How on Earth do you read the oil dipstick?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jross20, Feb 25, 2019.
  1. Feb 25, 2019 at 3:38 PM
    #41
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    I skimmed the thread and didn't see this method mentioned so here goes. I'm going to tell you guys the secret to getting a good dipstick reading in a taco so LISTEN UP! Note that I haven't tried this on any "turn and lock" style dipsticks so YMMV. It works perfectly on any 2.7L I've tried it on.
    1. Pull out and wipe as usual
    2. Reinsert but not fully. Stop when it's about 3-4 inches from being fully seated.
    3. STAB AND YANK. Quickly push it down the rest of the way until it seats and immediately yank it out quick like how some ATM machines like you to do your debit card.
    4. Observe the clearest reading you've ever gotten with your dipstick.
    2k2, jross20[OP] and b_r_o like this.
  2. Feb 25, 2019 at 4:53 PM
    #42
    DirtJumper14
    DirtJumper14 Well-Known Member
    SoCal
    2005 TRD OR
    5100's, BDF grills and light bracket, big 3 upgrade, ATH bed braces, snugtop xtra vision shell, (bed, shell, hood, rock, front, rear, footwell, glove box, center console led lighting), MESO Gasshole, MESO dome and map lights, Flyeyez center console light, custom fuse panel, TRD CAI, toyota bed mat, 2013 black carpet, 2015 side mirrors, BedRug, AJT key fob, ultraguage, 8 cadillac horns acdf, pop n lock tailgate lock, energy suspension bushings, spicer greasable ujoints, Rigid lights everywhere, kenwood stereo, led tube taillights (red), 2018 T4R trail wheels, rokblok mud flaps, TRD skid plate, RCi gas tank skid plate
    jross20[OP] likes this.
  3. Feb 25, 2019 at 5:05 PM
    #43
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    You don't. Lol. The dipstick shows a blurred line every time on mine. I've sanded it and made cross hatches on it and it's almost useless. It tells me if I changed the oil and that's it.
    cryptolyme and jross20[OP] like this.
  4. Feb 25, 2019 at 5:38 PM
    #44
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    If you pull it and check a bunch of times its going to get harder and harder to read as you pull more and more oil up into the tube.
    Pull the stick and wait 5 mins.
    As mentioned above, dip it and remove it quickly.
    Check both sides and compare what looks like the highest reading. Wait another 5 mins before you check again.
    :bananadance:
  5. Feb 25, 2019 at 5:50 PM
    #45
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    I just check mine cold most of the time, before I even start the engine for the day. That, and safety glasses with a 1.5 set of cheater lenses in them.
  6. Feb 25, 2019 at 9:30 PM
    #46
    Dustflap
    Dustflap Well-Known Member
    None of the oil checking methods mentioned here work with any consistency on the 2.7L. To get a semi readable level sometimes takes 5 to 8 tries. The problem is the "S" shaped dip stick tube. As you pull the dip stick out, one part of the "S" wipes the bottom and the other wipes the top making it difficult to obtain a good reading. 0w20 oil being so thin contributes to the problem. Bad design on Toyotas part!!
    mistermanny and GilbertOz like this.
  7. Feb 26, 2019 at 11:32 AM
    #47
    DRP6833
    DRP6833 Well-Known Member
    Dave
    Frederick, CO
    2014 Tacoma I4 4WD
    Correct. Probably shoulda mentioned that.
  8. Feb 26, 2019 at 4:18 PM
    #48
    jross20
    jross20 [OP] Well-Known Member
    Georgia
    2000 4Runner SR5 4x4 | V6 | Auto
    Tundra 5100s F+R, OME 880s+890s, duro bumps, etc
  9. Feb 26, 2019 at 4:41 PM
    #49
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    This has been the key for our cars, especially the I4 Camry which has an S-shape tube - if one side is smeared, 8/10, the other side will be more readable. Same for cars with ATF dip sticks.
    b_r_o[QUOTED] likes this.
  10. Feb 26, 2019 at 4:48 PM
    #50
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    PzTank and b_r_o like this.
  11. Feb 26, 2019 at 5:43 PM
    #51
    rphillips
    rphillips Well-Known Member
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    It's amazing how simple checking oil was for over 100 yrs. Why did it need to be changed? Why, why, why. Please just put it back like it was.
    Lone
  12. Feb 26, 2019 at 6:17 PM
    #52
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    If this post gets this thread to 4 pages, I’ll be kicking myself...
    I can’t really tell if you’re serious or just yanking chains here???
    Have you noticed THE difference between the two pdfs?
  13. Feb 26, 2019 at 7:08 PM
    #53
    jross20
    Georgia
    Nah I downloaded them on my phone earlier, just got home a bit ago. A phone isn't great for big PDF's haha.
    On my desktop now so I'll check em out.
    Ok looks like one... is the Canadian one? Not sure... but this isn't the one I was actually looking for... I see people posting from what looks like a super book like I used to have for my first car. Shows you exactly how to do anything, take things apart, replace things, all the diagrams and torque specs. Etc.
  14. Feb 27, 2019 at 2:58 AM
    #54
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    I stopped checking the dipstick about 150,000 miles ago. I just drain and fill 5.5 quarts of oil every 6,000 miles...good to go.
    TacomaMike37 and spitdog like this.
  15. Feb 27, 2019 at 5:03 AM
    #55
    PzTank
    Above the Notches
    You’re looking for the Factory Service Manual (FSM).
    Search this forum for it. There are links and you have to download sections one at a time.
    Regarding the Owners Manual, I was hinting at the possibility of the MY date being the difference between the two manuals for your MY. This is the way the 2015 manuals were differentiated.
    jross20[QUOTED][OP] likes this.
  16. Feb 27, 2019 at 5:26 AM
    #56
    jross20
    Georgia
    Ah thanks my man!
    PzTank[QUOTED] likes this.
  17. Nov 2, 2022 at 1:34 PM
    #57
    TatoesTaco
    TatoesTaco New Member
    2022 trd sport
    Vehicle Modifications:
    I don't advise doing this but I did I also work with metal on a daily. You can take a torch to the tip and quench in dirty oil to darken the metal, easier to see it on a dark background. Tho be careful not to harden it to much from the quenching process. Do not get it anywhere near to glowing red or even orange.
    I'm not sure if it would work but I think it would, other option being cold bluing. I'm to lazy to get it and try but u think that be a solid option.
  18. Jan 1, 2024 at 5:30 PM
    #58
    Bosshoag
    Bosshoag Well-Known Member
    Mr. Doogan
    Virginia Beach, VA
    '20 4X4 TRD Off Road MT
    I'm here for knowledge folks, please feel free to inform me. Expedition Essentials Track Mount Weather Tech floor liners and window vents K&N air filter Summit Dakars in Matte Bronze -25 offset King suspension from Filthy Motorsports MESO customs white/red interior lights and MESO customs gasshole
    Maybe if I dip the tip in sugar I’ll be able to see where sugar remains when I pull it back out and that’ll be the level… like the Fun Dip candy right?
    Just messing/trying to get this thread to 4 pages though honestly I like the idea of pulling it out, wiping it off, then waiting 5 minutes before a quick stick and pull out. I’ve already crossed hatch filed one side of my stick and was still having issues the last couple days getting an accurate reading.
  19. Jan 2, 2024 at 4:25 PM
    #59
    Bosshoag
    Mr. Doogan
    Virginia Beach, VA
    I’ve read a few TacomaWorld threads in full on this topic and now I have “THE ANSWER!” For an accurate reading, run your truck for a bit to get it to operating temperature (when temps increase stuff expands so nice always been told to check oil on a warm engine.) Pull the dip stick, wipe it off, and let it sit for 5 minutes or so to let the oil drain down to the pan and out of the dip stick tube. Grab your stick, get it started in the tube, then before you get too deep, thrust it all the way in until it’s fully inserted, and pull it out immediately. With the end pointed down, quickly set it down on a blue shop rag paper-towel, and rotate it once so you can see the wet oil mark on the rag compared to the oil level markings of the stick right next to each other.
    If anyone is interested, I’m willing to take some pictures or something to assist with this. It can be frustrating. I also made cross hatched etching on the tip of my stick which wasn’t totally necessary after using the method above.
    2k2 likes this.
  20. Jan 2, 2024 at 4:42 PM
    #60
    Squirt
    Squirt Samsung Aficionado!
    Ben
    Cornfields of Illinois
    2016 F150 Lariat with 3.5L of fury!!
    Rexing front and rear dash camera, some LEDs, Weathertech HP floor liners/vent shades/bug deflector/underseat storage bin, OEM Ford bed mat, Diode Dynamics SS3 Pros in selective yellow, Diode Dynamics 18" light bar in amber and universal Carhartt seat covers. Bak Revolver X4S tonneau cover. Android Auto USB plug upgrade! H11 to H9. Sound deadened/insulated floors and rear wall. VLED license plate reverse light. Yokohama GO15s. Rokblokz mud flaps. "Custom" 3in Flowmaster Super 50 Series cat back with a 3in Speedys Snap resonator. J&L catch can. AMP Powersteps
    Nearly 5 years later and its only gotten worse :bananadead:
    SR-71A likes this.
