How often do you change the rear brake shoes?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kidthatsirish, Jun 24, 2024.
  1. Jun 24, 2024 at 6:29 PM
    kidthatsirish
    kidthatsirish [OP] Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    I think I currently have about 130k on my current shows... honestly Wonder what others have.
  2. Jun 24, 2024 at 6:30 PM
    joba27n
    joba27n YotaWerx Authorized tuner
    Nolan
    Alberta
    2021 Gray TRD Sport Tacoma MT
    YotaWerx Stage 1, Bumper light bar, Hood wrap, Roadmaster Active Suspension, Durobumps.
    I'm over 182'000 KM's and my shoes look pretty fresh still. I also usually adjust them at tire rotations/ oil changes
    cruxofthebisquit likes this.
  3. Jun 24, 2024 at 6:32 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    140K on the stockers
  4. Jun 24, 2024 at 6:53 PM
    Homeline
    Homeline Well-Known Member
    2013 Access Cab 5-Lugger
    2" Leveling Kit, TRD skid plate, 16" Jeep wheels, Katzkin leather seats w/heaters, jump seat delete
    I have 230K miles on stock shoes and drums. Still had lots of lining when I last inspected at 175k. E-brake still holds rock solid.
    TheDevilYouLove and po35042 like this.
  5. Jun 24, 2024 at 6:54 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    They last forever if they never touch the drum.
    JasonLee, Torspd, ToyoTaco25 and 5 others like this.
  6. Jun 24, 2024 at 7:28 PM
    TacoTuesday1
    SD CA
    Inspect it...
  7. Jun 24, 2024 at 10:02 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Bottom line is once you pull the drums off and inspect, plus age is a factor, easier to just change all out and be done for another 10 years.
    Rusted pivots on parking brake areas, glazing of drums/shoes, rust/thrown weights/springs/etc, accumulated crap in there, old wheel cylinders, all can affect performance.
  8. Jun 25, 2024 at 4:37 AM
    TacoTuesday1
    SD CA
    I should probably check the DIY. Want to know if removing the drum with a bolt through the thread hole will unsettle the ebrake adjustment
    and need adjustment after putting the drum back on
    or if it’s simple remove and re install inspect
    to Check status
    Either way I’m expecting need to do cylinders, pads, drums, maybe that’s it.
    disc brake conversion would be awesome but I don’t know of any reasonably priced kits atm.
  9. Jun 25, 2024 at 4:48 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    I just inspected mine this weekend after doing new pads in the front. They are wearing a bit uneven, but even at their thinnest I still have 2.5mm left. Toyota spec is just 1mm. 120k miles on my truck.
    I do my best to keep them adjusted. I think the vast majority of people don't have them adjusted properly, which leads to the really high mileage intervals you read about on here
    Torspd likes this.
  10. Jun 25, 2024 at 4:57 AM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    Sounds like my truck. 205k on original rear brake equipment.
  11. Jun 25, 2024 at 4:57 AM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    I did the ones on my 08 at 160k.
    Didn’t need them but was there any way due to an axle seal.
    Had a 2012 and at 170k didn’t do them no issues, frame had more rust than I liked. Have a 2018 w/60k so no worries here yet.
  12. Jun 25, 2024 at 5:06 AM
    Clearwater Bill
    Billy
    Largo Florida
    Annual clean, inspect, adjust here. No salt, only 5k a yr.
    If I was an offroader or lived in salt world, it would be 2x a year minimum.
    As far as replacment, my average over similar vehicles (disc/drum) is about every 2nd front change of pads gets rear shoes. So roughly 150k on the rear.
    winkel likes this.
  13. Jun 25, 2024 at 6:30 AM
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    I have +220,000 on mine and they have only been adjusted once. I should probably replace everything in there including the wheel cylinder just as preventative maintenance.
  14. Jun 25, 2024 at 7:46 AM
    TheDevilYouLove
    Marylandistan
    Is there a thread on inspecting/changing the rear brake shoes and drum?
  15. Jun 25, 2024 at 8:49 AM
    SR-71A
    Zack
    Southern Maine
    If you're just inspecting them, that's easy. Take wheel off, take drum off, measure remaining pad thickness in various locations. A little compressed air gets rid of mud / dust buildup. Check the adjuster isnt obviously frozen.
  16. Jun 25, 2024 at 8:57 AM
    Rupp1
    Rupp1 "If you can dodge a wrench, you can dodge a ball."
    NC
    2024 Nissan Titan Pro4X
    Wait, there’s brake shoes on the back??? Only 83k on my 2015. They are still good.
  17. Jun 25, 2024 at 9:46 AM
    FishaRnekEd
    FishaRnekEd Well-Known Member
    New Orleans, LA
    2005 4.0 6spd 4x4 Dbl Cb short bed
    My shoes were only worn halfway down at about 150k miles. I replaced them since i was in there to replace the rusted up springs.
  18. Jun 25, 2024 at 12:12 PM
    jaymac10
    jaymac10 Well-Known Member
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    I'm an idiot so... How do you take the drum off?
  19. Jun 25, 2024 at 12:18 PM
    kidthatsirish
    Break lug nuts free on rear wheels, do not remove.
    Raise vehicle, support on Jack stands.
    Chock front tires to prevent vehicle rolling off Jack stands.
    Release parking brake.
    Go through back of drum and ease tension of off star wheel
    Remove lug nuts on rear wheels, remove wheels
    Firmly grasp rear drum and pull off (ensure parking brake is released!)
    If (read likely) the drum won't come off, replace lug nuts on studs to prevent thread damage.
    Get BFH, tap with increasing force on drum until drum comes free.
    If required you can buy some bolts (don't recall the thread pitch) that will thread into the drum and help you back them off.
    Spindifferent likes this.
  20. Jun 25, 2024 at 12:33 PM
    muddog321
    FL
    If you use bolts to pull the drums off (usually needed) and you have not done so in a long while, there will be a lip on the outer edge of the drum that catches the shoes and you will likely break the little outer metal tabs off the wheel cylinders metal plungers as the shoes flex out - unless you first back off the adjuster. If you are changing the wheel cylinders who cares. You will hear and feel a pop as the drum releases off the axle/lugs.
