How often do you change the differential fluid?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Cnasianfire, Jun 10, 2018.
  1. Oct 21, 2022 at 2:12 PM
    #61
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    2015 Toyota Sienna with rear locker
    Bought my '15 DCSB OR back in 2020 with 76k on the clock. No record of previous service, and based on what I saw come out I'd lean towards it being factory fluids but no way to tell for sure. Using Amsoil Severe Gear 75w90 going forward because that's what I like, YMMV.
    Changed all diffs at 80k and sent samples to Blackstone. Front diff oil looked TERRIBLE coming out but test was A-OK. Rear diff had elevated metals but they said it's likely break-in wear. Transfer case looked brand new but was the worst test results of the bunch with high insolubles and copper. Moral of the story: don't judge oil condition by how it looks in all cases. Links here if you want to see the test results for yourself: [#55][#56][#72][#135]
    I'm about to dump them again & send in new samples. I'd expect the tests to come back much better this time unless something is already gone wrong - which I highly doubt as it functions perfectly.
    Tests cost $30 but my time & peace of mind are worth it. Frankly I spend more on other dumb mods & toys, oil tests are what I consider cheap insurance for expensive driveline parts.
    DGXR, wmb67 and 2015WhiteOR like this.
  2. Jan 24, 2025 at 7:52 AM
    #62
    EIkTaco
    EIkTaco Active Member
    Jonathan
    2013 Silver Tacoma
    Method Wheels, Axiom LED Lights, Pedal Commander
    Hahahahhahaa
  3. Jan 24, 2025 at 8:02 AM
    #63
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
