How much weight can our tailgate handle?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TinoTaco, Aug 8, 2017.
  1. Aug 8, 2017 at 9:09 AM
    TinoTaco
    TinoTaco [OP] Well-Known Member
    Nanaimo
    2017 TRD DCSB Off-Road - White
    Odd question I know, but I'd rather ask before damaging...
    I've got some crates to transport soon and they're going to be in the 500+ lbs range. Seen as it'll probably be just me and maybe the wife trying to load them, I'm going to be having to tip the crate onto the tailgate, then deadlift it up and slide it into the bed.
    It shouldn't be an issue having 500+ lbs pivoting on the edge of the tailgate eh? I could see the tailgate skin getting dinged up, but I may just put a piece of plywood down to protect it.
  2. Aug 8, 2017 at 9:13 AM
    excorcist
    excorcist Well-Known Member
    Reno, NV
    '06 dcsb, '86 pickup, '89 runner
    plywood, or maybe some 2x6s under the crates would be a good idea..., I wouldnt put 500 pounds on the edge of the tailgate without support.. people have bent them by loading motorcycles that weigh less.
    over60, TinoTaco[OP] and Benzdriver81 like this.
  3. Aug 8, 2017 at 9:14 AM
    AFMurse2014
    AFMurse2014 Death Can Wait
    Devin
    San Antonio
    2016 MGM Double Cab TRD OFF ROAD 6 Speed MANUAL
    Freedom, American flags and ISIS blood Morimoto 35w 5500k HID/ LED highs from TRS. RCI expo rack Core Short throw shifter, hypertech speedo recalibrator. Rear seat molle panel. OVT. PnP 2LM. C4 Hybrid Bumper w/ amber BD squadron pods. 33 pizza cutters. T9 radio
    my tailgate made a cracking noise when my 180 pound body stepped from the edge of the bed down to the tailgate. The plastic got all kinds of chewed up when I was unloading washing machines.... So I'd use caution.
  4. Aug 8, 2017 at 9:15 AM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    Usually a tailgate is max rated in the 300 to 500lb range from what I've seen in the past. I would not put 500lbs on my tailgate, I can damn sure tell you that!
  5. Aug 8, 2017 at 9:24 AM
    Benzdriver81
    Benzdriver81 Making it fool-proof will just make a better fool
    Kevin
    PNW
    05 DCLB Sport
    That's what the PO of my truck did.
  6. Aug 8, 2017 at 9:32 AM
    James_Bond
    James_Bond Well-Known Member
    Southern California
    '16 TRD Sport DCLB
    All stock
    there's some vendors out here that sell both a top tail cover and a whole plate the replaces the inner composite side of the tail gate. Even the Top tail cover will make your tail gate alot more rigid.
    Bravisimo likes this.
  7. Aug 8, 2017 at 9:33 AM
    smitty99
    Scottsdale
    I'm more concerned with the stress placed on that little "safety cable" and the hinges. When you place all of that mass on the edge of the tailgate, it will exert a lot of force on those components.
    Bolsillos5624 and Spare Parts like this.
  8. Aug 8, 2017 at 9:36 AM
    James_Bond
    Southern California
    '16 TRD Sport DCLB
    All stock
  9. Aug 8, 2017 at 9:37 AM
    James_Bond
    Southern California
    '16 TRD Sport DCLB
    All stock
    I have seen other vendors with other solutions.
  10. Aug 8, 2017 at 9:38 AM
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    I would rent a trailer from your local U-Haul to put the crates in.
    boston23, UrbanT@co, wadeo and 7 others like this.
  11. Aug 8, 2017 at 9:39 AM
    TinoTaco
    Nanaimo
    Good call, don't know why that hadn't crossed my mind.
    duly noted. Probably taking the tailgate off and using atv ramps would probably be appreciated by my lower back anyways
    Thx guys
    VanGo3, tcjacado, hiPSI and 4 others like this.
  12. Aug 8, 2017 at 9:40 AM
    TinoTaco
    Nanaimo
    any links/details?
    nm... I should have reloaded the page before that comment lol not used to quick responses like this! ha
  13. Aug 8, 2017 at 9:40 AM
    smitty99
    Scottsdale
    Last time I checked our tailgates only have one little wire cable to help load share. The photo there shows two cables which may bump up the max load bearing capacity of the tailgate (that truck looks like a full size). The support panel is good for protecting the tailgate from getting dented or taco'd -in from impact or pressure but it still does not add the amount of weight that the tailgate can bear.
    Lawfarin and Humboldt_Homie like this.
  14. Aug 8, 2017 at 9:41 AM
    LEXICON
    LEXICON born where the prairies meet the rockies
    Courtney
    Canada
    2016DCLBBLACKTACOMATRDSPORT4X4PREMIUM
    Nothing worthy
    I'd remove it for safer/easier loading
  15. Aug 8, 2017 at 9:42 AM
    James_Bond
    Southern California
    '16 TRD Sport DCLB
    All stock
    That's a Tacoma.
  16. Aug 8, 2017 at 9:49 AM
    SRQ_TACO16
    SRQ_TACO16 Well-Known Member
    David
    Sarasota, FL
    2008 Tacoma
    3rd gen SR5 wheels
    I've done 500ish pounds multiple times on this truck. we unload machines pivoting them off the tailgate on two metal rails. It has left marks, but no damage. Feels very sketchy compared to Silverados we used to have. Last time I heard some odd noises and haven't tried it again since. We've bent two Tundra tailgates doing the same thing. I'd say once or twice should be fine. Just not built heavy enough...
  17. Aug 8, 2017 at 9:54 AM
    James_Bond
    Southern California
    '16 TRD Sport DCLB
    All stock
    Now that I recall, I loaded a used washer and dryer in my bed and I did load them on most of the tailgate, then I (250lbs) stepped onto the tailgate and then moved it well into the bed.
  18. Aug 8, 2017 at 9:57 AM
    smitty99
    Scottsdale
    A washer and dryer weighs 500lbs? Most of them I've ever moved probably aren't even pushing 150lbs.
    20tacoma17 likes this.
  19. Aug 8, 2017 at 10:00 AM
    James_Bond
    Southern California
    '16 TRD Sport DCLB
    All stock
    I never said they weighed 500lbs. Why are you putting words in my mouth?
  20. Aug 8, 2017 at 10:07 AM
    Bootleg_Flyer
    Bootleg_Flyer Well-Known Member
    Virginia
    17 DCSB Off-Road
    I recently had three adults sitting across my tailgate (~500 lbs) for maybe 45 mins. No deformation or other issues that I'm aware of.
    hiPSI, VA SOFTACO and James_Bond like this.
