How much $$$ to fix my suspension?
Discussion in '1st Gen. Tacomas (1995-2004)' started by cmf21, May 19, 2011.
  1. May 19, 2011 at 8:02 AM
    cmf21
    cmf21 [OP] Well-Known Member
    Arizona
    04 4x4 dbl cab trd
    I have an opportunity to refinance my auto loan. My suspension is shot all the way around on my 04 dbl trd 4x4. I figure I might as well do this as long as I have this opportunity otherwise it'll never get done. I want to do this as right as I can without braking the bank too much. My tires right now are ok and will have to wait.
    Would $1700 for parts, etc be to much or to little or should I ask for $2500 instead to place it safe. I'm trying to get a feel for what need and I'm guessing I need at least $1100 for a bundled kit such as the ome.
  2. May 19, 2011 at 8:05 AM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    just pick a good lift out with new UCAs and go from there...OME is a great lift!
  3. May 19, 2011 at 8:06 AM
    beefcake
    beefcake J-rob
    J-Rob
    Central California
    98 4WD V6
    Debadged,Deck Plate mod, Helix throttle body spacer, magnaflow two chamber, smoked corner marker lamps, cb radio, smoked headlights, grillcraft mesh grill, URD short throw shifter, ultagauge, billstein 5100 front struts, spidertrax 1.25 spacers on all four
    $1700 should be fine, unless you plan on putting bigger tires on once you have your lift. I have all of things ordered for my truck Including Leaf springs, bump stops, Rear shocks, extended brake lines, UCA's, toytec coils, basically everything but the front bilstein shocks and i am around $1500 and $250 of that was just to ship parts
  4. May 19, 2011 at 1:18 PM
    tsab916
    tsab916 Well-Known Member
    Sacramento
    02 DC 4x4
    I just paid 1399.00 shipped for my toytec ULK...the tw discout code pays for shipping
    I got the 650 coils with the complete leaf spring instead of the aal
    the 650 coils are the biggest coil they got and its recommened that your suppose to have an extra 200lbs up front. I have nothing up front and it rides just fine for me...not too stiff and not too soft.
