.
  6. Sep 24, 2010 at 9:48 PM
    AlexXx
    AlexXx Well-Known Member
    Louisiana
    99 taco
    All-Pro 3" Rear kit, Camburg Coilovers, 1" RB BL, 285/75/16's, and rear Lock Right locker Collecting 4wd parts to convert.
    Man I hate when people say just get a 4wd. Dude search to find good deals, I got all my parts under $1000 then sell your parts you don't have any use for anymore and get some money back.
  7. Sep 24, 2010 at 9:50 PM
    joes06tacoma
    Joe
    Central Coast, CA
    If you have to pay for labor, forget it and trade for a 4x4. Otherwise, just start collecting parts. Not too many guys on this board doing solid axle swaps, but if you can find someone doing that swap, then you can buy their ifs and use the parts you need. Then you need a trans and transfercase.
    As others have mentioned, there should be write ups available on the internet somewhere. If it were me, I would collect the parts, do the front end setup one weekend, swap trannies and add transfercase and drivelines the next weekend.
    My understanding is that it's all bolt on on the tacomas. Not the same thing, but my uncle converted an F150 from 4x2 to 4x4. If he didn't tell me, I would never know. Do it yourself and get the details right, you will have bragging rights then.
  8. Sep 24, 2010 at 9:52 PM
    AlexXx
    Louisiana
    99 taco
    Listen to this man! But yes there's so many threads about the swap, just search and you will receive.
  9. Sep 25, 2010 at 1:08 AM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
  10. Sep 25, 2010 at 4:30 AM
    supremetaco2
    supremetaco2 Well-Known Member
    concrete jungle, oahu
    04inacoma
    +hp, lifted, lights, dif breather mod, debadged, shorty antenna...
    no need u can wheel your prerunner just as hard as a 4x4. dont listen to other people. only thing is you might get stuck more often. more of a challenge right? haha.
  11. Sep 25, 2010 at 4:56 AM
    Idrivetoys
    Idrivetoys Well-Known Member
    Yuma AZ
    I need a 4 door DC 4x4
    +1 i love my prerunner, but if your needs are a 4WD for other reasons then try to find parts first.
  12. Sep 25, 2010 at 6:10 AM
    Barnone
    Barnone Guest
    How much would it cost to change a 4x4 to a Pre-runner?
  13. Sep 25, 2010 at 6:17 AM
    DaytonLax14
    DaytonLax14 Well-Known Member
    Corey
    Ohio
    98 extended cab TRD Off Road
    How handy does someone have to be to do this?
  14. Sep 25, 2010 at 6:18 AM
    DaytonLax14
    Corey
    Ohio
    it's free. you just turn off the 4wd;)
  15. Sep 25, 2010 at 8:04 AM
    crazyasu45
    Canada
    3" SUSPENSION LIFT
  16. Sep 25, 2010 at 8:09 AM
    pittim
    Mk7 TDI
    Permanent CEL
    well if you sell everything off to some 2wd that wants 4wd, its probably gonna cost you -$$$ :p
  17. Sep 25, 2010 at 8:22 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    www.Autotrader.com
    It will be way easier and save you the headache and cash. Plus if you do the swap, it will never be 100% right. There will always be some little thing that bothers you because you had to "rig it".
    Believe me I have modded cars in the past and learned that there is a point where you have to stop and just start with a different platform.
  18. Sep 25, 2010 at 8:35 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The Prerunner and 4x4 are the same chasis. ALl he would have to do is add the stuff to make it a 4x4. Even better, is the first gens had a manual T-case. IIRC, there is a block off for the T-case shifter, that can be easilly cut, and removed for the stick.
  19. Sep 25, 2010 at 8:53 AM
    macgyver
    Brad
    Canton, GA
    Everything should be easy in theory... Until you start tearing things apart. Then you realize you have the wrong part or you forgot a part and your truck is your daily driver you don't have a truck for a few days..then days turn into weeks..and weeks turn into months.
  20. Sep 25, 2010 at 8:55 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    If you dont know what your doing, then yes. However, there are tons of online resorces that can help. In many cases, buying the same truck, but 4x4, that has been wrecked, can make for an easy swap. Then you can sell the rest of whats left to recoup some cash.
