How often do you change air filters?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LeftCoastNerd, Apr 4, 2017.
  1. Jan 6, 2023 at 6:03 PM
    #81
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I inspect at every oil change. I change it when its dirty.
  2. Jan 6, 2023 at 6:49 PM
    #82
    Alealexi
    Alealexi Well-Known Member
    Houston, TX
    2007 Tacoma Prerunner
    I'm sure there is but the summary is that it will not give you much benefit. Only do it for looks and for the noise with less filtration.
    Dm93 likes this.
  3. Jan 6, 2023 at 6:57 PM
    #83
    TreeFortRichard
    TreeFortRichard Barcelona Red is the best red...
    Brian
    42.3115167,-71.6638516
    '23 SR5 DCSB 4x4 Barcelona Red
    Cabin air filter should be looked at once a month maybe between Nov and Feb in the Cold weather states...the mice get in there fast...
  4. Jan 7, 2023 at 7:31 AM
    #84
    GorgeRunner
    GorgeRunner Out There
    2005 PreRunner
    I have an AEM or AEM knockoff washable engine air filter. Beat the dust out of it anytime, wash it with water once and a while. I live in dust, saves a lot of money. I have spare cabin filters, hardly ever change them since installing anti rodent screening.
  5. Jan 7, 2023 at 7:46 AM
    #85
    316sherm
    316sherm Well-Known Member
    South Louisiana
    2020 Tacoma SR TSS Package 4 Cyl
    Both at every 20,000 miles...which (with my driving) is about 1-1/2 years.
    mcpcartier likes this.
  6. Jan 7, 2023 at 7:52 AM
    #86
    Dalegribble02
    Dalegribble02 Well-Known Member
    Savona British Columbia
    2014 SR5 4x4 meg grey sold
    Dobinson mrrs Deaver leafs archive garage hammer hangers.
    Inspect every oil change and clean my afe dry filter when ever its dirty.
  7. Jan 7, 2023 at 7:54 AM
    #87
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I've changed out the air filter and cabin filter 2 times in 15 years on my 2007... comes out to about every 17,000 miles. I did the wire mesh rodent protection mod on the housing above the cabin air and added a pre-filter on top of it so my cabin filter stays pretty clean... just shake off some dust once in a while.
  8. Feb 4, 2023 at 7:45 PM
    #88
    Mas Olas
    Mas Olas Well-Known Member
    Woody
    10 miles north or 400 miles south of the border.
    2020 Blacked-Out White DCLB TRD OffRoad 4x4
    What is this rodent protection mod you speak of???
  9. Feb 4, 2023 at 10:25 PM
    #89
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
  10. Aug 27, 2023 at 10:56 AM
    #90
    klemkdittlehopper
    klemkdittlehopper New Member
    James A Fowler
    2006 Tacoma
    I change the engine air filter every 5k when I change the oil. I bought a dozen for 7 dollars each when I got my truck about 6 months ago. I live in the country on a dusty road but even if not I think the air filter being as clean as it can be is as important as clean fuel. Paying 20 dollars for a an OEM one is foolish. The cabin one every year. They are 5 bucks if you shop around.
  11. Aug 27, 2023 at 9:45 PM
    #91
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    This here ^
  12. Aug 28, 2023 at 3:57 AM
    #92
    TacoTuesday1
    FL
    Engine air filter? Probably never because snorkel.
    cabin air filter yearly. It’s small, clogs fast, and easy to change. I don’t need a clogged filter stressing and prematurely damaging my AC compressor.
  13. Aug 28, 2023 at 5:32 AM
    #93
    mcpcartier
    mcpcartier Well-Known Member
    mike
    SoCal
    2012 DCSB TX PRO
    Never thought about that filter stressing the AC. Change it every 20k and it usually looks like its due. Maybe this will motivate me to do it every 15k
  14. Aug 28, 2023 at 5:39 AM
    #94
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    I inspect mine every oil change I go more by appearance then time or miles.
  15. Aug 28, 2023 at 5:54 AM
    #95
    Steelhead Bum
    Steelhead Bum Well-Known Member
    Mitchell
    Eastern WA
    13 DCLB Sport 4x4, 92 AC MT 4x4
    Cabin and air every other oil change which works out to once a year.
  16. Aug 28, 2023 at 3:41 PM
    #96
    TacoTuesday1
    FL
    usually when a car has a blown compressor the filter looks like crap. And they tend to last 100k in general.
    new parts aren’t always made as good as old ones. I want the AC to last. So if the filter is dirty I’ll either shake it off or replace. Cheaper than other filters.
    it also can’t last as long as other brands because it’s not nearly as big as other ones nor quantity. Like cars that have 2-4 (Mercedes).
    same goes for the occasional recharge service to make sure the right amount of r134a is present, with good clean PAG oil and gas. Working at a shop, it’s basically free to do, and just means parking the truck inside on a scheduled Saturday off in the corner hooked up to the machine to do it’s own thing automatically.
    Last recharge included replacing a leaking schrader valve at the charge ports with a service kit from Oreillys who had it in stock when it started leaking.
  17. Aug 29, 2023 at 10:19 PM
    #97
    EL DUDE
    EL DUDE Well-Known Member
    I can’t remember the last time I changed my cabin filter
    I change the engine air filter once a year. Used to run K&N but after a trip in some sands I tossed it out, paper for me now
