How Much Weight to Ballance your 265/75/16 Duratracs?
Discussion in 'Wheels & Tires' started by woodsbuggy3, Apr 13, 2010.
  1. Apr 13, 2010 at 2:41 PM
    woodsbuggy3
    woodsbuggy3 [OP] Member
    NE Ohio
    09 Sport 4x4
    I recently purchased a set of 265/75/16 duratrac's, I made sure to purchase them from a place that does the RFV ballancing, my problem is there is a vibration between 50-60mph. I took them back to be re-ballanced and I think they are actually worse now. Seems to be a shitload of weight on these things and wanted to see how much weight it is taking others to ballance thier 265/75/16 Duratracs. Have a feeling I have a bad set or something but wanted to get opinions here first before fighting the tire shop. Listed below is the total ammount of weight on each tire, they are dual plane bllanced so some of the weight is on the front and some is on the back of the rim.
    FR - 19oz
    FL - 20.5oz
    BR - 18.5oz
    BL - 18.5oz
  2. Apr 13, 2010 at 2:46 PM
    hendooman
    hendooman The Stroker Ace
    Jeff
    KC
    2009 Tacoma OR (SOLD); 2015 TRD PRO 4Runner
    I cannot give you weight ideas, but I have heard others say they are hard to get balanced. If they cant get them perfect I would get different tires...I wouldnt put up with that vibration.
    Did you do this in-conjunction with a lift? Or were you vibe free before the new tires?
  3. Apr 13, 2010 at 2:56 PM
    woodsbuggy3
    NE Ohio
    09 Sport 4x4
    I did put them on shorlty after installing 5100's @ 2.5" but I rolled around for probably about 500 miles after the lift with the OE 265/65/17's with no virbrations.
    Over 1 pound of weight per tire just seems crazy to me, I know the tire shop is going to say its becasue they are large aggressive tires but in reality there really not that large or aggressive.
  4. Apr 13, 2010 at 2:57 PM
    The End
    The End Support our troops!
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    2.5 King RR in front, LR ucs' s, 2.0 King RR rear, B.A.M.F shock mounts, ATO shackle flip, 4X sliders, ARB front bumper with XRC8, CBI hc rear, weathertechs, Leer cap, Thule rack, ubolt flip, etc.
    Does it ride smooth now?
  5. Apr 13, 2010 at 2:57 PM
    The End
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    I have 30-31 oz. on my front two right now.
  6. Apr 13, 2010 at 2:58 PM
    The End
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    Each.
  7. Apr 13, 2010 at 3:07 PM
    woodsbuggy3
    NE Ohio
    09 Sport 4x4
    Its smooth everywhere but 50-60mph, I live out in the country and all our roads around here are 55mph:rolleyes:
    30oz Wow, that is alot of weight! Those are Duratrac's your running?
  8. Apr 13, 2010 at 3:08 PM
    Brunes
    Brunes abides.
    Rotorhead
    That seems like a lot- but what other people have is irrelevant. Small differences in the rims and tires from rig to rig will make plenty of difference in the amount of weight used.
    You just gotta keep working with it.
  9. Apr 13, 2010 at 3:12 PM
    The End
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    No I got BFG KM2's. But I work at a tire shop and I have some of the "heaviest" wheels I've seen. But I have to do the stick on inside weights and that makes it a little worse. My trucks rides as smooth as glass though.
  10. Apr 13, 2010 at 3:13 PM
    The End
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    Ask them to pro match them. How many miles do you have on them?
  11. Apr 13, 2010 at 3:16 PM
    woodsbuggy3
    NE Ohio
    09 Sport 4x4
    What's Pro Match?
    They have about 1000 miles on them.
  12. Apr 13, 2010 at 3:20 PM
    The End
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    You have to have a good balancer to do it. It takes the lighest part of the tire and the lightest part of the rim and puts them in the best spot. Sometimes it works sometimes it doesn't do anything. You could also try rotating them.
    A lot of the time it's just that the tire is "out of round" and will fix itself.
  13. Apr 13, 2010 at 3:24 PM
    EL TACOROJO
    EL TACOROJO SNAPPIN NECKS AND CASHIN CHECKS.
    BURRY
    south mills NORCAK
    03 dblcab prerunner sr5 v6
    smoked taillights,smoked front turnsignals,smoked 3rd brake light,black badges,black roof rack,removed mud flaps,debadged, camburg 2.5 coilovers,camburg uca's, cobra 25 cb, 4ft firestick ant, dust light/bed lights , 4 hellas on the front
    could always run sand bags inside the tires . when the wheel spins up the sand will go to the spot that needs the weight . it wont matter if the the rims and tires are swapped from truck to truck its still gonna do it . i have the same size tire on factory rimms and i have a vibe still after rebalancing them twice
  14. Apr 13, 2010 at 3:27 PM
    The End
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    Those sandbags are called Magnum balancing, they do nothing at all.
  15. Apr 13, 2010 at 3:36 PM
    woodsbuggy3
    NE Ohio
    09 Sport 4x4
    Cool, thanks for the help. I guess I will just have to go talk to them again. Suppossedly they have a Hunter GPS 9700.
    I have a 94 Explorer with 33" BFG M/T's, I had dyna bead put in them but I've never really been impressed with it, I dont think they put enough in or something, anything over 70 has a serious vibration. Its was disapointing becasue I really like the idea of an active wheel ballance.
  16. Apr 13, 2010 at 3:38 PM
    EL TACOROJO
    BURRY
    south mills NORCAK
    sorry forgot what it was called . i talked to one guy said it worked for him . but im not a big fan of stickin shit in my tires not even fix a flat that is some nasty shit
  17. Apr 13, 2010 at 3:43 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Or....have them rotate the tires 180degrees on the machine and spin them again.
    Or, you could do some research on EQUAL tire balancing. Looks like white suger granuals.
    We used it on our jeep 35 x 12.50 x 15 on steal wheels. They ran awesome even on the highway at 70mph (never dared go beyond that in a lifted Jeep).
    They've gotta put the right amount in, or else it won't balance right.
  18. Apr 13, 2010 at 3:59 PM
    The End
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    Tried to patch a tire today that had fix a flat in it and it ate the inner liner to shit.
  19. Apr 13, 2010 at 4:01 PM
    The End
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    You have to keep working on it. If they are a good shop they will help you out. I have guys that are so picky that it makes me want to shoot myself because they are never happen. But when we do make them happy, they are loyal for life and they spread the word.
  20. May 30, 2010 at 9:32 AM
    korny351
    korny351 Well-Known Member
    Stockton, CA
    07 DCLB SR5 4X4
    I'm pretty much a newbie around here, but that kind of weight on a tire sounds ridiculous. I've read on more than one forum that the stock wheels on our trucks are lug-centric NOT hub-centric. As such they cannot be balanced properly w/o a bolt-up adapter. I forget the name of the piece. If your tire shop didn't use this adapter it could account for the problematic balancing and excessive weights. Might be something to look into.
