How often you change the air filter?
Discussion in '1st Gen. Tacomas (1995-2004)' started by hec983, Oct 15, 2013.
  1. Oct 15, 2013 at 11:41 PM
    hec983
    hec983 [OP] Well-Known Member
    Like the tittle says, how often do you change your stock paper air filter?? Under normal driving conditions once a year??
  2. Oct 15, 2013 at 11:43 PM
    MGMTacolover55
    MGMTacolover55 Well-Known Member
    Orygun
    2013 MGM Taco TRD Off Road
    floor Mats
    depends. If you start to feel sluggish acceleration then it is time to replace or about ever 10k miles
  3. Oct 15, 2013 at 11:44 PM
    DoyleMcpoyle
    DoyleMcpoyle Well-Known Member
    Carlos
    Bakersfield, CA
    02 TRD 4x4
    Whenever I see that it's dirty enough. No set time really
    Jolly Onion and Mush Mouse like this.
  4. Oct 16, 2013 at 3:50 AM
    Tmiller3063
    Tmiller3063 Active Member
    04 Prerunner Limited
    Dirty or when manual says to
    Mush Mouse likes this.
  5. Oct 16, 2013 at 4:01 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    10k miles
  6. Oct 16, 2013 at 7:47 AM
    offrdmania
    offrdmania Taco Wagon
    Templeton, Ca
    96 Tacoma LX 4 banger
    Take it out of the air box, hold it up to the sun. If it looks blocked then its time to change
    Jolly Onion and Aught2TaCO like this.
  7. Oct 16, 2013 at 7:47 AM
    Large
    Large Red
    If you live somewhere dusty (like the desert) you will obviously change it more often. I change mine every other oil change anyway.
  8. Oct 16, 2013 at 11:27 AM
    WarEagleTacoma
    WarEagleTacoma Well-Known Member
    Tracey
    Vincent, Alabama
    13 PreRunner SR5 Double Cab
    ceramic window tint, LED light kit, all weather mats, bed mat, TRD exhaust, Volant cold air kit, chrome step boards, Bilstien 5100 stuts/shocks , 2 inch lift, Better Built tool box, LT265/70R17 BFG All Terrain T/A KO2
    well if you read the owners manual and factory recommneded maint guide it tells you every 30k to change engine air and cabin air filters but for some of us that mileage will differ so you really just need to look at them and see.
  9. Oct 16, 2013 at 2:24 PM
    Yamaha Dave
    Yamaha Dave Well-Known Member
    I don't...ever. I have a K&N drop-in. And no I don't have any issues with it because unlike most amateurs I don't over oil it.
  10. Oct 16, 2013 at 2:30 PM
    2006TRDSPORT
    2006TRDSPORT 2006TRDSPORT
    Felton, Delaware
    2004 4Runner SR5 4WD
    I replace mine when it looks like it needs replaced, had the K&N filter & it looked like crap after 5,000 miles, I think I'm gonna go with the AFE pro dry filter because it looks much easier to manage. The replacement filters look good for quite awhile though, so they are fine as well.
  11. Oct 20, 2016 at 10:39 PM
    FrostyEldin
    FrostyEldin Well-Known Member
    Austin
    Lewiston, ID
    2008 SR5 Impulse Red
    Is the K&N worth it or is there a better filter?
  12. Oct 20, 2016 at 10:42 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    I was changing mine almost once a month with how often I was wheeling over spring/summer (dusty trails out here + always following other trucks). I try to just keep an old one with me when I go out wheeling now and swap it in for the day until we're done.
    MuddyJackson, FirstGen Jer and jjsul like this.
  13. Oct 21, 2016 at 7:44 AM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    When its dirty.
  14. Oct 21, 2016 at 2:07 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I some times change it after removing the acorns and squirrel nest
    Jolly Onion, koditten and Mush Mouse like this.
  15. Oct 21, 2016 at 2:10 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    Not worry it. There are a ton of better filters. Stock is better. If you want reusable then look at AFE pro dry
  16. Oct 21, 2016 at 2:17 PM
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
    both K&N and AFE allow more dirt into your engine than the paper filters FYI
  17. Oct 21, 2016 at 2:19 PM
    pudge151
    Sean
    Connecticut
    I agree. I was suggesting if he's stuck on going with a washable AFE has been shown superior to K&N. A paper filter is better for filtering
  18. Oct 21, 2016 at 2:20 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    I am curious why does no one list the filter capacity of your favorite flavor of filter ??
    Then is this like keep up with the neighbors they use it so I will as well
    I like the Toyota ones If I forget and use them all I get a Wix
  19. Oct 21, 2016 at 2:22 PM
    pudge151
    Sean
    Connecticut
    Capacity of an air filter?
  20. Oct 21, 2016 at 2:27 PM
    Mush Mouse
    mush
    2013 SR5
