How often are you guys looking under your hood/underbody ?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Gfenza89, Aug 31, 2023.
  1. Aug 31, 2023 at 4:30 PM
    Gfenza89
    Gfenza89 [OP] Well-Known Member
    2024 Tacoma SR5 4x4 DCSB
    How often do you guys check under the hood and under your truck just to look things over, check for leaks etc?
  2. Aug 31, 2023 at 4:39 PM
    turbosnail
    turbosnail Well-Known Member
    Pa
    18 dbl cab sr5 v6 4x4 , 1985 turbo sr5 pick up
    Every ten minutes because of all the complaints of timing case leaks and burnt valves , I can’t sleep , I lay on my back under the truck with a flashlight , while the sweat runs down my forehead …. Not that I’ve actually had any of these items go wrong , my truck has been flawless for 5 years
    BRFab, jmneill, 62CHTS and 20 others like this.
  3. Aug 31, 2023 at 4:41 PM
    Gfenza89
    So on a serious note how often
    gilligoon likes this.
  4. Aug 31, 2023 at 4:43 PM
    turbosnail
    Pa
    Once a month or so I take a quick look around , check for signs of coolant residue etc .
  5. Aug 31, 2023 at 4:45 PM
    delz05
    delz05 Well-Known Member
    In that once or twice a month club myself...
    Taco22trdor and Gfenza89[OP] like this.
  6. Aug 31, 2023 at 4:46 PM
    AusBerg
    AusBerg Well-Known Member
    Austin
    North MN
    2022 TRD OR DCLB
    Only time I find myself checking is when I'm down there for a reason like an oil change or replacing my suspension etc. Same for popping the hood. And by checking I mean just a quick cursory glance to ensure no major changes / issues
  7. Aug 31, 2023 at 4:46 PM
    GONE FISHIN'
    GONE FISHIN' Well-Known Member
    northern front range CO
    21 ORAC
    I look around at oil changes (5K/6mos), and b4 and after long trips or wheeling. would up it if I had any issues, so far so good.
    Gfenza89[OP] likes this.
  8. Aug 31, 2023 at 4:50 PM
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    I let my dealer look when I have them change the oil every 5-7k. I'm fortunate to have a dealer I trust and I'm only at 3k miles.
    On my 2nd gen that had 130k, I would crawl under and check once a month.
  9. Aug 31, 2023 at 5:00 PM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    Not often enough. Lying on the pavement in arizona can result in 3rd degree burns so it's not something
    I entertain thoughts on. The daum hood weighs more than I do so just getting it open is a chore in itself.
    I need some struts on that thing.
  10. Aug 31, 2023 at 5:17 PM
    PTPinETN
    PTPinETN Well-Known Member
    Alan
    ETN
    Can’t go wrong with Spiker Engineering, only about 100 bucks, well worth it.
  11. Aug 31, 2023 at 5:22 PM
    Stuck Sucks
    Stuck Sucks Aerodynamic styling with functional design
    Jim
    Pacific Plate
    The last time I was under there, I noticed my skid needs buffing and polishing.
    Seriously, I have witness marks on critical suspension component fasteners.
    Gmak621, Canadian Caber and jerrybear like this.
  12. Aug 31, 2023 at 5:27 PM
    ppat4
    ppat4 Well-Known Member
    Paul
    Kelowna, BC
    2016 Tacoma TRD Off-Road Access Cab
    Just added toolbox and roof-rack to haul my fishing boat 100's of miles into the backwoods every week. Goodrich K02s, Bilstein 5100 front and back, no lift.
    For me it is after every off road trip. That is about 30 - 40 trips per year. Some bad trails so I like to make sure everything is tight after beating on it.
    If you are offroad frequently you want to do this. A good way to check for leaks of course, but also underbody damage, brake lines, and especially tightness on all front end suspension components.
    As an example, I had been on a couple of easy trips early this spring and was lazy and did not look. Then a few weeks later I was packing for a 4 day off-road camping trip, and the day of packing decided to do an inspection. Discovered that my passenger side swaybar linkage was shot, it wiggled like a worm on a hook. That was around noon and I was in the middle of packing for that trip. So, I called the dealer who had nothing in stock, but they were able to get me a jobber part. I installed it that afternoon and was able to then finish packing.
    That was a rough trip and unsuspectingly leaving a broken swaybar linkage would not have been a great move.
    I finished an inspection just now in fact. Also had my wife going forward/reverse multiple times to track down some noise. While I lay down beside the truck. I kept my head clear of the wheels, did not want to give her any ideas. :)
    It turns out it is my rear drum brakes are making the racket. Quite sure they are just dirty and need to be disassembled and cleaned.
  13. Aug 31, 2023 at 5:28 PM
    jerrybear
    jerrybear Well-Known Member
    17 off-road
    once a month for fluid levels, tire pressure, anything leaking etc... at oil change check torque specs on suspension and look for any loose fasteners, air in spare.
  14. Aug 31, 2023 at 6:45 PM
    MadKatt
    MadKatt In need of serious help..
    Frozen Midwest Tundra
    2019 TRD OR DCLB Calvary Blue
    Should have just started a poll. I’m in the one to two times a month club.
    Taco22trdor, hiPSI and Gfenza89[OP] like this.
  15. Aug 31, 2023 at 6:45 PM
    Gfenza89
    I know lol
    MadKatt[QUOTED] likes this.
  16. Aug 31, 2023 at 6:51 PM
    dklehman
    dklehman Well-Known Member
    Darin
    Eastern wa
    2021 TRD off road
    I do a quick visual inspection everytime I fill up , check the oil and fluids every other month.
  17. Aug 31, 2023 at 7:48 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    In parking lots I almost always park with the passenger side facing the store, this allows me to do a quick visual of the body, tires and a pavement check for leaks as I walk up.
    I have the instant access button on the steering wheel set to the tire pressure screen and check that on the first start of the day.
    Under the hood check every 2 weeks or so.
    Under truck inspection and brake check every oil change/tire rotation every 5000 miles or so.
    ppat4, turbosnail and Gfenza89[OP] like this.
  18. Aug 31, 2023 at 7:50 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    62CHTS, jlemmond, Delta09 and 9 others like this.
  19. Aug 31, 2023 at 8:23 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    I might do an inspection whenever I'm cruising down a trail and hear a crash-bang and see a wheel flying off into the woods.
    On a more serious note... I generally only inspect the truck when I'm airing up/down, pumping gas, washing the truck by hand, or doing some other sort of maintenance.
    Chew, Gfenza89[OP] and LeakyAC like this.
  20. Aug 31, 2023 at 8:30 PM
    LeakyAC
    LeakyAC Captain jackass
    2016 SR5 Access Cab 2.7 4x4 Super White II
    -Uni filter secondary air pump mod -A/C drip line extension mod -ARB F + R diff breathers relocated -ARB front recovery point -"Tow Package" class V receiver + oem 7/4 plug + aux ATF cooler -Toyo Open Country ATIII 245/75R16 -Yellow fog lights (amber Lamin-X w/ PIAA amber H16s) -BakFlip G2 tonneau cover -TRD Pro grille -Body-matched bumper caps -Blackout emblems -Husky X-Act Contour floor liners -RokBlokz mud flaps -oem bed mat Not yet installed: -0" lift Bilstein 5100 F + R w/ 4Runner front shock lower bolt swap -Total Chaos LCA cam tab gussets
    For me about once a season so 4 ish times a year. Just a general look-see underneath
    Chew and Gfenza89[QUOTED][OP] like this.
