how much trim work to fit 285/75/17
Discussion in 'Wheels & Tires' started by jace1905, Apr 14, 2015.
  1. Apr 14, 2015 at 8:36 PM
    jace1905
    jace1905 [OP] Active Member
    james
    East Tennessee
    2020 Tacoma 4 dr TRD off road
    Bilstein 5100s Method 305 wheels 17x8
    Just installed a toytec lift with camburg UCAS and ome dakaar rear springs. Was wondering how much trimming would need to be done to run 285/75/17 tires on 17x8 wheels? Or should I stick with 285/70/17 for tire size..looking at nitro Terra grapplers for tires. Thanks in advance
  2. Apr 14, 2015 at 8:52 PM
    Sje1124
    Sje1124 Well-Known Member
    Sean
    Louisiana
    2010 DBL Cab TRD OR 4x4
    Just a few
    Cmc and some of the bottom of the front fender would have to be cut for sure.
  3. Apr 15, 2015 at 3:51 AM
    jace1905
    james
    East Tennessee
    Thanks for the insight.
  4. Apr 15, 2015 at 3:54 AM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    What 285/75's are you planning on running. I wish there where more tires in that size.
  5. Apr 15, 2015 at 3:56 AM
    jace1905
    james
    East Tennessee
    Was looking at the nitro Terra grapplers on 17x8 wheels with a 4.5 inch backspace. If its too much cutting I will go with 285/70 17
  6. Apr 15, 2015 at 3:56 AM
    jace1905
    james
    East Tennessee
  7. Apr 15, 2015 at 4:05 AM
    Large
    Large Red
    A lot ... that's a 34" tire.
    CMC
    Cut fenders
    Flatten pinch weld
    hammer the piss out of the fender well
  8. Apr 15, 2015 at 4:15 AM
    Telkins88
    Telkins88 Well-Known Member
    Ohio
    2021 TRD Sport 4x4 Premium
    Goodyear Ultraterrain AT 265/70r17 1” front and rear lift
    IMO I would go with 285/70-17 even with those you will have to trim some. I think 285/75-17 would be a pain to make fit.
  9. Apr 15, 2015 at 6:18 AM
    Sje1124
    Sean
    Louisiana
    Just a few
    Of your going with the 285/75/17s might as well go up to a 35 lol
  10. Apr 15, 2015 at 6:34 AM
    ArcherTaco
    ArcherTaco Well-Known Member
    Riley
    Greeley/Windsor, CO
    '13 DCLB TRD Sport
    Toy-Tec Kit, Tool box fit to bed, Dipped badges, cab lights, running boards, Flowmaster exhaust
    I'm running 285/70/17 and you can make it work. With the 285/75/17 as mentioned above you will need to do the cab mount chop and if you intend to go over anything bigger than a speed bump you will need to trim your fenders some. I've bashed mine with 33's. Just FYI
  11. Apr 15, 2015 at 1:37 PM
    jace1905
    james
    East Tennessee
    thanks guys i think i will stick with 285/70/17 then seems as though there is more work for the 75's than gain for me
  12. Apr 19, 2015 at 9:42 AM
    jace1905
    james
    East Tennessee
    just an update for those interested in the future i went with 285/70/17 and still having to do a little inner fender work also removed the front mudflaps
  13. Apr 19, 2015 at 3:58 PM
    Telkins88
    Ohio
    Looks good!
  14. Apr 19, 2015 at 7:14 PM
    jace1905
    james
    East Tennessee
    thanks its a start many more upgrades planned as finances allow
  15. Apr 21, 2015 at 5:41 PM
    mainewoodsballer
    mainewoodsballer YESSAHBUD...heyut
    Ol' Waltah
    Maine
    2015 DCLB TRD Sport (Pyrite Mica)
    Check out my Build to See!
