How not to tow
Discussion in 'Towing' started by mountainman94, Dec 9, 2012.
  1. Dec 9, 2012 at 5:06 PM
    mountainman94
    mountainman94 [OP] awwwwww yeeeeeeeeahhhhh
    Cory
    A Place of Higher Learning
    '98 TRD SR5
    5100's/Eibach coils; 2 inch toytech AAL, Black Pacer 15x8 wheels, 32x11.5 BFG AT K/Os
    Let me start this off by saying this isn't humor, this isn't a joke, and i'm extremely lucky lots of people weren't hurt or worse today.
    Earlier this afternoon, I was delivering some furniture for my mother on a 12' flatbed trailer. I hooked everything up to my tacoma, checked lights, straps, chains, the whole nine yards. I pulled the load successfully about half an hour to the house where the furniture was going, helped unload it, and then started back. When I was about 10 minutes from my house, the now unloaded and extremely light trailer began to sway behind me. I have towed small trailers before, so as before, I eased into the gas to attempt to straighten the trailer. Doing so did not help, and the trailer continued bucking behind me. (I was driving on a 4 lane highway with a central turn lane.) As I realized that my tactic was not going to work, I let off both pedals and eased into the middle lane, hoping to slow it down by it pressing against my truck and hopefully not damaging anything. Before I could react to it, the trailer bucked itself off of my hitch and slid to my left, across 3 lanes of traffic, before jumping the curb and safely coming to rest off the road and out of traffic. the trailer was pretty banged up, and the hitch was not usable. My dad and I later chained it up to his silverado and (very slowly) made it back to the house. When I looked back on the situation, I realized that I had made a mistake that had very nearly cost me and others. I had forgotten to put a holding pin in the latch that holds the trailer to the ball, and when the trailer began bucking, it simply removed itself from my hitch, and the chains holding it on were able to bounce off. I made mistakes today, this much is true. I am, however, fortunate that the only harm done was to the trailer.
    The moral of the story is that even a light trailer can be trouble, and ALWAYS ALWAYS ALWAYS make sure that the connection between your truck and trailer is locked, pinned, and securely chained.
  2. Dec 9, 2012 at 5:12 PM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    glad the damage isn't worse...
    The failure of the hitch is secondary to why the trailer started to go out of control...
  3. Dec 9, 2012 at 5:15 PM
    mountainman94
    Cory
    '98 TRD SR5
    Yes, but had I set up the hitch correctly, I wouldn't have lost the trailer. I'm still not sure as to why the trailer began to lose control. I was coming down a slight hill toward an intersection, and I assume that braking with a very light trailer caused it.
  4. Dec 9, 2012 at 5:16 PM
    KeithB
    KeithB Well-Known Member
    Keith
    Cheshire, CT
    SWB '09 Tacoma DCSB Sport 4x4
    Wheels and Tires: 17x8" Ultra Goliath wheels with P285/70R17 Falken Wildpeak AT3/W tires, Suspension: Fox coilovers set at 2", TC UCA's, 1.5" lift 3 leaf pack with overload left in Other: TRD SS exhaust, Pioneer AVIC 4100 H/U with Android Auto (awesomeness), sat radio bluetooth, Accessories: Toyota roof rack, black Toyota running board steps, cargo divider, weathertech floor liners, Literider roll up soft tonneau, thule bars over tonneau, USB ports front and rear, seat heaters, birddawg mirror riser Cosmetic: window tint, grillcraft black mesh upper/lower grill, vinyl armrest in doors, Clazzio black seat covers with blue stitch, Redline steering wheel wrap Lighting: fogs only mod, back up lights, amber interior accent lighting, amber 10" LED light bar in hood scoop, 33" LED bar behind the lower grill, amber lamin-x on fog lights, Tacomabeast headlights and matching tails.
    I wonder if it was already unhitched when you noticed it swaying and bucking. I've seen someone on the highway pulling a trailer with only the chains and it was all over the place and he didn't even notice.
  5. Dec 9, 2012 at 5:18 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    In my experience, without the latch pin in place, the trailer tongue will lift off the hitch the minute some weight is applied on the rear of the trailer (say, when loading). Surprised your trailer stayed put for as long as it did.
  6. Dec 9, 2012 at 5:21 PM
    mountainman94
    Cory
    '98 TRD SR5
    The latch was in place, and you could place weight on the rear of the trailer without it lifting off. I just didn't put a pin in place to hold it there, and it was able to shake itself loose.
  7. Dec 9, 2012 at 5:22 PM
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    Cory, thanks for telling your story. Took some courage to throw that out there knowing you might get a ration of poo for saying so.
    I'm thankful no one was hurt and that you were able to educate others through your mistake.
  8. Dec 9, 2012 at 5:23 PM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    Thank the Lords it didn't happen when loaded. Many, many moons ago, I left the hitch unlocked to the ball,of course it came off in traffic, but my chains held as I pulled off with trailer banging away at my first gen Tacoma. Ever since then, I always check things when ever I stop for anything when towing.
  9. Dec 9, 2012 at 5:25 PM
    WYOTAC
    WYOTAC Well-Known Member
    Joel
    Santa Barbara
    06 AC TRD OffRoad Desert Sand
    ICON 2.5 with JBA UCA, OME Dakar
    My coworker had that exact same thing happen to him on the interstate at 75 mph. Scary stuff! Glad no one got injured. Lessons learned first hand are lessons truly learned though.
  10. Dec 9, 2012 at 5:28 PM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    Thanks for sharing this as a reminder to double check everything. Glad nobody got hurt.
  11. Dec 9, 2012 at 5:29 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    You said the safty chains "bounced" off? :confused: Sounds like they wern't secured right.
  12. Dec 9, 2012 at 5:34 PM
    Airun
    Airun Well-Known Member
    Aaron
    Show Me State
    TRD sport, DCLB, 4wd
    Debadged, custom emblem, Husky liners, custom bedrail Yak Trak setup with load bars, , BakFlip Fibermax, OME 3" lift with LightRacing UCAs
    Yeah this most likely. The safety chains held on as long as they could.
    Thanks for the post Cory and I'm glad everything worked out and your ok. Tough lesson but you show great integrity swallowing a lil pride so we all will think twice next time.
  13. Dec 9, 2012 at 5:43 PM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    Speeding up probaly only made things worse, just letting off the gas slowly may have helped as to much speed is usually the culprit of an out of control trailer. Sounds like a tongue weight issue. Have you pulled it before without any problem.
  14. Dec 9, 2012 at 5:48 PM
    BamaToy1997
    Bill
    Navarre, FL
    Because of the stories I have heard similar to these, I have learned that when towing I use either padlocs, or a clevis to secure the safety chains. Nothing worse than seeing a trailer come loose. I had a friend who didn't have his ball tightened up right, and had secured everything else just fine, but his ball nut fell off and the ball came out of his bumper. We had to replace over 50 feet of chain link fence when I got there to help get the trailer untangled from the fence.
  15. Dec 9, 2012 at 5:51 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    This is what I was thinking too. :notsure:
  16. Dec 9, 2012 at 5:52 PM
    mountainman94
    Cory
    '98 TRD SR5
    They were the kind that at the end had only a hook, instead of a carabiner type connection. I'm really not sure how it happened, but I never found the chains. They weren't connected to the trailer, and they weren't on my truck...
    The reason I sped up is because my dad has told me that a trailer that starts to fishtail does so as a result of going faster than the truck. He says that giving it a little gas pulls the trailer into line. And yes, I've pulled that exact trailer several times, loaded and unloaded, and it's never fishtailed, jumped, done anything out of the ordinary.
  17. Dec 9, 2012 at 6:25 PM
    OffroadToy
    Glad nobody got hurt. I tow a boat and have seen it begin to fishtale a couple times in the side mirror. I just slow down a bit and it evens out pretty quick. Just a reminder... get some quality chain with hooks that snap shut, and allways criss-cross them.
  18. Dec 9, 2012 at 6:26 PM
    TACO TX
    Kelly
    Denison ,Texas
    Balane and weight distribution are factors of a swaying trailer. Generaly tongue weight on an empty trailer will cause it. Maybe the amount or lack of drop has the trailer un balanced. Just glad nothing was to damaged and everyone is ok.
  19. Dec 9, 2012 at 10:51 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Glad everyone was OK. I tend to agree that the coupler had probably come unlatched from the ball, which caused the swaying / bucking. I KNOW you will be putting a padlock / hitch pin into the coupler latch in the future, thanks for posting your experience so others can learn from it too. Also, are you certain you matched ball and coupler sizes? 1 7/8 ball in a 2" coupler is a recipe for disaster too.
    Towing a trailer is the one thing in life you don't want to go off with out a hitch.:)
