How much will the feel of my truck change?
Discussion in 'Suspension' started by JackedTaco, Jun 4, 2009.
  1. Jun 4, 2009 at 11:31 AM
    JackedTaco
    JackedTaco [OP] Well-Known Member
    Johnny
    USA, Earth...
    07 Access Cab TRD Off Road
    Weathertech Mats, Thule rack custom install on bed caps. Foglite anytime mod. K&N air filter. Rear leaf TSB. Tinted passenger windows. TRD CAt Back exhaust. Bilstein 5100 front shocks at 1.75".
    Hi guys, Have a 07 access cab off road and its time to start the mods!!:)
    My question is, I am looking to put a 3 inch lift (toytec) and am wondering, I like the way my truck drives now, how much can I expect it to change with a three inch lift. I am looking at spacers up front and AAL in the rear.
    Thanks guys!
  2. Jun 4, 2009 at 12:05 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    Well, I know for a fact that a spacer lift will make it stiffer, and not smooth. Like if you went with a OME coil lift, or coilovers.
    just my 2cts. :)
  3. Jun 4, 2009 at 12:32 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Depends on the type of spacer....IN coil spacers preload the springs and lift the truck, with some increase to the stiffness of the ride. TOP spacers just add height to the set up without messing with springs. They shouldn't have a major effect on the ride.
    Check out the Bilstein 5100 shocks with an AAL in the rear if you have a budget...you can get lift and a good ride...plus they are better than the stock shocks.
  4. Jun 4, 2009 at 12:59 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    Dont do the spacers!
  5. Jun 4, 2009 at 1:04 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    I would also avoid the spacer lift. If you actually wheel it that is. If it is just for looks I honestly don't think it would make you ride that much different. I have a block in the rear of my truck for my lift and haven't experienced any of the stiffness or axle wrap.
  6. Jun 4, 2009 at 1:15 PM
    jrobson
    jrobson Well-Known Member
    Mobile, Alabama
    09 DC 4x4
    Ultimate lift kit, LR UCA's, Bi-xenon 8000K headlights, Xenon 8000K foglites, (4) KC slimlites on N-Fab light bar, Extang trifecta toneau cover
    I used their Ultimate kit with the TSB AAL and if I was rating mine on a 100% factory ride I would give it 95%.
  7. Jun 4, 2009 at 2:36 PM
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
    Kings, AP 3" leaf pack, timbrens front and rear, TC UCA's, pro comp 7189's, baja ATZ's, CBI sliders and rear, relentless front, dynomax catback
    I'm researching pretty much the same setup you have, did you get the TSB done and the TSB AAL, or just get the TSB AAL with no TSB?
  8. Jun 4, 2009 at 6:48 PM
    JackedTaco
    Johnny
    USA, Earth...
    Thanks guys, should I opt for the Ultimate lift kit then? OR go the Bilstein 5100's route with AAL instead.
    Thanks in advance, kinda a newb at this...
  9. Nov 16, 2009 at 7:20 PM
    Chicago Bob
    Chicago Bob New Member
    Bob
    Orther
    1998 Tacomagold short bed
    Flow Master, K&N fiilter
    Hey Guys, you seem like experts here on this forum. I have a question about shocks. I am not into lifting my 98 Tacoma Extra cab, but I do want to change the shocks on my truck. I have a set of Bilsteins for the rear from a TRD pre runner, will they work on a non pre runner? I want to change my rear shocks for a more stable ride, Will the Bilsteins or Tokico's work without modification? The bolts on my rear shocks look smaller than the rubber bushings on the Bilsteins. Any help would be appreciated. It the metal bushing the same diameter as the rubber bushings that came with the shocks? The Bilsteins look the same, but I am not sure if they will fit. Thanks in advance for your help. You can e-mail me at lyonhart49@hotmail.com. Thanks again guys. I can see where I can learn a lot about my truck here!!! P.S. My Tacoma is an SR-5 if that makes any difference.
    Chicago Bob.:)
  10. Nov 16, 2009 at 7:39 PM
    BigBawlzTaco
    BigBawlzTaco Well-Known Member
    2019 Toyota Tacoma SR
    I wanna know too :rolleyes:
  11. Nov 16, 2009 at 7:42 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    If your truck is a 5 lug (5 lugs on the wheels), the shocks from a 4x4 or Prerunner wont fit. And welocme to TW! :)
  12. Nov 16, 2009 at 7:51 PM
    MMazz365
    MMazz365 Well-Known Member
    Michael
    NY
    TRD Off Road
    -flowmaster dual side exit exhaust -3 inch lift -cb radio -scanner -DTRL's -Fogs Anytime -Truxedo Soft Tonnahu Cover -eyelids -grillcraft upper and lower -fogs behind the grill
    Ive had my truck for like a month. a guy at a lift kit store near me said if i got a 2inch leveling kit i wouldnt notice the difference in the ride at all. i forget the brand though
  13. Nov 16, 2009 at 7:52 PM
    Chicago Bob
    Bob
    Orther
    Thanks Chris 4X4 for your help. I need to pop of one of the wheel covers, but I have a feeling I have a 5 lug pattern, if so, I am stuck with 2 sets of shocks that won't fit my truck. What I am looking for is a smooth ride with a more stable feel, do you have any suggestions on shocks? Thanks again for your help. Let me know what you think, Thanks Bro.
    Chicago Bob!!
  14. Nov 16, 2009 at 8:04 PM
    Chicago Bob
    Bob
    Orther
    If anyone has a suggestion for a good shock that will give my extra cab a smoother and more stable ride, please let me know. I value your opinions. I do love my Tacoma. Thanks Guys.
    C.B.
  15. Nov 16, 2009 at 8:17 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I have heard good things about the Monroe Sensatrac shocks on the 2 wheel drive trucks. And a friend of mine ran the KYB Gasajust on his truck and liked those.
  16. Nov 16, 2009 at 8:22 PM
    Chicago Bob
    Bob
    Orther
    Chris 4X4,
    I know my truck has the Monroe sensa tracks on it now, they are possibly worn and may need to be replaced. I like the idea of the KYB Gas adjust shocks. They may be the answer for me. I love my Tacoma, it fits me like a glove. Thanks again Chris 4X4.
    C.B.
  17. Nov 16, 2009 at 8:24 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Glad to help. :)
  18. Nov 20, 2011 at 6:13 AM
    Jeffrey
    Jeffrey New Member
    Jeffrey
    Warminster Pa
    06 tacoma accsess debadged
    2 1/2 blocks on front,add a leaf rear,slightly larger Lt265/75r16 tires, nerf bars
    I love the ride and the handling of my 06 access cab, it is a grocery getter I don't want to get it muddy or scratch it. I went with 2 1/2 top spacer in front and aal in the rear, fairly easy to install without having to change anything else like brake lines. It still handles as well as it did before and has a nice firm but still comfortable ride, gave me a 3 inch higher lift and with largest tire that will fit the stock rims it has a nice tuff look to it. As a side note make sure whoever is mounting tires on stock rims knows to break the beads and remove the tire pressure monitors before removing or mounting tires. The guy where I bought my tires did not and broke the monitor on the first one. This cost them $150 for the monitor plus $80 to have it reprogrammed at the dealership. Dont think they made much on me that day even though I bought 5 tires (yes I replaced the spare which was brand new) so it would match.
