How much weight are you putting in bed for snow
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 127.0.0.1, Nov 13, 2014.
  1. Nov 13, 2014 at 12:47 PM
    #41
    Jefes Taco
    Jefes Taco Well-Known Member
    Denver, CO
    14' DCLB TRD Sport supercharged
    Wouldn't placing the sandbags near the tailgate multiply the weight compared to placing them over the axel due to leverage?
  2. Nov 13, 2014 at 12:49 PM
    #42
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    Theory is, it'll cause you to slide more if not over the axle.
  3. Nov 13, 2014 at 12:51 PM
    #43
    Idaholandho
    Idaholandho The other white meat
    3 Now - 2022 Trail Edition, 2015 TRD 4x4 and a 2006 SR5 4x4
    2015 Tacoma, Magnuson Supercharger, Bully Dog Flash and GT, Safari Snorkel, Toytec BOSS 2.5 Coil Over Front, Toytec BOSS Aluma 2.5 Rear, Toytec 10 Leaf Pack, Stainless Brake Lines, Icon UCA's, CBI Reverse Adj Shackle Mounts, CBI Ubolt Flip Kit, Timbren Bump Stops, CBI Bushmaster 2.0 Front Bumper w/ Warn M8000S Winch and SR2 Rigid Flood Lights, CBI Bushmaster 2.0 Rear Swingout Bumper, Rigid SR2 backup lights and Dual RotopaX / Fuel/First Aid Pack, CBI Rock Sliders, CBI Full Skids and CBI Rear Diff Armor, BAMF LCA Skids, FrontRunner Outfitters Slimline II Roof Rack w/ Rigid SR2 40" Combo Light Bar, Rock lights, Rigid pods in Bed Rack, Intelligent Battery System w/ Dual NorthStar batteries, Spod Power Distribution, illuminated switch panel in sunglasses holder, Viar Extreme Duty On-Board Air w/ 2.5 Gallon Tank under bed, Air 2 Air Sys, Magnaflow Exhaust, Fuel Off Road Trophy Wheels, 285/75/17 Toyo Open Country R/T, Diff breather mod, FX-R BHLM Demon Eye headlights, Esuse LED Fog Kit, Pelfreybilt Camera Relocation mount, Pelfreybilt ax/shovel bed mount, Debadged, tint, a 2006 Tacoma SR5 and a 2022 Trail Edition
    OP, as well as weight in the bed, consider airing down your tires for + surface area contact.
  4. Nov 13, 2014 at 12:54 PM
    #44
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    I'm assuming this question is for 2x4 vehicles only. I do just fine with nothing in the back with 4x4. I'm amazed on how well it goes when turning Auto LSD on (VSC off).
  5. Nov 13, 2014 at 1:23 PM
    #45
    adrstout
    adrstout Well-Known Member
    Adam
    Indiana
    '12 4cyl SR5 4x4
    2.5" lift, 265/75r16 Cooper AT3, All Pro Front Skid, KBVoodoo bed rack, a bunch of other random stuff
    I've never done it though I don't doubt it could be effective. If I was 2wd, I'd be all over doing that.
    I have a heavy as steel topper now so I think that will suffice. I air my tires down if we get snow. Never had a problem.
  6. Nov 13, 2014 at 1:39 PM
    #46
    Lostsheep
    Lostsheep Well-Known Member
    NorCal
    2015 6spd 4x4 OR
    6112s and 5160 , Dakars , Superbumps x4 , u-bolt flip , All Pro Skids (hacked and raised) , 265/70R17 KO2s, SEMA wheels, couple of machined things here and there
    Perhaps the greatest advantage to using actual sandbags is that once you get stuck you have a bunch of sand to throw under your tires ;)
  7. Nov 13, 2014 at 1:42 PM
    #47
    Mademan925
    Mademan925 Senor Taco
    Nick
    Discovery Bay, CA
    2014 4x4 TRD OFFROAD DCSB
    enough to go over stuff
    x2
  8. Nov 13, 2014 at 1:44 PM
    #48
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    None.
    Adding weigh reduces traction because there is more load to move.
    Use 4wd in snow, that's what it's for.
    Also having the front heavier is good for stability since the heavy part wants to be in front.
  9. Nov 13, 2014 at 1:46 PM
    #49
    127.0.0.1
    127.0.0.1 [OP] AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    I have 4x4 turd OR and have no issues
    but the arse end is light and may add weight to maximize 2wd mode or 2wd mode with autolsd
    ...I am getting the '200lbs is about right' vibe and I do know a source of that weight.
    stone chips or a few bags of birdseed my GF wants to feed to all the critters that live in trees.
    cripes, she is 100lbs and often drags 70lbs bags of sunflower seeds into the rec room after a shopping run....
    crap I could just bag a few squirrels and stick them in the bed they sure are FAT in my 'hood
  10. Nov 13, 2014 at 1:48 PM
    #50
    AeroCooper
    AeroCooper Half the strength of ten (microscopic men)
    NH
    2018 Barcelona Access Cab Off Road
    Remote start, tailgate inserts, nifty key fob case, Husky X-Act floor liners, AVS vent shades, bed mat, MX4 Tonneau cover, Tyger step rails
    I've never added any weight, other than whatever snow falls in the bed, and never had an issue just using 4WD as needed.
  11. Nov 13, 2014 at 1:49 PM
    #51
    romeo
    romeo Wombat
    Luis
    Lacey, Wa
    Silver 4x4 DC Sport
    Whatever the bedrack from Jlee (B.A.M.F) weighs is the amount that will be added.
  12. Nov 13, 2014 at 1:49 PM
    #52
    127.0.0.1
    /etc/hosts
    FWIW...with vehicle slipping and handling, and a pickup truck... the front want to stay put due to inertia, and the light arse wants to come up front and say hello...
  13. Nov 13, 2014 at 1:53 PM
    #53
    wdb
    wdb intolerance intolerant
    Dave
    the perimeter
    plain jane
    Hella 4000 eurobeams, Amp Bed Step, IamMrYo mirror riser, Wet Okoles, HomerTaco satoshi, retrofit intermittent wipers & backup camera
    You can have a whole discussion just about the advantages and disadvantages of that tactic. Short version: sometimes it's good, sometimes it's bad.
  14. Nov 13, 2014 at 1:55 PM
    #54
    Stuligan
    Stuligan Well-Known Member
    Ontario, Canada
    05 TRD OR 4L V6 6spd
    Billy 5100 level lift (0.85" front) White/Amber DRL/Signal Kit GTA Car kit for AUX/IPod Satoshi Grill 2x 20" LED Light bars behind grill HID headlights LED Taillgihts LED interior lights.
    I've always put weight in the back of any rear drive front engine vehicles I've used, a couple hundred pounds weight won't effect my fuel economy anymore than running around in 4x4 the whole winter. I was amazed with the Taco how big a difference the 4x4 made last winter.
    To those complaining about braking distance... There's snow, you can't stop on a dime anyways, have an extra passenger worth of weight on board shouldn't make a difference to how you SHOULD be driving in those conditions.
    The extra weight also makes the truck a little easier to manage the weight transfer to go drifting around everything that isn't a stop light.
  15. Nov 13, 2014 at 1:57 PM
    #55
    Stuligan
    Ontario, Canada
    Note: my truck is also a 2005 and doesn't traction or stability control.
  16. Nov 13, 2014 at 2:23 PM
    #56
    MTLTaco
    MTLTaco Well-Known Member
    Montreal
    09 Double Cab TRD
    My ARE LSII, bed mat seem to work fine for me
  17. Nov 13, 2014 at 2:31 PM
    #57
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Does everybody that's worried that adding 200lbs to the vehicle weight is going to have such a huge effect on stopping on snow refuse to take passengers in the snow too ?
  18. Nov 13, 2014 at 2:39 PM
    #58
    Stuligan
    Ontario, Canada
    This only works for SNOW. As soon as things get slushy you want the narrowest contact patch you can get. Otherwise it's not different than driving through a puddle, you get a whole lot of hydro-planing and not a whole lot of control.
  19. Nov 13, 2014 at 2:40 PM
    #59
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    I go with my leer canopy, bed mat, and 4 50 pounds bags of sand. 100 pounds next to each wheel. Doesn't effect fuel economy at all that is noticeable and measureable.
  20. Nov 13, 2014 at 2:50 PM
    #60
    shr133
    shr133 Well-Known Member
    Muskego, WI
    2010 V6 Sport
    K & N filter, 275 70 17 Cooper AT3, OME Nitrocharger shocks, 884 Springs, Dakar leafs.
    I live in WI and never add weight. Now with cooper AT3s even better... 4 x 4 DCSB... But this year I may go out and play more and run up north so I may through a couple bags of salt in the back...
