how often to change shocks?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacomaPrime, Oct 31, 2011.
  1. May 21, 2012 at 6:17 PM
    Rupp1
    Rupp1 "If you can dodge a wrench, you can dodge a ball."
    NC
    2024 Nissan Titan Pro4X
    I probably didn't need to, but I just replaced mine at around 90k. I just bought some off of another member's '11 Sport, and put them on my '06 SR5. The ride seems nicer.
  2. May 21, 2012 at 6:22 PM
    The1youluv2hate
    The1youluv2hate Well-Known Member
    Peps
    SAnta Paula CA
    18 TRD sPort 4x4 (11mgmsport)
    oem pro grill 17” pro rep wheels Fox dsc shocks
    Just an alignment
  3. May 22, 2012 at 1:19 PM
    TacomaPrime
    TacomaPrime [OP] Cybertronian Tacoma
    Gregory
    Illinois
    14 TRD sport 4x4 Barcelona Red
    Weathertech front floor liners, window vent visors. Custom bedside decals. OEM bed mat, tonneau covrew. Added D rings to bed.
    Oh nice! Whats the max height increase you can go without needing anything but an alignment?
  4. May 22, 2012 at 3:27 PM
    TacomaPrime
    Gregory
    Illinois
    Well, that news makes me happy. I was thinking about just going up 1.75"
  5. Oct 10, 2018 at 9:56 PM
    zilla805
    zilla805 Weekend warrior
    San luis obospo
    4x4 TRD
    I have a hundred seventy thousand miles on mine and they running good. Thinking about installing a 2.5 for suspension on it soon
    I married my tacoma likes this.
  6. Oct 11, 2018 at 5:54 AM
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    Are shocks easy to do yourself or is this something the dealer/mechanic should do? Not sure if special tools are needed, I've never done it and have not googled it yet.
  7. Oct 11, 2018 at 7:16 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    You replace them when you need them. And you will tell when you need them.
  8. Oct 11, 2018 at 7:19 AM
    PackCon
    Connor
    The front STRUTS will require a spring compressor. You can decide for yourself if thats a job you want to take on.
    Unless you buy a whole new coilover already assembled.
    The latter is advisable. Especially if its a longer coil for a lift. :thumbsup:
  9. Oct 11, 2018 at 7:22 AM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    I just changed mine out at 100K. Replaced the OEM TRD Bilsteins with 5100's.
    I didn't think I needed them, but after the swap, I realized how worn my original shocks were.
    I spend a lot of time on forest/logging roads and that gradually takes its toll over the years.
  10. Oct 11, 2018 at 7:53 AM
    Armed in Utah
    Armed in Utah Well-Known Member
    Utah's High Desert.......
    2003 Lexus LX 470
    Installed 5100's here on my '14.....fronts set 3rd ring.....1.75" ride just fine
    I wouldn't bother putting used shocks on....especially the fronts with labor cost
    otherwise...stock Toyota or Bilsteins last a long time....just get beat up from gravel
    TheDevilYouLove likes this.
  11. Oct 11, 2018 at 8:51 AM
    TheDevilYouLove
    Marylandistan
    So jelly of you Utah people!! I love spending time there. Eat some Blue Lemon and Waffle Love for me!!
    Armed in Utah[QUOTED] likes this.
  12. Oct 11, 2018 at 11:14 AM
    TheDevilYouLove
    Marylandistan
    I'm also wondering how long shocks last. My 2010 taco with 130,000 miles on it does not ride as smooth as my wife's brand new Subaru. I'm wondering if my shocks have slowly worn out over the years. I have the TRD Sport that came stock with Bilsteins. Might be time to replace them.
  13. Oct 11, 2018 at 12:12 PM
    PackCon
    Connor
    Neither. Its based on use.
    Mine pretty much burned out in a month of serious hauling.
    Heavy off road use will burn through then quickly as well.
  14. Oct 11, 2018 at 2:15 PM
    Armed in Utah
    2003 Lexus LX 470
    our dry spell has ended.......rained for nearly the last 10 days.......
    local mountains picked up 24"+ snow.......thats a 9K'........!
    Skyline Drive I'm sure closed for the year.......rain/snow today right now
    Hopefully its a heavy wet winter ! Good start for sure
  15. Oct 11, 2018 at 2:26 PM
    #35
    TheDevilYouLove
    Marylandistan
    Looks like rear shocks are pretty easy so I ordered some new Bilsteins for the rear for about $150.
    The front appears to be significantly more expensive if you get the whole assembly with the coil.
  16. Oct 11, 2018 at 2:32 PM
    #36
    Armed in Utah
    2003 Lexus LX 470
    fronts......my shop guy charged me 2 hrs IIRC......more work than rears for sure
    that's why I would not install used on front
    no coils included......just shocks.....best pricing is from Headstrong Off Road
    all four under $350 shipped
  17. Oct 12, 2018 at 5:30 AM
    #37
    Coolerman
    Coolerman Well-Known Member
    Dan
    Rochester, NY
    2005 4x4 SR5 AC / 2007 4x4 FJC / 2021 Tesla Y
    Pro/2015 Coil-overs n shocks, Icon progressive AAL, Firestone Ride-Rite Air Bags and cradles, ECGS clamshell bushing, Extang Solid Fold Tonneau cover, 2014 Navigation radio and backup camera, Wet Okole seat covers, rcbs204 lighted 4x4 switch, Weathertech digifit floor mats and in channel window vents, Scanguage II, Hayden 678 Trans cooler, Western Suburbanite plow, Pop and Lock PL8521
    You may get a growling noise caused by the needle bearing in the front if you lift at all. Some people dont have the problem but most eventually do. It can be fixed by replacing the needle bearing. I replaced mine with the ECGS bushing and it eliminates the issue permanently.
    When I replaced the shocks on my truck they had no obvious signs of failure, but I had a major improvement in ride quality over the stock shocks when I installed the 5100's.
  18. Oct 12, 2018 at 9:51 AM
    #38
    TheDevilYouLove
    Marylandistan
    OK, I haven't even received the Billy's I ordered for the rear and I'm already eyeing up replacing the front shocks. I'd like to replace the springs and mounting plate also, so basically I'd be assembling my own coil/strut assembly. What are good replacement springs to pair with Bilstein 5100 front struts? I don't want any lift, factory height is fine on my TRD Sport.
  19. Oct 12, 2018 at 10:19 AM
    #39
    Coolerman
    Dan
    Rochester, NY
    Once you start down this rabbit hole it may never stop. :)
    I dont know that answer to your question but maybe try reaching out to Marie at Headstrong Offroad. They are usually very good about helping to point you in the right direction. Some of the shops will even assemble the strut for you which to me makes the process much easier.
    Or you could look at some Fox 2.0 coilovers or 6112 Billsteins. :)
  20. Oct 12, 2018 at 10:22 AM
    #40
    surfandturf
    surfandturf Well-Known Member
    CT
    2014 TRD DCLB
    I did mine at 100k when toyota was dumping the TRD pro kit for ~$650. Was a no brainer
    E-Paz 732NJ likes this.
