How much water is a concerning amount of water?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by cbugg13, Oct 4, 2021.
  1. Oct 4, 2021 at 12:17 PM
    cbugg13
    cbugg13 [OP] Active Member
    New Hampshire
    2021 TRD OR 4x4
    How much water drains under everyone's truck after finishing a ~2hr drive? I assumed it was from the AC previously, but have not had AC on for weeks now that's fall, and I am still seeing a significant pool of water under the front of my truck when I get home (2-3 ft across, 1 foot wide). Bringing it in soon for 10k service so I'll ask them as well, but just curious if others have similar experiences.
    I have it on my radar to research the AC drain mod, but I'm super not mechanical so it's taking a bit
  2. Oct 4, 2021 at 12:23 PM
    SpeySquatch
    2016 TRD OR DCSB
    I have a 2016 TRD OR and have never seen a puddle, not even a few drops. My truck has been garaged since I got it…nothing on the ground ever.
    I assume it wouldn’t be from rain or snow collecting under the truck…?
    I would be concerned and tell the service guy
  3. Oct 4, 2021 at 12:31 PM
    buckmaster243
    buckmaster243 I don’t know what to do with my hands
    Buck
    Washington
    2013 DCLB, 2023 4runner
    Mine drips probably a one foot puddle. Your defrost runs the AC also I believe.
  4. Oct 4, 2021 at 12:31 PM
    cbugg13
    New Hampshire
    2021 TRD OR 4x4
    Initially I thought maybe it was from melting snow (bought the truck in December), then rain (hooray spring!), and then AC since we went from 40 and raining to 90+ degrees in the span of days this year.
    This is the most I have driven in consistently dry conditions without the AC- so hearing it's not normal at least validates my concern enough to ask. My prior cars- many of which were absolute junkers, also didn't have this happen this much... but this is my first *new* truck so I kept trying to justify/talk myself out of it. I'll ask the techs about it, and someday I'll learn to trust my gut...
  5. Oct 4, 2021 at 12:32 PM
    Ol' Sarge
    Ol' Sarge Active Member
    Andrew
    WIsconsin
    2017 Tacoma TRD Sport
    I've read elsewhere on here that the AC doesn't even have to run in order for it to make enough condensation to drip. As far as how much, I've usually seen a puddle about the size of the palm of my hand. If you check where your AC drain is, it might be running down the frame laterally, but still doesn't seem enough to warrant a 2-3 foot puddle. You can't see where the fluid is coming from?
  6. Nov 5, 2021 at 7:24 PM
    cbugg13
    New Hampshire
    2021 TRD OR 4x4
    Limited data to report on still, but I *did* have the de-fog on the last long trip that resulted in significant water. I'm hopeful that's all it is.
  7. Nov 5, 2021 at 7:38 PM
    Clearwater Bill
    Billy
    Largo Florida
    De fog is running the AC. Enough humidity in the air, and you'll have puddles.
    High humidity, efficient system and free flowing drain makes big puddles
    To verify, all you have to do is slide under the passenger side around the firewall and look where the water is coming from. That hose nipple you will find is from your evaporator case inside.
    ktbell444 and whatstcp like this.
  8. Nov 5, 2021 at 7:39 PM
    cryptolyme
    cryptolyme Well-Known Member
    Virginia
    2021 SR Access Cab 4x4 2.7L
    mine drips all the time
  9. Nov 6, 2021 at 6:00 AM
    Nirango kid
    Nirango kid Well-Known Member
    Gilles
    Ontario
    2021 Tacoma TRD Sport Premium in Barcelona Red
    Mine has dripped a few times on the passenger side but it is very small amount of about 1tbsp splattered on the floor mat.
    I do some on the ground after being parked I guess it is normal from the AC drain hose but inside that is another question.
  10. Nov 6, 2021 at 6:02 AM
    ryanvar42
    ryanvar42 Well-Known Member
    2024 Silverado Trailboss
    None
    a tiny little puddle prob as wide as the bottom of a butter container
  11. Nov 6, 2021 at 6:07 AM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    How much water depends on climate. Here on the wet coast, I expect to see a decent amount but it is tough to tell with all the rain. In Arizona where it is dry and hot, I wouldn't expect too much. Also, expect to see more when you have a truck full of passengers and the windows up. Humidity plays the largest part. These systems do cycle the A/C to pull moisture out of the air to prevent window fogging.
