How much to have shave off 2006 Tacoma 4.0 heads?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wonderbread, Jul 26, 2025.
  1. Jul 26, 2025 at 12:27 PM
    wonderbread
    wonderbread [OP] Well-Known Member
    Steven
    PNW
    08 Tacoma TRD 4.0 4x4 auto w Loc
    Bilstein 5100 adjustable w TRD Exhaust
    I got a head gasket leak. How much can be safely shaved off these heads in case it’s warped? TY
  2. Jul 26, 2025 at 1:39 PM
    zguy1
    zguy1 Well-Known Member
    Midwest
    None, according to the SM I have. "If warpage is greater than the maximum, replace the cylinder head."
    Maximum warpage:
    0.10 mm (0.0039 in.)
    By resurfacing the heads and removing the distance between the camshafts and crankshaft you risk having VVTI issues.
    Now have folks resurfaced theirs heads? Yes, I am one of them. Per the shop I went to, my heads were out .003". The shop took off .0035" from RH and .0034" from the LH. I have about 40k miles on my head gasket repair. I suppose in hindsight, mine were still within the allowable range.
    Others suggest using thicker head gaskets, like Cometic, but I honestly don't know much about that.
  3. Jul 26, 2025 at 1:41 PM
    IvanhoeTaco
    IvanhoeTaco Well-Known Member
    Eastern NC
    2005 Supercharged Converted Prerunner
    Total Chaos 3.5 LT, King Coilovers, 35x11.5r17 on Falcon T2, ADV 4 inch fiberglass, 4.88 gears, FJ cruiser transfer case, 4 runner front diff, Cab mount relocate, archive hangers, shackles, king 2.5x14 rear shocks, icon rxt leaf springs, king hydro bumps
    Had a buddy who had the block decked. Because that was the actual issue. He had to make up difference with headgasket.
    This was on a 1grfe 4runner
    wonderbread[OP] likes this.
  4. Jul 26, 2025 at 1:43 PM
    Bishop84
    Bishop84 Well-Known Member
    Read up on issues after machining heads.
    Head gaskets fail on these trucks but the heads rarely warp.
    I haven't machined a cylinder head on a 1GR yet and have never had one leak after gasket replacement.
    But milling the head seems to throw the timing off of these engines.
    zguy1, wonderbread[OP] and winkel like this.
  5. Jul 26, 2025 at 6:34 PM
    wonderbread
    Steven
    PNW
    I am definitely hoping that this 2006’s heads aren’t warped? It hasn’t overheated as long as I’ve owned it as far as I know
  6. Jul 26, 2025 at 7:49 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
  7. Jul 26, 2025 at 9:00 PM
    wonderbread
    Steven
    PNW
  8. Jul 26, 2025 at 9:31 PM
    TnShooter
    Deogee
    STOCK
    They are as good as OEM.
    But they don't make them in OEM thickness.
    If you don't shave the head, go OEM.
    If you do, go Cometic.
  9. Jul 27, 2025 at 7:38 AM
    tacokarl
    tacokarl Big Blue
    Karl
    Connecticut
    2008 Pre-Runner SR5 DCLB 1GR-FE
    Cometic is a highly reputable brand. As mentioned, if the cylinder head is shaved, a thicker head gasket is required to compensate for the material removed, which is why the Cometic gasket is designed with added thickness.
  10. Jul 27, 2025 at 7:48 AM
    wonderbread
    Steven
    PNW
    I have to take the heads into a machine shop to see if they are warped first… so I guess I buy the gaskets afterwards then right? TY
  11. Jul 27, 2025 at 7:51 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Or you just go get you a good straight edge and feeler gauges and check it yourself.
  12. Jul 27, 2025 at 1:25 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Don't buy anything until you know the condition of the heads
