How often you guys change your Oil
Discussion in '1st Gen. Tacomas (1995-2004)' started by nyg052003, Mar 1, 2015.
  1. Mar 1, 2015 at 7:56 PM
    nyg052003
    nyg052003 [OP] Nyg052003
    Charleston, SC
    04 Tacoma TRD Offroad SR5 4x4
    Haven't really read much of the manual yet but I would assume it would say change the oil at 3k miles for severe use and 5k miles for normal stuff or do I have that backwards or some of the wording wrong :)
    and what do you guys change yours at?
  2. Mar 1, 2015 at 8:09 PM
    larrybugcatcher
    larrybugcatcher Well-Known Member
    Tristan
    NC
    03 Xtracab 4x4 & 20 DCSB 4x4 stock
    3" Toytec Boss coilovers and Toytec AAL 33x10.50s KO2
    My father always changed oil in our toyotas every 3.5k so naturally that's what I do with mine.
  3. Mar 1, 2015 at 8:15 PM
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    2002 Toyota Tacoma 4WD
    Check Build
    I do 5000 but thats with synthetic if it makes a difference.
  4. Mar 1, 2015 at 8:16 PM
    Justn868
    Justn868 Well-Known Member
    Justin
    Kansas City
    14 4x4 TRD OR
    Every 5,000 miles
  5. Mar 1, 2015 at 8:24 PM
    JTrean
    JTrean Well-Known Member
  6. Mar 1, 2015 at 8:33 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    I use straight synthetic and change it every 10,000 miles but I don't drive it hard.
    the oil is not very dirty when I change it
    if I had dino oil I would change it every 5,000 miles
    synthetic lasts twice as long as regular oil so if your just switching over just double what you used to normally go.
  7. Mar 1, 2015 at 9:04 PM
    Holy schmidt
    Holy schmidt Well-Known Member
    Wyatt
    Nebraska
    every 4.5k with synthetic. Time wise its like 3-4 months id guess
  8. Mar 1, 2015 at 9:20 PM
    520Toyota
    520Toyota Well-Known Member
    C.V.
    Nor Cal
    dcsb 6spd 4x4 offroad
    Ome lift
    Mobil 1 synthetic with KN oil filter every 10k.
  9. Mar 1, 2015 at 9:27 PM
    whahahajr
    whahahajr Lone Star Club
    jimbob
    New Braunfels, Tx
    07 Tacoma TRD
    Camburg Uniball UCA, ARB Front Bumper, TAG rear bumper, OME rear shocks, All Pro 3" leaf springs
    Wow.
    Syn and ever 3k-4k. And it's dirty as heck. But it takes me about 6 months to drive 3k.
    I also use 5w30 mobile from Walmart (cheapest place to buy it).
    But I use a Mopar 452 filter due its larger capacity.
  10. Mar 1, 2015 at 9:40 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Mobil 1 5w30 with a Toyota oil filter every 5-6,000 miles. Usually about trice a year.
  11. Mar 1, 2015 at 9:45 PM
    opteron
    opteron Well-Known Member
    whittier, CA.
    2003 DB 4x4 SR5
    Leer camper, bug-rug, fox suspension 2.0 rear, fox 2.5 front, BAMF sliders and LCA, TRD fake 3 piece rims
    I do 7k, oil always clean.
  12. Mar 1, 2015 at 10:52 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
  13. Mar 1, 2015 at 10:59 PM
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    cheap Dino oil, and change it once a year. Have to add 1/2 quart every 1.5-2 months so it should stay pretty fresh.
  14. Mar 1, 2015 at 11:10 PM
    tbaird450
    tbaird450 8th Taco
    Travis
    Utah
    TRD Supercharged 2002/ DC OR 6-spd 2011
    Trd Supercharger 2.5" Lift MT Classic Beadlocks Blacked out Headlights #guttedcats
    I usually change mine with full synthetic every 4.5-5K. It really depends on your driving/RPM more than the actual milage. '11 4.0 6spd
  15. Mar 2, 2015 at 3:52 AM
    smokn
    smokn Unsenior Member
    08 DCSB TRD SPORT SR5 4x4
    Per the factory maintenance schedule, conventional 5w-30 and an OEM filter every 7,500 on all 3 3.4's I service.
  16. Mar 2, 2015 at 3:55 AM
    Large
    Large Red
    5K like others, after 100k or so I plan to run 10k mile intervals and change the filter at 5k.
  17. Mar 2, 2015 at 4:03 AM
    JAGER91374
    JAGER91374 Well-Known Member
    Des Plaines
    3 TRD O/R
    OME 883's and Dakars, OME Shocks, Gray Wire, Deck Plate, Blacked Out Chrome, RAT Skids, BAMF BPV Bracket, Toytec Diff Drop, Braided Extended Brake Lines Front and Rear, In-Dash Nav.
    Every 5000 miles or twice a year. Now that the truck is semi retired from daily duty I only put 6500 miles on it last year. 5-30 Synthetic of course.
  18. Mar 2, 2015 at 4:16 AM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    Mobil1 with OEM filter every 5K
    :thumbsup:
  19. Mar 2, 2015 at 4:17 AM
    Clearwater Bill
    Billy
    Largo Florida
    Anytime I get a vehicle under warranty, I follow the schedule that protects the warranty.
    Which for me is exceedingly rare. Like 4 times in 55 vehicles.
    On vehicles I use dino in, I just follow the heavy duty cycle, typically 5k. (BTW, modern SN oils are very good, almost syn quality in many ways)
    On vehicles I use syn in, I do my initial change from the PO oil in the first couple weeks. Mobil 1 of the correct weight. I then change at 5k and send a sample to Blackstone labs and let them tell me what it looks like.
    Typically they report back to sample again at 10k the next time. Which I do. Again, they'll often suggest I still have 'headroom' of another 3-4k. Which is nice if life gets in the way and I need it, but normally 10k becomes the standard.
    Now, since some vehicles I don't drive 10k a year, I'll send in an annual sample. Usually I learn things are just fine. Up to 3 years of fine.
    Working with a tribologist I know, who has his own lab resources, we've pretty much determined that miles are the major factor, not time.
    Long story short..............
    If out of warranty, it doesn't matter much what the book says or what anyone else tells you they do. What matters is what your vehicle requires, based on the lubricant you choose to use, how you use the vehicle, and the results of independent lab tests.
    Everything else is pretty much guessing and voodoo.
    BTW, you can't really tell anything about the condition of the oil and it's additive packages based on it's color at change time. Dark oil can have tons of life left. Only your lab tech knows for sure :cool:
    And for those of you who think I'm totally nuts, do some reading over on http://www.bobistheoilguy.com/ While there is a lot of antidotal junk on there (from forum members) there is also a lot of hard evidence supported by long term testing............
  20. Mar 2, 2015 at 4:21 AM
    chairly55
    chairly55 Active Member
    Frank
    South Shore, Boston
    White 2013 TRD Off-Road
    35% tint, brush guard, taillight guards, 4" rugged ridge LED, tonne cover, 31" KO's, interior floor lighting, plastidip
