How Often Do You Rotate Your Tires??
Discussion in 'Wheels & Tires' started by JRod4928, Oct 15, 2012.
Poll closed Dec 14, 2012.
  1. 3000 Miles
    25 vote(s)
    9.1%
  2. 5000 Miles
    178 vote(s)
    65.0%
  3. 7500 Miles
    26 vote(s)
    9.5%
  4. 10000 Miles
    30 vote(s)
    10.9%
  5. Never
    15 vote(s)
    5.5%
  1. Oct 16, 2012 at 2:46 AM
    coffeesnob
    coffeesnob Well-Known Member
    VA
    2010 access 4 cyl 2 wd
    I have 29,000 on mine have rotated one x need to do it again I just keep putting it off. I think I need to buy a good jack and do it myself.
  2. Oct 16, 2012 at 3:10 AM
    BORNWILDGUY
    BORNWILDGUY Well-Known Member
    Rich
    Florida
    2020 TACOMA TRD SPORT DCLB LIFTED W KDMAX-PRO XT TUNE
    FULLY LOADED WITH THE TECH PACKAGE, LEATHER, JBL SYSTEM W UPGRADED JBL SPEAKERS IN AL DOORS AND SUB, LED HEADLIGHTS, MOONROOF, EXTANG FULL TILT COVER, NFAB SIDE STEPS, OEM ROOF RACK, TRD PRO TAILS, COLOR MATCHED TRD PRO GRILL WITH WHITE RAPTOR LIGHTS, 15% TINT ALL THE WAY AROUND, TINTED WINDSHIELD 50%, BILSTEIN 6112'S W 650# SPRINGS AND 1/4 SPACER, ICON LEAF SPRINGS W 5125 REAR SHOCKS, WELD LEDGE 6 WHEELS 18 X 9 -12 W 275/65R18 TOYO AT III LOAD C TIRES
    Every 5,000 miles along with alignment and oil change. Lifetime alignment thru tires plus so I take it there every 5,000 wether it needs it or not.
  3. Oct 16, 2012 at 9:22 AM
    JRod4928
    JRod4928 [OP] Well-Known Member
    Pittsburgh
    '12 Tacoma SR5
    Extang Trifecta Tonneau WeatherTech Floor Liners Pop & Lock Tailgate Lock Antenna X Black Mesh Grillcraft with Tacoma Badge (Upper) and Cross (Lower) 18" BMF Wheels / Cooper 31.5" Tires 2" Leveling Kit
    Did you re-use the bolt? :boink:
  4. Oct 16, 2012 at 9:37 AM
    2011supercoma
    2011supercoma Well-Known Member
    nola
    sr5 4x4, trd supercharged
    trd supercharger, afe cai, doug thorley lt hearders, magnaflow exhaust, rcd 4.5" lift with ome 883 springs, cbi ditch light mounts with rigid industry D2 spot lights,
    when i need to buy new tires.
  5. Oct 16, 2012 at 10:19 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    They rotate everytime i drive.:notsure:
  6. Oct 17, 2012 at 8:45 AM
    Bobbb
    Bobbb "Rumors of Bob, but never Bob. It is Bob, right?"
    Bob
    Bob
    Bob
    Tundra TRD/OR
    Every 5,000 miles and I do all five of them. I do it myself as I already know not to trust the numbnuts at the dealership to do them properly and have learned this applies to the tire store where I bought them as well.
  7. Oct 17, 2012 at 8:50 AM
    JRod4928
    Pittsburgh
    '12 Tacoma SR5
    Yeah i'll be doing it myself too. I wouldn't work as hard or carefully on other people's vehicles either if I were them and had to do that for a living. I wish I could be honest and say I would, but I'd be lying, haha.
    I trust myself with my own vehicle, so If i screw something up I can at least say that its my own fault instead of being mad at someone else.
  8. Oct 20, 2012 at 3:27 PM
    darkgohan
    darkgohan Well-Known Member
    Never done this before,and I just bought the Cooper AT3. Can you tell me is it just front to rear,same side or say right front to left rear and so on? Thank you. :confused:
  9. Oct 20, 2012 at 3:34 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    You will find a lot of people have different opinions on which method you should use to rotate tires. Check out this link to see how Cooper recommends rotating your tires.
    http://us.coopertire.com/Tire-Safety/Tire-Maintenance.aspx
    I used to just rotate front to back but I starting having some cupping issues so I now rotate using the criss-cross method shown on Cooper's webside. I also have Cooper AT3s.
  10. Oct 20, 2012 at 4:19 PM
    darkgohan
    Thank you much appreciated!!
  11. Oct 23, 2012 at 10:09 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    I switch between AT and snow tires about every 6 mo /5000 mi, so I just put the tires on a different location the next year, effectively doing the rotation. No abnormal wear issues, though I suspect the snow tires will end up damaged beyond repair long before they wear out. Roads in the winter here have more debris. I picked up two punctures in the last winter alone.
  12. Oct 23, 2012 at 10:11 AM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    after every oil change...so every 3-5 thousand. Depending on the time of year. I change my oil every 3K during cooler months.
  13. Oct 23, 2012 at 6:15 PM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    At 5k when my oil gets changed.
  14. Oct 23, 2012 at 6:21 PM
    Taylor
    Taylor Check out NASA Spec3!
    Taylor
    Vienna, Virginia
    NASA Spec3 RaceCar
    I'm sorry if I'm being stupid, but what is "cupping"?
    I've never heard that. Is that excessive wear on the sides or something?
  15. Oct 23, 2012 at 9:26 PM
    #35
    KenLyns
    Belly of the Beast
    Cupping :notsure:
  16. Oct 24, 2012 at 2:52 AM
    #36
    2TRunner
    2TRunner Snoop Dad
    My House Usually
    LOF & Rotate every 3K.
    Haven't even worn through 3/32nds of my MTs in over 13K.
    Started at 19/32nds of tread, tread gauge was just above the 16/32nds mark at the last LOF/Rotate.
    MTs on @ 52K, now around 63.7K
    I check the balance pretty much every time to.
  17. Oct 24, 2012 at 4:52 AM
    #37
    JRod4928
    Pittsburgh
    '12 Tacoma SR5
    cupping is scalloping. google.
  18. Oct 24, 2012 at 1:55 PM
    #38
    Taylor
    Taylor
    Vienna, Virginia
    NASA Spec3 RaceCar
    So, how do you guys rotate your tires? Front to back, or the "Recommended" way?
    Everyone in my family swears up and down that rotating side to side will definitely scallop your tires.
  19. Oct 24, 2012 at 2:14 PM
    #39
    darkgohan
    Interesting,will like see what people say also. My tire guy says front to back is good,that cross over is an old school thing? My Coopers say cross over,according to information kindly passed onto me here,thanks again for that post.Now lets see where it goes.
  20. Oct 24, 2012 at 7:21 PM
    #40
    jerretxx
    jerretxx Some do, others talk
    Jerret
    North Carolina
    2017 DCSB Tacoma TRD Sport 4x4
    wasnt an option; but I rotate mine every 2k
