how necessary are the timbren bump stop for the u bolt flip kit?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ross123, Jan 21, 2012.
  1. Jan 21, 2012 at 4:32 PM
    ross123
    ross123 [OP] Well-Known Member
    fort bragg
    im about to buy the all pro ubolt flip kit. just wondering if the bump stops are worth the price?
  2. Jan 21, 2012 at 4:34 PM
    Large
    Large Red
    Depends if you think you will bottom your shock out. You can reuse the old bumpstops but you need to do a wee bit of modification. I would just go ahead and buy them, it's not worth the headache to me. Plenty of people run without bumpstops though..
  3. Jan 22, 2012 at 1:06 PM
    Oysterhead
    Oysterhead Well-Known Member
    Nashville
    '10 TRD OR
    Kings are king
    You only need them if you plan on flexing the crap out of your rear axle.
  4. Jan 22, 2012 at 1:43 PM
    HuntnTruk
    HuntnTruk Tacohead
    Kevin
    New York-not the City
    Indigo SR5 4x4
    I just cut my stock ones to fit and used a crappy welder to tack it to the plate
  5. Mar 4, 2012 at 1:21 AM
    wormfood
    wormfood Well-Known Member
    David
    Missouri
    2011 Tacoma TRD
    TRD Super Charger, UWS, All Pro expedition leaf spring pac, Icon stage 4 suspension, B.A.M.F LCA Skid plates, TC weld-on upper coil bucket tower gussets, TC weld-on spindle gussets with sway bar mounts. RTT, Thule Roof Rack, Thule, Leitner Active Cargo System, Warn Zeon 10 Winch, All Pro Front Bumper, All Pro Apex Sliders, Nilight - 60005C-A 20Inch 126W Spot Flood Combo Led Light Bar.
    They (Timbren) will get used eveytime your weight, towing or bed load bottoms you out, and depending on your trucks use, that could be often enough.
    They are an excellent upgrade for any towing or expedition trips. Check out the towing forum to learn more.
    An option are these from [​IMG]
    Watch it here.
