How much..
Discussion in '1st Gen. Tacomas (1995-2004)' started by LarrysWorld, Dec 25, 2011.
  1. Dec 25, 2011 at 4:12 PM
    LarrysWorld
    LarrysWorld [OP] 05 Taquito
    Larry
    Rialto, CA
    05 Tacoma Reg Cab
    2in front lift HIDs 15" Steelies
    How much of a difference does a new oil change and new spark plugs make?
    Need some help, my engine light keeps turning on and makes my gear change lag..
  2. Dec 25, 2011 at 4:14 PM
    Sunner
    Sunner Well-Known Member
    A pretty big difference if you have not done it in a while, you should always change these out as needed. I dont know how it would contribute to your transmission lagging on gear changes though, hopefully someone chimes in on that.
  3. Dec 25, 2011 at 4:17 PM
    LarrysWorld
    Larry
    Rialto, CA
    05 Tacoma Reg Cab
    Yeah ima change them soon! I've neer change the spark plugs since I've had the truck in 2009
  4. Dec 25, 2011 at 4:19 PM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    New motor oil should be done at least every 7500 miles or every 6 months which ever comes first that's the max Toyota recommends and that is for on road no towing just normal driving. Personally I do mine every 5k miles just so that it's easier to keep up with. Not sure what the rating on spark plugs are I think it's like every 50k but my plugs had over 100k when I changed them a few days ago, I don't thank that the previous owner took very good care of it but when I changed them I could immediately tell the difference just from the start because it started so much easier.
  5. Dec 25, 2011 at 4:22 PM
    LarrysWorld
    Larry
    Rialto, CA
    05 Tacoma Reg Cab
    Yeah I'm going to change them as soon as I get the chance too
  6. Dec 25, 2011 at 4:23 PM
    LarrysWorld
    Larry
    Rialto, CA
    05 Tacoma Reg Cab
    What kind of spark plugs would be good to put in?
  7. Dec 25, 2011 at 4:34 PM
    Warhorseforever
    Will
    Sand Lapper
    I'd go with the NGK's. Have yours ever been changed? Why I say NGK is because in the 115k miles that were on the old plugs then NGK plugs showed less wear than the Denso. If the plugs are the ones that came from the factory you will have NGK on the passenger bank and Denso on the drivers side bank. You can look in my gallery and see them side by side to do that click the little camera icon under my post count and info pane to the far left over there<<<<. They are a little pricier but imo worth it.
  8. Dec 25, 2011 at 4:38 PM
    Warhorseforever
    Will
    Sand Lapper
  9. Dec 25, 2011 at 4:39 PM
    shampoop
    shampoop Well-Known Member
    southwest WA
    08 tacoma extracab v6 auto trd offroad 4x4
    An oil change will not affect the way the car runs. New spark plugs will if the old ones are worn out.
  10. Dec 25, 2011 at 4:48 PM
    Warhorseforever
    Will
    Sand Lapper
    Right up until you spin a rod, drop a bearing, fry the rings, etc. :p
  11. Dec 26, 2011 at 12:22 AM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.7" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod, FPR Mod; JustDSM Tune via HPT MPVI2; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; aFe POWER Magnum FLOW Pro DRY S Air Filter; NSB-AGM27F Battery w/Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; Cooper Discoverer A/T3s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid & Cooling Panel; jsi's Locker Anytime, ramonortiz55's Always on Power Outlet Relay Mods & Crom's Speed Bleeder Mod; crashnburn80's Ultimate Headlight & Fog Light Upgrades (RallyLights Harnesses, Osram 85/80W H4 & Flösser 90W H11 Bulbs); mattgecko's Underhood Lighting; ND4's Fog Light Anytime Mod; mesojdm's Ultimate LED Dome and Map Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; 4Runner 4X4 & FJ Fog Light Switches; Husky Floor Liners; UltraGauge EM; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock; ARE Z-Series Cap, SolarGard Tint; BlendMounted Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Toyota's "1998 SUV and Truck: OM Supplement: Scheduled Maintenance" Guide, available from the Toyota Owner's Site and attached here, recommends oil changes every 5K miles for "most driving conditions" or 7.5K miles for "light, non-commercial duty for distances greater than five miles in temperate climates." Non-platinum/iridium spark plugs should be replaced every 30K miles or 24 months.
    That ^ is an EXCELLENT writeup on spark plugs - highly recommended reading. NGK BKR5EKB-11 or Denso K16TR11 are both good plugs for our engines.
