How much will the lighter hood/bed material affect overall durability?
Discussion in '4th Gen. Tacomas (2024+)' started by Mix 99.3, Dec 11, 2023.
  1. Dec 11, 2023 at 6:36 PM
    Mix 99.3
    Mix 99.3 [OP] Well-Known Member
    I've watched a few review videos of the new '24 model and they talk about the hood being lighter and the bed, liner, and tailgate all being much lighter than previous gens. That's probably nice for fuel economy but how will it affect durability? I'm kind of concerned about denting the bed, or what it will be like in a crash.
    :itllbuffout:
  2. Dec 11, 2023 at 6:42 PM
    JB_TN
    JB_TN Well-Known Member
    JB
    Tennessee
    2024 Bronze Oxide TRD OR
    Ah....just get that spray liner option and it will be all good. :D It will be fine regardless of the changes.
    maxmk8 likes this.
  3. Dec 11, 2023 at 6:45 PM
    GBR
    GBR Well-Known Member
    19 TRD OR
    I remember people freaking out about the F150 going aluminum. Somehow they still sell those pop cans to this day despite the naysayers.
    taco terror likes this.
  4. Dec 12, 2023 at 1:21 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    This summer, I had to replace a fender on my truck due to off-road damage. The replacement fender was lighter than the bubble wrap it came in. Toyota has been thinning down on the steel it uses for years for weight reduction. A switch to thicker aluminum may be a good thing.
    The Jeep Wrangler had aluminum body panels since the JL's introduction in 2018. It's been holding up well.
    Junkhead likes this.
  5. Dec 12, 2023 at 1:38 PM
    545 Well-Known Member
    2015 Access Cab
    The bed is glass fiber reinforced now, so it certainly could be lighter and just as strong, or even stronger. Or it could be weaker if they screwed the design up. Nobody really knows for now
  6. Dec 12, 2023 at 1:46 PM
    orangeblueorangeblue
    orangeblueorangeblue Member
    Composite beds on the 3G are pretty sturdy. Takes major abuse to bust through, and more resistant to minor dings than aluminum. And it won’t corrode.
  7. Dec 12, 2023 at 6:37 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
  8. Dec 15, 2023 at 11:37 AM
    myn75
    myn75 Well-Known Member
    Nor Cal
    2021 TRD Off-Road 4x4 DCSB, 1996 4runner SR5 V6 4x4 auto
    ARB OME BP-51 2”, TJM sliders, AT3Ws, Diode Dynamics SS42"
    lol are all those panels load bearing surfaces? i dont think so. will you be loading the hood full of cargo on a daily basis? i dont think so. have you seen how easily the STEEL 22 gauge body panels on the tacoma bend? which by the way on the Boeing 777-200 the thickness of the soft aluminum sheet metal is a whopping .040 inch thick. which is responsible for holding back 9.1 PSI of cabin pressure at cruising altitude which equates to about more than 1,300 POUNDS PER SQUARE FOOT. Not to mention pretty much everything else on that behemoth of an airplane is also aluminum, (steel, titanium, other stronger metals reserved for where its needed). So for automakers to employ the use of lighter materials in areas that could use it is of no concern to durability at all.
  9. Dec 15, 2023 at 11:58 AM
    OpeCity
    OpeCity Well-Known Member
    Long Beach, CA
    The 1300lb/sq ft is a tension figure. Aircraft are very susceptible to compression damage. So while I’m sure the aluminum parts will be fine, this comparison doesn’t really make sense
    coolrunnings82 likes this.
  10. Dec 15, 2023 at 2:10 PM
    myn75
    Nor Cal
    Agreed yield and compression figures probably make more sense. But automotive body panels are under no stresses at all which makes the original question pointless
  11. Dec 15, 2023 at 2:32 PM
    OpeCity
    Long Beach, CA
    They will be when they get dented. That’s usually the issue people are worried about
