How much weight can the tie downs support?
Discussion in '1st Gen. Tacomas (1995-2004)' started by pittim, Mar 10, 2009.
  1. Mar 10, 2009 at 9:58 PM
    pittim
    pittim [OP] mittip backwards
    Pink slider.
    Say there is a load of 350 pounds distributed to all 4 tie downs. Will they be able to handle it or will shit start bending?
  2. Mar 11, 2009 at 2:59 AM
    hardtaco
    hardtaco Well-Known Member
    Sarasota, FL
    08 PreRunner DCSB
    I believe you will be fine.
  3. Mar 11, 2009 at 4:16 AM
    devilsalmostfree
    devilsalmostfree Well-Known Member
    Carl
    Loudon, Tn
    99 Tacoma 4X4, 5 spd, 2.7 ltr
    Deck plate mod, intake silencer removed, AFE Pro Dry S Air Filter, debadged, Goodyear Duratracs 265/75R16. Flowmaster knock-off muffler!
    yeah i'ld say u'll be fine too, just if ur using rachet straps, dont over do it with them, thats when u'll start bending crap, ild think! just make them all taunt!
  4. Mar 11, 2009 at 7:04 AM
    pittim
    Pink slider.
    I'm not thinking of ratchet straps....I'm thinking of making a "hammock" for my truck.
    get some kind of outdoor fabric with 550 paracord along each edge. Each corner will then be attached to a carabeaner and then hooked into the corners.
  5. Mar 11, 2009 at 7:08 AM
    devilsalmostfree
    Carl
    Loudon, Tn
    oh, well u should be ok!
  6. Mar 11, 2009 at 7:13 AM
    chabro
    chabro Well-Known Member
    Houston
    2011 SR5 4x4 DC
    Hmmm hammock will be interesting. Those tie downs are for load holding not lifting. Essentially you will be using them for lifting. The moment placed on each tie down will be more like 200# each in a fashion they were never meant to act in. Should still work but watch closely the first time you use it.
  7. Mar 11, 2009 at 1:47 PM
    pittim
    Pink slider.
    oh dear god dont talk about moments. i hate them.
    anyway, i see what you're saying about the tie downs are only really ment to handle loads in 2D, not 3D. If each support is designed to have a tensile strength of 200 pounds in two directions, I'd guess that they can handle 100 pounds in three directions.
    I guess I'll find out if this is true if I end up making it though haha!
