How often do you engage RR Differential?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jrdbrn, Oct 12, 2011.
  1. Oct 12, 2011 at 7:51 AM
    jrdbrn
    jrdbrn [OP] Well-Known Member
    Jared
    Louisiana
    '21 TRD Off Road
    I was wondering as it is something I won't be using often. How often do you engage it to keep it lubed? I did it today at work in the gravel and it didn't want to disengage. After about 2 minutes of driving with it off, it finally disengaged. Is this normal?
  2. Oct 12, 2011 at 8:46 AM
    LUSETACO
    LUSETACO Here for the Taco Pron
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    Mine was "sticky" the first couple of times. It takes a little bit to break it in.
  3. Oct 12, 2011 at 9:27 AM
    coolreed
    coolreed Well-Known Member
    Reed
    OKC
    2019 Toyota Tacoma TRD Pro
    Goodyear Wrangler Dura Track Pro Tires, K&N Cold Air Intake, Pedal Commander.
    Are you talking about the Locking TRD Rear Differential that come with the TRD Off-Road Package?
    I have used mine once in five years.
  4. Oct 12, 2011 at 9:33 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    It depends on how much serious off roading you do. Specially climbing steep, rough hills. In my 2001 and 2005 it was used many times, and it is a life saver at getting the truck over an obsticle, like a mountain of rocks!
    My 2010 has A-TRAC and essentially that gives this truck the traction of lockers on the rear and front! I only use the rear locker now doing fun tests to compare A-TRAC and the rear locker. I did like using the locker in the snow (with A-TRAC on standby).
  5. Oct 12, 2011 at 9:40 AM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    I use mine a good bit. I used it a while back to pull some stumps out the ground or pull some trees that fell over during a bad storm we had a while back out of the woods so that I could cut them up and haul them away. I'll also use it to pull my boat up the landing ramp. When you try to disengage it if you turn side to side making like a ''S'' shape it will unlock quicker and let off the gas when you push the button out.
  6. Oct 12, 2011 at 9:54 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Wait....when did you get ATRAC?!
  7. Oct 12, 2011 at 10:10 AM
    RJALLDAY702
    RJALLDAY702 U MAD? OH U MAD
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
    I just throw it on every now and then, aside from when I wheel, To keep it lubed up!
  8. Oct 12, 2011 at 3:04 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    Depends on what you're referring too. If you mean the locking rear diff, I haven't really needed it but I'll put it in 4lo and lock up the rear diff about once a month when I am pulling my boat out of one gravel launch I use just to make sure it still works. Now if you mean 4hi, a couple times a week pulling my boat out of most launches that I use. It locks up fast now and unlocks easily too.
  9. Oct 12, 2011 at 3:25 PM
    nhgranite
    nhgranite Well-Known Member
    N.H
    fisher plow
    plowing my driveway i use it. pulling big ass rocks out of the ground this summer. wish i had one for the front.
  10. Oct 12, 2011 at 3:58 PM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    x2 Same here! :D
  11. Oct 12, 2011 at 4:22 PM
    lj973gm
    lj973gm Sold it, dont miss it yet.
    Ohio
    06 DCSB 4wd
    What this A-trac company you work for.
    I am a newb and know you swing on theirs already
  12. Oct 12, 2011 at 4:51 PM
    David K
    No, that is the point... A-TRAC IS A TOYOTA product... unlike a lot of posters here... I am about my Toyota and what it comes with... no add ons to make it have more traction!
    A-TRAC is Active Traction Control and has been on many Toyota and Lexus 4WDs for several years... It is a proven technology and the Tacoma Off Road 4WD finaly got A-TRAC in 2009.
    In a nut shell, A-TRAC provides the traction benefits of locking differentials on the front and rear, without the handicap of steering difficulty lockers create by not allowing the tires to rotate differently.
  13. Oct 25, 2011 at 2:14 PM
    Blackhawk131
    Blackhawk131 Well-Known Member
    How do you know if you have a open or lsd in the back. I have a 2006 TRD OR if that helps or where there different diffs?
  14. Oct 25, 2011 at 2:19 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    I engage my rear diff every I take my truck out of park.
    Now the Rear Locker...Eh...whenever I feel like it really. More in winter.
  15. Oct 25, 2011 at 2:31 PM
    T-Rex266
    T-Rex266 SpaceX Director Moderator
    Elon
    As David has said before u should only use the rear locker when ur stuck correct?
  16. Oct 25, 2011 at 2:35 PM
    Crom
    Nick
    San Diego, CA
    Millions
    That's what the Toyota manual states. However, in practical use it's best to activate it before a difficult section of a trail--in anticipation of loss of traction so that you don't get stuck.
    Also, the 2WD guys use it very differently from the 4x4 guys, so you'll notice that peoples experiences will vary depending on which truck they own.
  17. Oct 25, 2011 at 2:36 PM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    When I am in sand I just lock it and go. There is no speed restriction. I know David likes to post the picture of the warning sticker but you can operate a locker over 5mph
  18. Oct 25, 2011 at 2:45 PM
    Cr250jumper
    The moon
    50 shades of tan©
    OMG are you crazy! Didnt you see the warning sticker on your door? You rebel
  19. Oct 25, 2011 at 2:50 PM
    David K
    Just so we are all understanding... I post the warning sticker more often to those with or considering the Off Road TRD 4WD... because it has A-TRAC and there is no 'warning sticker' on using A-TRAC...
    A-TRAC provides traction on the front and rear tires. IF you ever find a situation that A-TRAC doesn't get you through, THEN you have the rear locker still, as an emergency back up (and it is Toyota that says use it only for emergency stucks, etc.).
    Because it is my 3rd rear locker equipped Tacoma, I know you can drive it locked over 5 mph, and not just for getting unstuck (who wants to get stuck first, anyhow?).
    The Toyota concerns are that steering is compromised with the rear locked... so, if you don't go fast, less chance of you driving into a tree or off a cliff! A-TRAC does NOT affect steering.
    I have yet to find a place where I used the locker in the past to get through, that A-TRAC alone didn't work as well, or better in my newest Tacoma. This is the news that I share, if anyone wants to know. A-TRAC is many levels higher in traction assistance than TRAC or basic limited slip... It does the job of front and rear lockers together. Instead of locking the axles together inside the diff., it locks the axles by matching rotation of the two tires by braking the slipping tire to the same traction level as the tire on firm ground.
  20. Oct 25, 2011 at 2:50 PM
    05RedTaco
    05RedTaco Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    Yes, when I went off road in my 2wd TRD OR, I would engage the locker before an obstacle where I anticipated I could get stuck, just to avoid spinning one tire and risking damaging it in the process...
