How often do you change your oil? My manual says 10,000 miles?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tarbal255, Jan 16, 2019.
Thread Status:
Not open for further replies.
  1. Jan 16, 2019 at 1:02 PM
    oruacat2
    oruacat2 Well-Known Member
    Kenny
    Bluegrass Country
    2017 white Tacoma TRD Offroad
    none yet
    Ask yourself if your own peace-of-mind is more valuable than the extra time and money spent changing it more frequently than the manual says and if the answer is "yes" tell everyone else to suck it.
    TimC likes this.
  2. Jan 16, 2019 at 1:02 PM
    SgtPuddin
    SgtPuddin Well-Known Member
    Mississippi
    2018 Tacoma TRD Off-Road DCLB
    KO2 Ray10 5100’s 884’s Rx350 Retro Headlights
    Now I know why oil companies are so rich lol.
    over60, outlawtacoma and na8rboy like this.
  3. Jan 16, 2019 at 1:04 PM
    iDrew
    iDrew I spend too much on vehicles...
    Andrew
    Edmond, OK
    '16 TRD Off-Road DCSB
    STOCK AF
    I change mine every 5k because I drive mine hard lol
    Gritto and The hammer like this.
  4. Jan 16, 2019 at 1:05 PM
    SgtPuddin
    Mississippi
    I can understand that side of the argument. If your turbo charged, tow alot, or hell even wheel alot it makes sense. But just highway driving like most people do it doesnt. Lets face it our engine aint no goat lol
  5. Jan 16, 2019 at 1:08 PM
    SgtPuddin
    Mississippi
    I give up lol.
  6. Jan 16, 2019 at 1:12 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    If you run 91 Octane fuel, it changes the oil interval to 5000k, and 5W30
  7. Jan 16, 2019 at 1:12 PM
    Taco16LB
    Taco16LB Well-Known Member
    I understand the sentiment but it costs almost as much for the oil test as a an oil change if you do it yourself . why not just do the oil change ? Do an oil test at 10K and again at 59 K before the warranty runs out .
    xxTacocaTxx likes this.
  8. Jan 16, 2019 at 1:13 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    With synthetic oil 10K is conservative. There are lots of guys out there with 400,000+ miles that changed oil at 10K or even longer. The guy with the 1.2 million mile Tacoma doesn't even keep up with his mileage. He changes once/month and said it varied between 8K-12K. His original engine was still working fine at almost 900,000 miles but needed a new head gasket. They decided to just replace the engine with one out of a scrap yard with 100,000 on it. He now has 400,000 miles on that engine.
    I've been changing mine on my 2007 at 10K since new and now have 194,000 on it. I have no doubts about it going another 194,000 with the same oil change interval.
    Pwakchop and xxTacocaTxx like this.
  9. Jan 16, 2019 at 1:13 PM
    SgtPuddin
    Mississippi
    You should post stuff like that. Someone might actually believe you lol.
  10. Jan 16, 2019 at 1:13 PM
    sd1uh8as
    sd1uh8as Well-Known Member
    Ivan
    Bay Area
    2018 Tacoma OR DCLB
    5k miles
  11. Jan 16, 2019 at 1:14 PM
    Stocklocker
    17TRDORDCSBAT
    :devil:
    over60 likes this.
  12. Jan 16, 2019 at 1:16 PM
    mcdean
    mcdean Well-Known Member
    San Jose, CA
    2016 DCLB TRDOR 4x4 A/T
    LED int lights, Morimoto HID lows, Philips LED fogs
    You forgot to add "You're going to blow up your engine at 100k miles if you don't change the oil every 5k miles." and "If you use 0W20 oil instead of <insert manufacturer/different weight> then you're a Toyota shill.".
    The hammer likes this.
  13. Jan 16, 2019 at 1:26 PM
    boynoyce
    boynoyce .
    16SR5AC4X4V6QS
    It's going to be ok.
    You can change your oil before 10k if it makes you happy.
    Waiting until 10k also works.
    0W20 synthetic oil is what Toyota recommends.
    Good luck and keep your sense of humor well oiled also.
    Cheers
    The hammer, Taco16LB and shakerhood like this.
  14. Jan 16, 2019 at 1:26 PM
    iDrew
    Andrew
    Edmond, OK
    STOCK AF
    I hotrod mine lol. I let her sing through the RPMs as it was designed to. When I change the oil, it isn't gold anymore by any means, so I just change it. It helps that I'm at a dealership too so I can put it on my rack whenever.
  15. Jan 16, 2019 at 1:31 PM
    #35
    BeaverNation
    BeaverNation Well-Known Member
    Change mine every 15,000 miles with Mobil 1.
    Pwakchop, The hammer and Slashaar like this.
  16. Jan 16, 2019 at 1:31 PM
    #36
    HelloMyNameIs
    HelloMyNameIs I know words, I have the best words.
    2018 TRD Off Road in Cement
    OME 2885, Billie 5100s, HS Prog AAL, 255/85r16 Cooper ST Maxxs
    We're supposed to change the oil? What do we change it to?
    The hammer and Bullnettles like this.
  17. Jan 16, 2019 at 1:32 PM
    #37
    Qwack
    Qwack Well-Known Member
    Oahu
    2016 TRD Sport 4x4 2017 4Runner
    friends and family with high milage toyotas (300k and over) say they just follow
    the owners manual recommendation. I used to do 2k oil changes
    but now i do 10k oil changes. also get a fumoto valve.
    HelloMyNameIs likes this.
  18. Jan 16, 2019 at 1:37 PM
    #38
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    10K miles
    See signature
  19. Jan 16, 2019 at 1:40 PM
    #39
    MinookaBlues
    MinookaBlues Well-Known Member
    2022 Super White SR5 Access Cab
    Stock
    Changed my oil 4 times the first 2 years under ToyotaCare. After that I was told by the dealership that I only needed to do it every 10,000 miles since I was using synthetic. I put about 7,500/year on my truck so when I take it in for an inspection I get the oil changed at the same time.
    https://toyota.custhelp.com/app/ans...the-oil-change-intervals-using-synthetic-oil?
    https://www.chicagotribune.com/classified/automotive/sc-changing-oil-autos-0519-20160516-story.html
    https://www.edmunds.com/car-news/tips-advice/stop-changing-your-oil.html
    https://www.wow-toyota.com/toyota-4runner-recommended-maintenance.htm
  20. Jan 16, 2019 at 1:47 PM
    #40
    royceferris
    royceferris Well-Known Member
    Roy
    Nashville TN
    2019 OR DCSB 6MT
    My 2 cents... people that care about changing their oil more regularly take care of EVERYTHING about the vehicle, not just the oil. So these are the people saying they have a million miles and it is because of frequent oil changes. For the record, I'm doing 5k until warranty expires then 7-8k.
    gurneyeagle likes this.
Thread Status:
