How much weight can bed rails hold?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Aw9d, Jan 6, 2012.
  1. Jan 6, 2012 at 1:14 PM
    Aw9d
    Aw9d [OP] That one guy
    Az
  2. Jan 6, 2012 at 1:24 PM
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    200 lbs i doubt you could overload the ammo can enough to break the bed rail
  3. Jan 6, 2012 at 1:47 PM
    Aw9d
    Az
    Perfect thank you very much!
  4. Jan 6, 2012 at 1:54 PM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Is it just attached at the slider thing? If the weight was distributed evenly along that rail I am sure it can hold 200 lbs easy. If most of the weight is at the bottom of that can it may become a little wobbly through the ruff stuff
  5. Jan 6, 2012 at 1:56 PM
    Scubasteve4533
    Scubasteve4533 Well-Known Member
    Ohio
    11 TRD OR
    5100 @ 1.75, tsb rear springs with 5100. anytime fogs, rear diff breather, 50 cal ammo boxes on bed rails
    I have 25ft of 3/8 chain as well as the winch adapters for my highlift in an ammo box mounted like that and it doesnt budge. I have a 1/2 carrier bolt in each bed rail with a nut inside the box and a lock on the front.
  6. Jan 6, 2012 at 2:09 PM
    Aw9d
    Az
    Exactly the same thing I was thinking on how to mount it. I don't think I'd have more than 75lbs max at any giving time, more so 20-30lbs. Just didn't want to drill holes in my ammo can and mount it before I knew it could hold some decent weight.
