how often do you replace coolant in your 2nd gen taco
Discussion in '2nd Gen. Tacomas (2005-2015)' started by oldgrayghost, Aug 17, 2017.
  1. Aug 17, 2017 at 10:36 AM
    oldgrayghost
    oldgrayghost [OP] Member
    I have a 2007 4.0 that has the same coolant that came from the factory/dealership. going on 11yrs old now. it's never been mentioned when she goes in for oil/filters- what do you guys think on this?
  2. Aug 17, 2017 at 10:40 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    SLLC should be replaced every 5 years or 100k miles.....whichever comes first
    Rambo54 and 2015WhiteOR like this.
  3. Aug 17, 2017 at 10:41 AM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Wouldn't hurt to flush and replace but if you've never had overheating problems you can leave it alone. Just check the level and make sure your radiator fins aren't mucked up with mud and dirt
    Rambo54 likes this.
  4. Aug 17, 2017 at 10:53 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Every 100k
  5. Aug 17, 2017 at 11:02 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    yup i do 5 yrs or 100k n call it good.
  6. Aug 17, 2017 at 11:10 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Huh
  7. Aug 17, 2017 at 11:11 AM
    TireFire
    Olympic Peninsula
    Fixed, stupid fat fingers
  8. Aug 17, 2017 at 11:40 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    176k on original AF
  9. Aug 17, 2017 at 11:44 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    coolant needs to be changed. nah
    Sig45 likes this.
  10. Aug 17, 2017 at 11:49 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    If it ain't broke , don't replace it. If it looks nice and pink and not leaking anywhere, don't touch it.
    WebberLander, igno1tus and Sig45 like this.
  11. Aug 17, 2017 at 12:52 PM
    oldgrayghost
    I ordered a gallon of factory coolant just in case. even on my older vehicles I always used distilled water on the mix. I can't remember how many anode rods and electric water heaters I've replaced due to my community water supply- NO way is any of that going in anything that takes a water mix.
    Capt Jrod likes this.
  12. Aug 17, 2017 at 1:06 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    My 07 has 181,000 and it is still factory. I change my own oil, but take it in to a trusted independent mechanic for a yearly checkup. He checks it from top to bottom including testing the fluid. He says mine is still good.
  13. Aug 17, 2017 at 1:14 PM
    ericd
    ericd Stuff
    Eric
    las vegas
    2013 DCSB 4x4 OR
    The only real way to know is with a hydrometer. Everything else is a guess.
    Lord Helmet likes this.
  14. Aug 17, 2017 at 1:24 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    The problem with most coolant is that it turns acidic over time. Get some PH Test Strips and check it on a regular basis like yearly.
    DavesTaco68 likes this.
  15. Aug 17, 2017 at 1:36 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    You should add that gallon. A drain & fill is super easy, and for a gallon you should only have to open the radiator drain valve and not bother with the block, I am not 100% sure about the 4.0. If it takes more than a gallon to refill, just put back some of the old stuff you drained. Call it a "refreshing" but after 11 years it is a good idea IMO. You already have the coolant anyway.
    I drained the original coolant after 7 years (hit 100k miles). Now I do a drain & fill every 5 years, which equals about 65k miles. This is a regular service specified in the owner's manual so don't ignore it for too long. Coolant will eventually wear out due to heat cycling, and possibly age will affect it also. It really is easy to do, at least it is on my 2.7 :)
    spitdog likes this.
  16. Aug 17, 2017 at 6:07 PM
    Armkb
    Armkb Well-Known Member
    Hudson Valley, New York
    09 TRD Sport DCLB
    Bilstein 5100, OME 885X, LR UCA, ARB/EL095R, ES LCA Rack & Sway Bar Bushings, Yellow Wire Mod, ABS Switch, TPMS Mod, Scanguage, Toyota Bed Mat, WeatherTech Floor Liners, Extang Trifecta Cover, Fumoto Drain Valve
    This^^^^^^
    Fluid may look fine, and there may be no symptoms or problems...but like Jimmy said coolant breaks down with use and time. Go by owners manual.
  17. Aug 17, 2017 at 6:10 PM
    Plain Jane Taco
    USA
    If you bought SLLC it's premixed. Do not dilute it.
    If you bought LLC then mix it 50/50 with distilled water
  18. Aug 18, 2017 at 8:17 AM
    yonah
    yonah Well-Known Member
    Calling-in from east of the Rockies
    I don't have my owner's manual in front of me, but I am fairly certain it calls for the original fluid to be changed at 100k miles, and every 50k after that.
  19. Aug 18, 2017 at 8:27 AM
    Rambo54
    Rambo54 TacomaBob
    Robert
    Eustis,FL
    2013 Nautical Blue Metalic Tacoma PreRunner DCLB
    Many !
    I do mine every 3/36 ,its insurance. Coolant gets dirty and chemicals can wear ! why risk a overheat and rust and leaks on road ???
    Lester Lugnut likes this.
  20. Aug 18, 2017 at 8:37 AM
    80schild
    80schild Well-Known Member
    Chad
    Flori-Bama
    2007 TRD Sport Access Cab
    Yes, and the corrosion inhibitors deplete over time.
    I don't understand the "if it don't leak leave it alone" mentality. Corrosion is usually what causes the leak in the first place.
    Rambo54 likes this.
