How much weight in bed before it is a problem w/ 3-leaf springs?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JKD, Dec 5, 2010.
  1. Dec 5, 2010 at 3:49 PM
    JKD
    JKD [OP] Well-Known Member
    I'm curious now, with the posters who swear that any weight at all in the bed of the truck makes it slam into the bump stops in normal driving.
    I've now driven around with an old refrigerator (~220 pounds) with no problem, and a washer/dryer set (~310 pounds) over gravel country roads with no problem. The rear end didn't squat noticeably with either load.
    I figure with the washer, dryer, passengers, accessories, and assorted cargo in my cab, I was probably at 800 pounds total payload. My '09 prerunner AC is rated at 1415 pounds payload capacity, so I was a bit over halfway there--with no noticeable suspension sag, bottoming out or other problems driving over a bumpy country gravel road at normal speeds.
    So, how much payload does it take before my three-leaf truck slams into the bump stops while driving normally?
  2. Dec 5, 2010 at 4:03 PM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
  3. Dec 5, 2010 at 4:06 PM
    Detective_Dan
    Detective_Dan "Place original and witty user title here"
    Colorado Springs
    2014 DCSB Beast / 2016 Yamaha FZ-07
    Pelfreybilt Front Plate Bumper, Brute Force Fab High Clearance Rear Bumper, Pelfreybilt Sliders, OME 886/Dakars, SCS F5's, 33" Ko2's, Cobra 75WXST/3' Firestik, oil catch can, aero turbine 2525, rear differential breather extension, bedmat, weathertech digital fit front/rear, BHLM, custom shiftknob (made by me),
    im pretty sure i just went blind
  4. Dec 5, 2010 at 4:09 PM
    Trap
    Trap Well-Known Member
    Indego Ink TRD OR
    Electric Tail Gate Lock, EZ Down + Cable Mod, Galvanized Underbody, DK 9000, CloudRider SS Grill insert. BakFlip HD, Cabin Air Filter mod, Alarm, Zero Rust !
  5. Dec 5, 2010 at 4:39 PM
    BRP27
    BRP27 When I grow up I want to be just like Me
    So far south in Texas my feet are in salt water
    04 4X4 Tacoma SR5
    3 in Ultimate ToyTec, set @ 2.5 in. AAL PINCH Weld Mod ( beat the pinch weld over inside the fender) Painted the pinch weld on bottom of cab Black Hi Lift Knock off
    I carried 1/2 cord of firewood 80mi @ 70mph in the bed today with no problems . Had some sag but it drove well, no bottoming out, no sway from the front end being light.
  6. Dec 5, 2010 at 4:45 PM
    Brunes
    Brunes abides.
    Rotorhead
    I loaded up my truk with my sport bike (~400#), tools/fluids (80#), camping gear (~100#) and my fat ass (~180#) and didn't have any issues. And the track I drove to was back in the woods a ways.
  7. Dec 5, 2010 at 4:47 PM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    I've had about 1,000 lbs (including myself) in my 5 lugger without issue. She sagged a little bit, but I still had plenty of room before the bump stops.
  8. Dec 5, 2010 at 4:48 PM
    RJA102
    RJA102 Member
    Los Angeles, Ca
    2010 Sport
    I only had about 200 pounds in the bed before my bump stops hit the frame. I was going over very uneven ice and snow though.
  9. Dec 5, 2010 at 4:50 PM
    swendling12
    swendling12 Well-Known Member
    Sean
    Nebraska
    09 Reg Cab SR5 4 cyl 5spd 4x4
    I've had my topper, recovery gear, and camping equipment which was ~600-800 lbs. I was within an inch of the bumpstops, and hit them many times traveling the trails back to the campsite.
  10. Dec 5, 2010 at 4:52 PM
    SOSHeloPilot
    SOSHeloPilot Well-Known Member
    U.S.A.
    2016 SR5, AC/LB, 4x2, V6, Auto, w/Tow, SiriusXM, Stock
    UnderCover SE, Bed Mat, Tint, Weather Techs & DashGoPro
    Before TSB, 20 - 25 bags of black velvet mulch and I was on the bump stops ... maybe ~450 lbs. (before TSB).
    After TSB ... no problems with much heavier loads ... I really liked this TSB.
  11. Dec 5, 2010 at 4:56 PM
    SmilingMark
    SmilingMark Well-Known Member
    Mark
    Ogden, UT
    2010 Access Cab
    Color matched grill w/ grillcraft. BHLM and Morimoto Mini HID's Debadged.
    Classic example of why it's a TSB and not a recall. Some have a problem, some don't. If you don't... dig your truck and keep on truckin'! If you do, get it swapped.
  12. Dec 5, 2010 at 5:01 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    Banned :eek:
  13. Dec 5, 2010 at 5:08 PM
    fletch aka
    Gary
    Left Coast
    I have been loaded with enough camping gear for a week plus my gear box, floor jack, tools, strap etc. and never had a problem. Grape Vine in California has it's bumps and dips so I feel I gave it a good test. If I felt I needed the TSB I would after it or at least get a AAL. :notsure:
  14. Dec 5, 2010 at 5:10 PM
    05RedTaco
    05RedTaco Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    I have had Yamaha Wolverine ATV & Yamaha Blaster ATV with three guys in the cab in my 5 lugger. It sagged but got up to 75mph just fine...
  15. Dec 5, 2010 at 5:15 PM
    joes06tacoma
    Joe
    Central Coast, CA
    1,000 lbs or so is when mine starts bottoming out over bumps. Not really a problem for me. Might be an issue if I was going off-road with that kind of load though.
  16. Dec 5, 2010 at 5:23 PM
    SOSHeloPilot
    U.S.A.
    LMAO at the cat poster and the captions ... :D
  17. Dec 5, 2010 at 5:28 PM
    Quakee
    Quakee Well-Known Member
    Eddie
    (LA) Tujunga, CA
    2010 TRD Off-Road 4x4
    Toytec ultimate lift kit, Total Chaos UCAs, spidertrax spacers, mudflaps removed, 4wd badge where "prerunner" usually goes, wicked flow 13" muffler, sound ordnance b-8pt sub-woofer.
  18. Dec 5, 2010 at 5:29 PM
    Taco.Tim
    Taco.Tim Well-Known Member
    Tim
    Georgia
    2010 Buhlue Access Cab 2WD
    Looking!
    Loaded the bed up to the rails, about 2/3 of the way back with firewood, and it had just under an inch of clearance to the bump stops. Rode pretty nice too, but I didn't have to go on dirt roads with it.
    Tim
  19. Dec 5, 2010 at 5:36 PM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    Mine was loaded for a vacation trip across country, not over 300 lbs in bed and she rode horribly. Bounced off bump stops and real light in the front - wind had me all over the road. Same trip next year after tsb, 1000 times better. Wind didn't bother me, did not hit bump stops.
    I took pics of the bump stops before the tsb was done and there was definite wear.
  20. Dec 5, 2010 at 5:40 PM
    fletch aka
    Gary
    Left Coast
    I wonder if it has anything to do with how often you carry a load. I only carry a load a couple of times a year, maybe my springs don't have as much abuse??
