How often do you adjust rear drum brakes?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacomagirl76, Mar 21, 2017.
  1. Mar 21, 2017 at 4:54 PM
    Tacomagirl76
    Tacomagirl76 [OP] REG. CABS RULE!
    Some where in New England!
    2014tacoma reg cab
    Duratra wrangler tires,tinted windows,kicker rear speakers,JL Audio front,fosgate amp. More to come
    Hi everybody,
    I was wondering how often should you have the rear drum brakes adjusted or cleaned ? I have 37K on my 2014 taco and did it about 9 thousand miles ago.
  2. Mar 21, 2017 at 5:19 PM
    Tacomagirl76
    2014tacoma reg cab
    Thanks for the info. I appreciate it
  3. Mar 21, 2017 at 5:27 PM
    Tiberius
    Tiberius Well-Known Member
    Aurora, CO
    Nautical Blue v6 SR5 4x4 Access Cab
    Use your parking brake when you park. I believe it adjusts your brake for you.
  4. Mar 21, 2017 at 5:31 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I think when you reverse and hit the brakes that adjusts them but I could be wrong
    TacoSupremeo likes this.
  5. Mar 21, 2017 at 5:33 PM
    Clearwater Bill
    Billy
    Largo Florida
    Parking brake use should adjust the drums, assuming the adjusting mechanism doesn't bind up.
    It's cheap and easy to 'service' the front calipers and rear assembly at least once a year in non salt climates, pre and post salt in northern climes and maybe more if you are an off roader in heavy wet/muck.
    By service, I mean clean, lubricate motion points and inspect. You'll keep things working freely and make the brakes last longer in most cases.
    fla_sun likes this.
  6. Mar 21, 2017 at 5:34 PM
    Bishop84
    Bishop84 Well-Known Member
    They "sort of" self adjust, when they are far out the wheel will turn and lock in place, but it won't adjust anywhere near to spec.
    I adjust any Taco drum when they are off, which for most of my customers is every 16000km or 10,000mi.
    It's harder to gauge how effective the brake adjustment is because of the pull style hand brake but when it's right it feels a lot more firm.
  7. Mar 21, 2017 at 10:59 PM
    Tacomagirl76
    2014tacoma reg cab
    Ok thanks everyone for the advice
  8. Mar 22, 2017 at 12:34 AM
    TacoSupremeo
    TacoSupremeo Well-Known Member
    Michael
    2005 Tacoma Double Cab 4x4
    Ive had trouble with mine adjusting like they're supposed to, next time I have he wheels off, I will be cleaning and lubricating the "self adjuster" on both sides. Steves104x4 is correct, when you apply the brakes in reverse sharply (aka, panic stop) the tang pushes down on the notched part on the self adjuster to unscrew it slightly for an adjustment. If the adjuster is gummed up (not freely unscrewing) it wont adjust efficiently.
  9. Mar 22, 2017 at 12:42 AM
    Speedytech7
    924 W Garland Ave, Spokane, WA 99205
    It's less Tacoma and more mod
    Honestly never by hand, mine have always self adjusted correctly.
  10. Mar 22, 2017 at 1:20 AM
    09BlueBeast
    09BlueBeast Well-Known Member
    Cody
    Denver
    09 Speedway Blue TRD Sport 4x4
    I got to about 118,000 on my factory pads
