How much wheel travel with 3" lift?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by drsus, May 1, 2012.
  1. May 1, 2012 at 10:48 AM
    drsus
    drsus [OP] Well-Known Member
    Los Angeles, CA
    4Runner TRDpro
    stock
    I tried doing a search.
    What kind of wheel travel are you guys seeing from 3" lifts and how much more out of extended travel coil over like icons/fox ext travel units?
  2. May 1, 2012 at 10:54 AM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    standard 3'' yeilds the same as stock, with the ratio of up travel vs down travel changing slightly to give you the new ride height.
    extended travels give you just under an inch of extra travel. assuming you use an aftermarket upper control arm.
  3. May 1, 2012 at 11:02 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    :thumbsup:
  4. May 1, 2012 at 11:11 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Half true. the Light racing arms have more travel than required for ET coilovers, however I can't speak for the camburg ball joint arms.
  5. May 1, 2012 at 6:03 PM
    drsus
    Los Angeles, CA
    4Runner TRDpro
    stock
    so how much travel we talking ?
    8"? 10"?
  6. May 1, 2012 at 6:14 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    i couldn't tell ya. only way to know 100% without someone else coming in here with your exact setup is to take the spring off the shock, put the shock back in, and cycle the suspension
    just trying to cover all of the bases.
