How often do you change the differential fluid?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Cnasianfire, Jun 10, 2018.
  1. Jun 12, 2018 at 12:36 PM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    30K
    My front diff seized this past December and needed to be replaced. I attribute that to a fluke and not the gear oil.
  2. Jun 12, 2018 at 12:38 PM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    Ouch! Assuming you had to get a new one, how much did that run you?
    Sig45[QUOTED] likes this.
  3. Jun 12, 2018 at 12:40 PM
    Sig45
    Mark
    Maine
    Ouch is right.
    Right around $3K for a new one including labor.
    My dealer tried to locate a used one through LKQ, but there were none available - that's how rare this was.
    That gear oil had only been in there for 5K miles.
  4. Jun 12, 2018 at 12:43 PM
    Blockhead
    Pittsburgh, Pa.
    Geez! Any idea why it seized?
  5. Jun 12, 2018 at 12:43 PM
    2WD
    2WD Well-Known Member
    Pete
    2013 DCSB TRD Off-Road Pre-Runner Taco
    King 25001-119A, JBA HC and superbumps, EL095 leafs with longer overload leaf removed and 2 degree shim, Bilstein 5160 rears with fox roost shield on passenger side, King 2'' bump stops, B&M 70264 trans cooler, CSF FJ radiator, Leer Trilogy X2T bed cover, Scangauge, 34R AGM battery, weathertech floormats, Gold plug on the differential, fancy engine and diff oils, UNI air injection filter mod, Factory antenna chopped 4'', De-badged, Ram mount on A pillar, Cooper ST Maxx 265/75 R16.
    I changed mine at 20k(rear diff 2013 with e-locker). It was dark grey with a ton of fine sparkles like a nice metallic paint. I got scared, bought a gold plug(really strong magnet plug) and changed it 2 more times over the following year. Now it is staying very clean looking and no sparkles.
  6. Jun 12, 2018 at 12:44 PM
    Sig45
    Mark
    Maine
    Nada...the tech showed it to me and it just wouldn't turn.
  7. Jun 12, 2018 at 12:46 PM
    Blockhead
    Pittsburgh, Pa.
    I would’ve been sick...you never know I guess.
  8. Jun 12, 2018 at 1:07 PM
    Sig45
    Mark
    Maine
    Yup...crappy feeling, but what can ya do.
    None of the techs had ever seen that happen.
    Blockhead[QUOTED] likes this.
  9. Jun 13, 2018 at 7:37 AM
    Cnasianfire
    Cnasianfire [OP] Well-Known Member
    Charles
    Wilmington, NC
    2015 Tacoma TRD off road DCSB
    BFG KO2 285/75/16 ~2" lift (5100s and block)
    Yeah, I tow like 6 hours a year. I don't do any real off roading besides the beach and I am always in 4Hi, never lock the rear. I hope that it isn't trashed.
  10. Jun 13, 2018 at 9:19 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    ALWAYS change out the original oil within the first 10k miles, preferably 5k miles. Then every 30k after that. Gear oil is cheap, pinion bearings and ring and pinion gears are not. Most that go a long time on original oil end up trashing ring n pinion due to worn pinion bearings.
    wi_taco and ejl923 like this.
  11. Jun 13, 2018 at 10:36 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    I run it hard only a few times a year, so I change the differential fluid every 60,000 miles using synthetic 75w90. Mine is the base with the open differential so the LSD is a non-issue.
  12. Jun 13, 2018 at 10:41 AM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    I try to change between 60-80k. I just put 80w-90 (mixed with a little bit of 85-140) in the rear and 75-90 in the rest. I do not care about synth/non-synth as it doesn't matter to me, just get the proper API rating. FWIW Supertech full syn 75-90 is about $6 a quart at walmart.
    Make sure to clean off the drain plug magnet really well before reinstalling so that it can effectively pick up crap.
  13. Jun 13, 2018 at 10:44 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    I changed front and rear dif at 30K miles. The front dif did not need it. From here on out I am planning to do the rear dif at 60K (every 30K miles) and the front dif at 90 K (every 60k miles).
  14. Jun 13, 2018 at 10:48 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    I noticed the same. Went for a drive to warm up the oil before dumping, and when I got to the front diff, it was cold. I put in 4hi and did another highway run, then drained. Nice and warm, but fluid looked brand new.
  15. Jun 13, 2018 at 11:24 AM
    #35
    Sugar Silva
    Sugar Silva Well-Known Member
    Dave
    San Diego, CA
    16 Toyota Land Cruiser
    Kings Sliders TRD Rock Warrior Wheels Tint
  16. Jun 13, 2018 at 11:29 AM
    #36
    whitedlite
    whitedlite Well-Known Member
    USA!
    3RD Gen TRD 4WD
    this a little overthought, think about all the tow rigs that have never been changed. Family has an 03 F250 with a Cummins, 235k miles on truck body, all that work and never a differential oil change.
    In my tacoma I have ARB's front and rear, so I'll probably do it once I hit 50k miles then have the free time.
  17. Jun 13, 2018 at 4:51 PM
    #37
    Cnasianfire
    Charles
    Wilmington, NC
    Wow, so many opinions. I was scared that at 65k and not knowingif it had been ever changed that I might have worn the diff down prematurely and harmed it. But doesn't sound like I have. No lsd, tow 2 times a year, beach driving is about all the off road I do
  18. Jun 13, 2018 at 5:01 PM
    #38
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    I have never changed different oil in any of my vehicles except my VMAX.
    Maybe at 200k I'll do it along with first sparkplug change. 192k miles and running strong .
    SLeeper512 likes this.
  19. Jun 13, 2018 at 5:27 PM
    #39
    joerod86
    joerod86 Well-Known Member
    Joe
    07 Super White TRD Off Road Access cab 4x4
    Toyota recommends to change it every 30K miles. If you tow or off road often then you should follow that plan. If you are driving under normal conditions then every 50K should be fine. Honestly the service is ridiculously easy, you don't even need to jack up the truck. It's cheap insurance in my opinion.
  20. Jun 13, 2018 at 5:37 PM
    #40
    JTLynch
    JTLynch Member
    Jeff
    2018 Tacoma SR5
    if you have a Gen 3 (2016 or later), I strongly urge you to change the rear end differential fluid at 30,000 miles and have the technician look carefully for shavings and a cracked spline. I waited till 90,000 miles and Toyota bought me a brand new differential gear labor included. The engine change in the Gen 3 changed the drive train and it looks like more stress is put on the rear u-joint and the spline gear.
    I was lucky and my service manager talked Toyota into comping the whole thing. You might not be so lucky.
    Just sayin'
