how much???
Discussion in 'Audio & Video' started by pinktaco808, Apr 19, 2011.
  1. Apr 19, 2011 at 10:48 PM
    pinktaco808
    pinktaco808 [OP] Hot Steppa
    how much would i need to sound deaden my whole single cab tacoma???
    i seen this 8-24x27 sheets of scosche for 300
  2. Apr 19, 2011 at 11:46 PM
    DevL
    DevL Well-Known Member
    You mean vibration dampening? Cause that is different than sound deadening. About 6-8 sq feet per front door (12-16 total inside and out, 8 sq feet for the rear wall, and around 8 square feet for the roof. So 32 square feet of vibration dampener. You may have a little left over for misc small spots on the floor and kicks... truck has tons of floor deadening from factory. Thats for a deadener that requires more coverage due to thinness like Dynamat, Fatmat, Soche Accumat, or whatever. That Sosche Accumat is horribly overpriced for what you get. I dont know why you are obsessed with very particular off brands. Do you have a shop that sells it or are you reading about it somewhere?
    Thats just vibration dampener... it wont block external sound well. That requires closed cell foam and mass loaded vinyl... which will be about twice as expensive as the vibration dampener.
  3. Apr 20, 2011 at 6:33 AM
    mattg43
    mattg43 Well-Known Member
    Texas
    08 Prerunner SR5 DC
    SwingCase, driver side. PVC Bike rack. Aftermarket stereo.
  4. Apr 20, 2011 at 8:39 AM
    ThreeMan
    ThreeMan Opinions Vary...
    Oswego, NY
    08 4x4 V6 TRD DCLB
    Eibach Springs with Billstien 5100's - Full Katzkin Leather - Back Flip Roll-X bed cover - Custom Projector/Dual Halo Headlights by ambiguous - Eagle Eye LED tail lights - LED Light Bar Mounted in Bumper - Wade In-channel Vent Visors - K&N Filter - 20% on the fronts - Rear AAL TSB - 4 Tie Down Mod - Pop N Lock - Running Boards - Billet Grille - Weathertech Mats - LED Map and Dome Lights - Optima Yellow Top - Redline Elite Hood Struts - Tunes: Eclipse 7100 HU - Eclipse IPC-106 Interface - Audison LRX 5.1K - Hertz Mille MLK2 Components - JL 13TW5 - JL cables and wires - Fully Deadened with SDS products - Metra dash kit - Custom Sub Box and Amp Rack - Still Under Construction.
  5. Apr 20, 2011 at 12:31 PM
    pinktaco808
    yes a shop carries it.Also my main goal is to get rid of vibration from the sub and to get rid of the outside sound in the back of the single cab.... mainly around the vents.... i was reading you cant seal them up or can you???? if not then i guess would it be best to epoxy the plastic vent to the cab to stop the vibration from the vents vibrating and.....
