How "NOT" to do struts!
Discussion in 'Suspension' started by 4WD, Dec 15, 2011.
  1. Jan 28, 2013 at 7:54 AM
    #41
    Shipwreck
    Shipwreck Well-Known Member
    Johan
    Centennial CO
    2016 TRD Off Road Tacoma
    Stock
    I was doing the 5100 install on my 1st gen tundra a few years ago and got the spring compressor kit from some auto parts store and while inder tension the compressing shaft snapped and the whole coil and strut came appart in the vice. I clampped it down in the vice and put some heavy wet towels over it to decrease the velocity should something come apart and still i got my hand beat up pretty good and one of the steel blocks got lodged in a solid wood door leading into the house. My poor dog also got a hit in the ribs with the other end. Luckily all is good and well now but this seriously is not something to mess around with....
  2. Jan 28, 2013 at 8:16 AM
    #42
    4WD
    4WD [OP] cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    No Truck..well, maybe
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Well consider this, if it takes 600lbs of pressure to compress a 600lb coil 1" & most shocks/struts are preloaded up to 2", thats half a ton +/- of energy being released at once,,, you're luck you still have a head.........:eek::eek: glad alls good with you & your puppy
  3. Jan 28, 2013 at 10:07 AM
    #43
    Shipwreck
    Johan
    Centennial CO
    Stock
    Yes it was insane... never doing that again.
  4. Jan 28, 2013 at 11:11 AM
    #44
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    Harbor Freight 110v welder garage fab parts.
  5. Jan 28, 2013 at 11:50 AM
    #45
    4WD
    Doug
  6. May 12, 2013 at 10:01 AM
    #46
    04Tacomabuild
    04Tacomabuild Well-Known Member
    Reese
    Kenora, ON, Canada
    04 Tacoma TRD SR5 3.4l V6
    Toytec/Billistein coilovers, allpro leafs, OME greasable shackles, allpro ubolt flip kit, Billistein 5100's in rear.
    The worst part is that thats a toyota dealer..
  7. May 16, 2013 at 1:57 AM
    #47
    uncleART
    uncleART Well-Known Member
    Arty
    Bothell, WA
    13 MGM DCLB Sport
    DeBadged, Toyota Bedmat, TRD exhaust, Window tint 30%, DeFlapped the front, Bilstein 5100s, Toytec coil overs, Dakar leafs, LR UCAs, SwayBar relocate, TRD Offroad tow hook, RotoPax, Bora wheel spacers, DeFlapped the rear, Tailgate mod, CBI receiver shackle w/ Bolt Hitch Pin, {REMOVED-Goodyear Duratrac 285/70-17 LR-D & REMOVED-Procomp 7089 wheels}, Weathertech Floor Liners, Spare tire mod, UWS toolbox with Bolt Latch Retrofit, Rear Diff vent relocated, Blacked-out grill emblem, Toolbox Bedrail mod, Trailer Plug relocated, Back-Up light mod, ECGS bushing, Redline Hood Struts, Leer 100XR, BFG TA KA2 265/70-17 LR-C, FJ Steel wheels
    :eek:I could hardly stand the suspense. What a complete retard. Besides the potential of injury or death, the moron almost took out the suburban outside!
    Dobinsons Mike likes this.
  8. Jul 18, 2013 at 3:21 AM
    #48
    toughtaco
    toughtaco Well-Known Member
    05 tacoma dbl cab short bed
    TRD CAI, MBRP dual exhaust, PIAA headlights and driving lights, 5% limo tint, 3 inch Skyjacker lift , AFE throttle body spacer, 285/70/17 BF Goodright AT TA KO, Grillcraft MX with PIAA's behind the grill, anytime fog light mod, reverse camera anytime mod, and PIAA fog lights on the rear bumper anytime mod light bar behind back window with truck lights for reverse assistance, Optima Red Top Battery, Onza 3x5" LEd reverse lights attached to light bar behind cab
    I am wondering if anyone in here could recommend the best struts for 2005 DCLB. I have a 3 inch lift and just got the brakes done yesterday and I have to replace the front struts. Thanks for any help in advance.
  9. Nov 17, 2013 at 3:58 PM
    #49
    Dr 10Jeeps
    Dr 10Jeeps Well-Known Member
    Larry
    Ontario, Canada
    '13 Tacoma 4X4 (TRD, Trail Pkg)
    Well, the guy wasn't THAT stupid. After all, at the beginning, he did say "I don't want to stand in front of it."
  10. Mar 10, 2014 at 8:21 PM
    #50
    Navar
    Navar Well-Known Member
    Corona CA
    07 Tacoma TRD Sport 4x4
    Washed it, Icon suspension, Icon UCA
    Jeesh where is this shop so we never go there.
  11. May 22, 2014 at 9:04 AM
    #51
    shr133
    shr133 Well-Known Member
    Muskego, WI
    2010 V6 Sport
    K & N filter, 275 70 17 Cooper AT3, OME Nitrocharger shocks, 884 Springs, Dakar leafs.
    Pay the 100 and order the new ones assembled, the top cap wears out anyways so replace the whole strut....
  12. May 22, 2014 at 9:21 AM
    #52
    THE SCHIRMINATOR
    THE SCHIRMINATOR Well-Known Member
    Mid Mo
    06 TRD Tacoma
    Iv swapped springs without a compressor several times. Nothing dangerous about it if you do it right. Simply jack up the whole vehicles and brace with jack stands, loosen lower control arm bolts, place jack under lower control arm, jack it up until all compression is done, remove top nut and SLOWLY let down the jack until ALL pressure is off the spring/strut. Swap spring and reverse the process. Simple and safe enough for me. But looks like these guys just removed top bolt and nothing else...
  13. May 22, 2014 at 10:04 AM
    #53
    cosmicfires
    cosmicfires Well-Known Member
    David
    Lynnwood, WA
    Tacoma 4x4
    Snugtop cab high canopy.
    One time in Mexico we stopped at a vulcanizodora (tire repair shop) to get a tire patched. The were assembling a big truck tire on a split rim without a safety cage using big hammers to seat the ring. Before I took cover around the corner I asked "muy pelegera?" (very dangerous?). One guy said "si si" with a big smile.
    Same kind of thinking.
  14. May 24, 2014 at 2:25 PM
    #54
    grublin
    grublin Well-Known Member
    TC
    Plano, Tx
    The description on Youtube says the strut was bent and they couldn't get it in a spring compressor............11 years as a mechanic, half of which working next to the body mechanic, and I've never seen a strut bent bad enough you couldnt get one of the many spring compressors available around it. So stupid.
  15. Aug 27, 2016 at 10:33 AM
    #55
    Lifeofbrian
    Lifeofbrian L I V I N
    Brian
    Westminster, CO
    2008 DBCB TRD Sport
    Pro Comp Alloy wheels., Double Din, Rock Sliders, Flowmaster Exhaust, Soft topper and a few other little mods.
    same here, expecting him to loose his head.
