How much weight?
Discussion in 'Technical Chat' started by Do58, Mar 25, 2018.
  1. Mar 25, 2018 at 3:06 PM
    Do58
    Do58 [OP] Well-Known Member
    2015 white tacoma limited
    Quick question.... first truck I’ve owned and really don’t use at a truck for hauling other than groceries lol. I have a 2015 Tacoma limited 2wd prerunner and looking at redoing my landscape in the front of my house. Question it.... anyone have an idea of how much weight/lbs. I can have in the bed of the truck before being concerned? Needing to haul moss rock boulders, sod, dirt/mulch etc.... thanks in advance
  2. Mar 26, 2018 at 8:05 PM
    TOMB
    TOMB Well-Known Member
    Tom
    Newington Ct. 06111
    2013 Access cab Sport -super white
    Changed all drain plugs to Dimple Magnetic plugs UNI filter on air pump
    You should have a chart showing what capacities your truck is able to carry in your owner's manual good luck
    TOMB
  3. Mar 27, 2018 at 7:55 AM
    hladun
    hladun Well-Known Member
    Alberta
    Tacoma
    You'll find it's surprisingly little. The manual gives total weights so if you have 3 X 250 lb friends with you you might reach the limit with a few hundred lbs in the box. With only a driver it's around 1,000 lbs but with rocks, gravel, cement etc. that's a surprisingly small amount. I was at my limit with one garbage can full of cement. But then......
  4. Mar 28, 2018 at 12:07 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Rule of thumb if the bed is sitting on the tires it most likely to much weight !!
    Have the place your buying from deliver it saves much wear and tear and frustration
